Quantum electromagnetic interference
In summary, photons associated with radio waves have very small energy, so they cannot induce any visible particle-type effects (photo-electric effect or blackening of photographic plates). So, it is very difficult (almost impossible) to see particle-like properties of radio waves. Nevertheless, it is reasonable to assume that all physical properties of visible light and radio waves are the same. So, there should be no fundamental differences in the double-slit experiment performed with these two kinds of radiation.
Sherlock_H
Hi
I wonder if I could get help with some questions that have puzzled me related to the two split experiment and electromagnetic interference in general.
I know that if you shine a laser beam through the two split experiment then inference patterns will appear, and that if the path of a photon traveling through the experiment is measured or known then the interference patterns break down.
I have also read that this also works if two (identical) laser beams are combined, i.e interference occurs. If the laser beams were 180deg out of phase then the peaks and troughs would cancel out the beam.
1. Can I assume that, if I were able to determine which laser beam an individual photon came from the interference would also break down?
2. I was wondering whether this works exactly the same for radiowaves? If I were to position a receiving aerial between two radio transmitters, (some distance apart), that were transmitting the same frequency radio signal but 180deg out of phase the radio signal would be canceled out and the aerial should not receive anything.
3. If I now added two more receiving aerials, each one positioned slightly closer to one of the transmitters. By comparing the difference in signal and phase between the first aerial and the second new pair of aerials I should surely should be able to work out the path of the radiowaves. Does the interference breakdown? Do I suddenly receive a signal from all the aerials or just the second pair or maybe nothing changes?
4. If this is true what happens if the two transmitters are now brought close together (I guess near field). Do the same effects happen?
I may be well off track so please forgive my lack of knowledge. I may have to go and buy some radio equipment...
Thanks
Steve
Hi
I guess my question is really this, is there an equivalent experiment/or research to the double slit experiment, carried out at Radio frequencies?
i.e that radiowaves also travel as a wave but arrive as a particle, and interference can be made to break down when the path of the radiowaves are known.
hope someone can help?
Thanks
Sherlock_H said:
Hi
Thanks
Photons associated with radio waves have very small energy, so they cannot induce any visible particle-type effects (photo-electric effect or blackening of photographic plates). So, it is very difficult (almost impossible) to see particle-like properties of radio waves. Nevertheless, it is reasonable to assume that all physical properties of visible light and radio waves are the same. So, there should be no fundamental differences in the double-slit experiment performed with these two kinds of radiation.
Eugene.
Your first experiment with the two laser beams would be a very good one to run, as it might give insight into the nature of the double slit experiment. It sounds like a good alternative that could demonstrate the same principle. However, off the top of my head I can't quite think of a way to tell which laser beam a given photon came from if the beams are combined.
If what you say about interfering lasers is true we should get interference even if both lasers are firing single photons, which to me is intuitively wierder than the double slit. Maybe there is a way to determine which it came from with individual photons
Hi
Thanks for the responses. I have seen several references to the fact that two laser beams will produce interference patterns. I have been trying to find them, one is below.
https://www.physicsforums.com/showthread.php?t=218827.
When I find another I will add it in.
OK, I've done a bit more research and proving radiowaves act like a particles is the problem. So for interference patterns to stop single photons have to be effectly observable, is this correct? I wonder if this has ever been done, maybe by indirect means?
Thanks
Sherlock_H said:
Hi
Thanks
Well, keep in mind that while visible light is of course composed of photons, but so are radio waves, microwaves, x-rays, etc...
To my knowlege, all photons have wave-particle duality.
Related to Quantum electromagnetic interference
1. What is quantum electromagnetic interference?
Quantum electromagnetic interference, also known as quantum noise, is a phenomenon that occurs at the quantum level and affects electromagnetic fields. It is a random fluctuation of the electromagnetic field that can interfere with measurements and communication signals.
2. How does quantum electromagnetic interference impact technology?
Quantum electromagnetic interference can cause errors and disruptions in technology, especially in sensitive electronic devices and communication systems. It can also limit the accuracy and precision of measurements.
3. What causes quantum electromagnetic interference?
Quantum electromagnetic interference is caused by the unpredictable behavior of particles at the quantum level. It is a result of the Heisenberg uncertainty principle, which states that it is impossible to know the exact position and momentum of a particle at the same time.
4. Can quantum electromagnetic interference be eliminated?
It is impossible to completely eliminate quantum electromagnetic interference, but it can be minimized through advanced technologies and techniques such as shielding, filtering, and error correction codes. However, some level of interference will always be present due to the nature of quantum mechanics.
5. What are the potential applications of quantum electromagnetic interference?
While quantum electromagnetic interference can be a nuisance in technology, it also has potential applications in quantum computing and cryptography. It can also be used for random number generation and in quantum communication protocols.
  • Quantum Physics
