Quantum entanglement and hidden variables
In summary, the conversation discusses hidden-variable theories in quantum mechanics and the concept of locality in physics. It also touches on the phenomenon of quantum entanglement and the lack of mechanisms to explain it. The conversation concludes with a discussion on the limitations of current theories and the need for further understanding of the underlying principles of nature.
PainterGuy
940
70
Hi,
I have a basic understanding of quantum physics. I was reading a Wikipedia article on hidden variables, https://en.wikipedia.org/wiki/Hidden-variable_theory . The article says the following.
In physics, hidden-variable theories are proposals to provide explanations of quantum mechanical phenomena through the introduction of (possibly unobservable) hypothetical entities. The existence of fundamental indeterminacy for some measurements is assumed as part of the mathematical formulation of quantum mechanics; moreover, bounds for indeterminacy can be expressed in a quantitative form by the Heisenberg uncertainty principle. Most hidden-variable theories are attempts to avoid quantum indeterminacy, but possibly at the expense of requiring the existence of nonlocal interactions.
Albert Einstein objected to aspects of quantum mechanics, and famously declared "I am convinced God does not play dice". Einstein, Podolsky, and Rosen argued while assuming local causality that quantum mechanics is an incomplete description of reality. Bell's theorem and the related experiments have subsequently ruled out nearly all local hidden variable theories.
One notable non-local hidden-variable theory is the De Broglie–Bohm theory.
I was confused about the words "local" and "nonlocal" in the quote above so I checked out another Wikipedia article, https://en.wikipedia.org/wiki/Principle_of_locality . The quote below has been taken from the mentioned article.
In physics, the principle of locality states that an object is influenced directly only by its immediate surroundings. A theory that includes the principle of locality is said to be a "local theory".
Question:
The quantum entanglement phenomenon is also non-local where one quantum particle can influence the other particle instantaneously which could be located thousands of miles away.
How is this phenomenon explained? Is it only taken as 'natural fact' without any resort to underlying mechanism which is responsible for this instantaneous interaction? Or, it is accepted that there are some unknown features or variables in nature, experimentally not-yet-discovered, which are responsible for this entanglement?
I'd appreciate if you could keep it simple though I do agree this topic is difficult to simplify. Thank you for your help, in advance! Helpful link:
1: https://www.scientificamerican.com/article/how-einstein-revealed-the-universe-s-strange-nonlocality
PainterGuy said:
Question:
The one quantum particle does not influence the other one instantaneously via some mechanism that exchanges information. The system cannot be considered as a pair of separate, distinct particles. Both members of the entangled pair must be considered together as an inseparable pair rather than two individual particles.
That is about as basic as I can make it, as requested.
Likes PainterGuy, DrChinese, vanhees71 and 1 other person
PainterGuy said:
Question:
As above, QM predicts correlation across a non-local system. Not influence of one system on another.
There are no mechanisms in physics, as such. Here's an interesting example from this site recently. You have a positive charge at the origin and a negative charge on the x-axis. What is the electric field further along the x-axis, beyond the negative charge? A student recently assumed that the negative charge would block the electric field from the positive charge at the origin. It was explained that electric fields pass right through intervening charges. What is the mechanism for this he asked?
More generally, what is the mechanism for local phenomena? How does a particle in an EM or gravitational field know to react to the field in a certain way? If it follows the gradient of the potential, how does it know the gradient? Again, there is no rational mechanism for how this happens.
My point is that QM is not as different in this respect as many people would like to imply.
There may be a deeper theory, but there may not. But, even if there were a deeper theory, I suggest it would have its own fundamental assumptions and lack of mechanisms to explain these.
PainterGuy said:
This is a decidedly unhelpful link. The more you read of popular science journalism, the less you understand about QM as a robust academic branch of physics.
PS after over 900 posts on PF, you should know better than to link to something like this!
Likes PainterGuy, DrChinese and vanhees71
Thank you for the help!
About the charge example. I have always thought of a positive charge as the source and a negative charge as the sink. If a negative charge is lying along the positive x-axis and the positive charge is situated at the origin, I think that some of the the field lines emanating from the positive charge will converge onto the negative charge.
Source: University Physics, Young, Freedman, 13th ed. pg. 709
I get your point. Thanks.
If I trusted popular science that much, I wouldn't be asking you for help. Yes, for a beginner, sometimes these popular science articles can make one interested to search further.
Thank you for your time!
Here is a simple analogy. In Newtonian gravity, a massive particle acts on another massive particle far away, instantaneously. How is this phenomenon explained, within Newtonian gravity?
Likes PainterGuy and DrChinese
Thank you.
It is just assumed that nature acts in some mysterious way. Though, I think that Newton himself knew that this is not really true.
Likes vanhees71
In the 'Many Worlds' interpretation of quantum physics, both entangled particles will exist in separate worlds when a measurement is performed.
For example, in the case of a simple Bell pair where the wave function has 50% probability of finding the two particles with spin up and 50% probability of finding them spin down, when a measurement is performed on the particle(s) then worlds branch. One world has the spin-up particles, and another world has the spin-down particles. The two pairs exist separately, independently and non-interactively.
From Sean Carroll's book 'Something Deeply Hidden' (page 105), "The correlations don't come about because of any kind of influence being transmitted faster than light, but because of the branching of the wave function into different worlds, in which correlated things happen."
To me, 'Many Worlds' is much nicer in this regard. "Spooky actions at a distance" and hidden variables are no longer required.
Is this the way that our world(s) really operate? We will probably never be able to know, but it is an interesting concept to ponder.
  • Skeptical
Likes PainterGuy and PeroK
You've misunderstood that "Many Worlds" is not a different theory from QM, but only an interpretation of QM. There is no "spooky action at a distance" in QM (except that the ghost of Einstein's reservations about QM still cast a shadow seventy years after his death). Einstein, I suspect, would have been horrified by the Many World's Interpretation (MWI). And, there are no "hidden variables" in QM.
Sean Carroll is a great physicist, but he takes his proletyzing zeal about MWI too far, in my opinion.
Note that this is a popular science book and, therefore, not a valid reference for QM on this forum, I'm sorry to say.
Likes PainterGuy and vanhees71
FAQ: Quantum entanglement and hidden variables
What is quantum entanglement?
Quantum entanglement is a phenomenon where two or more particles become interconnected in such a way that the state of one particle is directly related to the state of the other, regardless of the distance separating them. This means that measuring the state of one particle instantly determines the state of the other, even if they are light-years apart.
How does quantum entanglement challenge classical physics?
Quantum entanglement challenges classical physics by defying the principle of locality, which states that objects are only influenced by their immediate surroundings. In classical physics, information cannot travel faster than the speed of light. However, entangled particles seem to share information instantaneously, suggesting a form of connection that classical physics cannot explain.
What are hidden variables in the context of quantum mechanics?
Hidden variables are theoretical constructs that aim to explain the behavior of quantum systems through underlying, deterministic factors that are not accounted for in standard quantum mechanics. The idea is that quantum randomness might be due to our ignorance of these hidden variables, rather than inherent indeterminacy in nature.
What is Bell's Theorem and how does it relate to hidden variables?
Bell's Theorem is a fundamental result in quantum mechanics that shows that no local hidden variable theory can reproduce all the predictions of quantum mechanics. It provides a way to test whether the correlations predicted by quantum mechanics can be explained by local hidden variables. Experiments have consistently supported the predictions of quantum mechanics, suggesting that local hidden variables do not exist.
Can quantum entanglement be used for faster-than-light communication?
No, quantum entanglement cannot be used for faster-than-light communication. While entangled particles do exhibit correlations instantaneously, the process of measuring one particle does not transmit usable information to the other particle in a way that can be controlled or used to send messages. The no-signaling theorem in quantum mechanics ensures that entanglement cannot be used to violate causality or transmit information faster than light.
9K
