Quantum entanglement and wireless electricity
In summary, quantum entanglement allows for two particles to be connected despite an enormous distance, allowing for the properties of one to be transferred to another. However, this does not mean that physical effects can be transmitted between the particles. Entanglement refers to a constant global property of the particles being analyzed by a variable global instrumental setting. While some believe that energy can be transported through entanglement, it is still a highly debated topic and further research is needed. It has been shown that classical correlation between particles can be used for energy teleportation, but this is dependent on the ground-state multipartite entanglement generated by nearest-neighbor interactions. It is important to read papers published by experts in the field, such as Masahiro
rpcarnell
I read about quantum entanglement in an article about teleportation I read on the web.
If two particles can be connected despite an enormous distance, in such a way that the properties of one can be transferred to another, even though no wire or string is linking them, can you use this quantum phenomenon to transmit power without wires? For example, if I submit an electron to a strong magnetic field, will the electron entangled to it behave as though it is being affected by a strong magnetic field? Could I use this to transport energy without a wire?
I know I am making little sense, but I can't be any clearer.
According to the quantum theory of entanglement, you can't transmit CAUSE from one entangled particle to another. They have an after-the-fact correlation, which can only be verified by exchanging signals at light-speed or less. In other words, relativity is not mocked by quantum entanglement.
Welcome to Physicsforums!
The entangled state does not mean that what happens to one happens to the other. It means that what you learn about one is consistent with the other - while they are entangled. In the example you describe, you would terminate the entangled state rather than transmit an effect. That is because the magnetic field could be used, in principle, to gain information about particle spin.
You couldn't use it to transport energy. The separated
particles aren't physically connected and aren't 'communicating'
in any way. No properties of the particles are transferred.
But now, after the replies you got, I'll bet you're wondering
what entanglement is, exactly. :-)
Well, here's my take on it.
A *constant* (as in nonvarying) global property of the
entangled particles is being analyzed by a *variable*
"Global property" of the particles refers to some physical
characteristic, such as momentum or polarization, wrt which
they're related. Two ways to create such a relationship are
to have them interact (ie., hit each other) or to produce them
by the same atomic oscillation (there are also other ways
to entangle two or more particles).
For certain preparations, this relationship is invariant, and
such an invariant relationship is what is necessary in order
to produce predictable variable results (of the sort that
are called entangled) by variable global instrumental settings.
As long as no external torques are introduced to either of
the entangled particles, then they can be light years apart
and the relationship they have to each other, created
by common cause or interaction, will remain intact.
"Global instrumental setting" refers to some combination
of the setting of the instrument analyzing particle 1 with
the setting of the instrument analyzing particle 2.
For example, in the case of photons entangled in
polarization, it's the angular difference of the polarizer
setting p_a, at A, and the polarizer setting p_b , at B -- and
you can see that, even if the polarizers are light years apart,
changing the setting p_a or p_b simultaneously
(ie., instantaneously) changes the global variable |p_a - p_b|.
Further, there is always one and only one global instrumental
setting for any pair of detection attributes (A,B) -- no matter
how or how often the global instrumental setting is
varied while the entangled particles are in flight.
Well, Masahiro Hotta, the Japanese physicist, who published the paper wouldn't agree with you. I suggest that you should search papers published by him and read it.
As per Hotta, energy can certainly be transported from Point A to Point by entanglement and at the conclusion, he said that "it may be concluded that bipartite entanglement between A and B itself is not essential for QET" (QET: Quantum Energy Teleportation). His another conclusion is "this implies that an almost classical correlation between A and B is su¢ cient to execute QET for large separation, and is expected to be robust against environmental disturbances in contrast to the entanglement fragility in the previous quantum teleportation scheme. It should be emphasized, however, that this classical correlation is originally induced by the ground-state multipartite entanglement generated by nearest-neighbor interactions".
I suggest to everybody to read papers published by Hotta in this regard and then make comments.
But, after studying the paper, a scheme of information exchange suddenly come to my mind. As per the good old Alice and Bob analogy. As per Hotta, if Alice inject energy Ea to his own particle, the output Bob will get will be Eb, and the output is less than or equal to (maximum) the input by Alice. But, whatsoever, there is an output.
I just want to propose that we can use this phenomenon for information exchange. As for example, when there is an input, there would be an output and that means 1(one). When there is no input (as per Hotta), there would be no output and that's 0(zero). I just wonder why don't we use this phenomenon for transfer of information.
At present, conventional IT is enough for us to communicate. But, problems arise when we want to communicate with something that had already left our planet. As for example, some probe in Mars can send pictures and data far more quickly and clearly than conventional method and we don't have to set large antennas to capture the very faint signal sent by the probes.
Moreover, such kind of communications will be much safer and "leakage proof". There is practically no chance for any third party to tap the data.
pranj5 said:
Well, Masahiro Hotta, the Japanese physicist, who published the paper wouldn't agree with you. I suggest that you should search papers published by him and read it...
Welcome to PhysicsForums, pranj5!
This is a 6 year old thread. I would recommend that if you want to discuss a specific paper, that you cite it - and the issue you wish to discuss - in a new thread.
Related to Quantum entanglement and wireless electricity
1. What is quantum entanglement?
Quantum entanglement is a phenomenon in quantum physics where two or more particles become connected and share a state, even when separated by large distances. This means that the state of one particle can affect the state of the other, regardless of the distance between them.
2. How does quantum entanglement relate to wireless electricity?
In wireless electricity, energy is transferred through electromagnetic waves. Quantum entanglement allows for the instantaneous transfer of information and energy between particles, making it a potential technology for wireless electricity transmission without the need for physical wires.
3. Is quantum entanglement currently being used for wireless electricity?
While there have been successful demonstrations of quantum entanglement, it is still a highly experimental concept and has not yet been fully implemented for wireless electricity transmission on a large scale. More research and development is needed before it can be widely used.
4. What are the potential benefits of using quantum entanglement for wireless electricity?
If fully realized, the use of quantum entanglement for wireless electricity could greatly reduce the need for physical infrastructure, making energy transmission more efficient and cost-effective. It could also potentially allow for faster and more secure communication networks.
5. Are there any challenges or limitations to using quantum entanglement for wireless electricity?
One of the main challenges is the difficulty of maintaining quantum entanglement over long distances and in real-world conditions. It also requires advanced technology and precise control of particles, making it a complex and expensive process. There are also concerns about potential interference and security issues with the use of quantum entanglement for wireless electricity transmission.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
24K
  • Quantum Physics
  • Quantum Physics
