Quantum Entanglement & Hybridization
In summary: And this is not license for you to make silly statements and proclaim "well it's only an approximation".On the Approximation Farm, some approximations are more equal than others.
LilandB
I'm conflicted about how hybridization and quantum entanglement can simultaneously co-exist. I'm first confused about how quantum entanglement was proven. I tried to read to proves (I'm in grade 11 and planning on writing an ee on this) and it flew relatively over my head. Hybridization states that some of the electrons will switch orbital direction in order to add more bonds (simplified). But because of that, wouldn't the other electron also switch direction because of quantum entanglement? Assuming that it's easy to replicate quantum entanglement (I doubt it is), we could just forcefully change the orbital direction of an electron and know that the other electron would be in the opposite direction. But this would allow for information to travel faster than the speed of light which is no Bueno (we could allow information to travel through like a boolean value).
Hybrid orbitals are not "real." They are approximations to actual wave functions that are useful to understand the bonding and geometry of molecules. In fact, placing individual electrons in orbitals is itself an approximation: the actual multi-electron wave function is a more complicated beast.
Also, hybridization is not a dynamic process. It concerns stationary states of the atom. Rearrangement of electrons during chemical reactions is again a much more complicated process.
To better understand entanglement, I suggest you take a look at @DrChinese's website on Bell's theorem.
Likes DrChinese, topsquark and PeroK
:welcome:
I suggest you need to take QM one step at a time. Nothing will make sense until you have a good grasp of the basics.
Likes vanhees71 and topsquark
They are as real as "actual" (??) wavefunctions. Schrödinger equation is a linear equation and linear combinations of solutions are perfectly valid solutions.
  • Skeptical
Likes weirdoguy
Actual many-electron wave functions are not product of single-electron wave functions. Saying that a given electron is in a sp3 orbital is an approximation of the actual electronic structure of an atom.
Likes vanhees71
This is one of the cases "chemistry vs. physics" approach sounds different. The word "actual" means nothing to me. All we do is try to explain a complex reality with some models. Whether it is Schrödinger or Dirac eq or LCAO, etc... In this sense every explanation is an approximation.
  • Skeptical
  • Sad
Likes PeroK and weirdoguy
And this is not license for you to make silly statements and proclaim "well it's only an approximation". On the Approximation Farm, some approximations are more equal than others.
Unfortunately they are not perfectly valid solutions to the Hamiltonian in question. For instance the electrons carry charge, and therefore directly interact.
Likes PeroK
There is no "chemistry vs. physics" in QT. Chemistry is a specialization of physics. There cannot be any contradiction between physics and chemistry. Both are exact natural sciences!
FAQ: Quantum Entanglement & Hybridization
What is quantum entanglement?
Quantum entanglement is a physical phenomenon where pairs or groups of particles become interconnected in such a way that the quantum state of each particle cannot be described independently of the state of the others, even when the particles are separated by large distances. This means that the measurement of one particle's properties instantly influences the properties of the other entangled particles, regardless of the distance between them.
How does quantum entanglement differ from classical correlation?
Quantum entanglement differs from classical correlation in that it involves a deeper level of connectivity between particles. In classical correlation, the properties of particles are correlated in a predictable way based on their shared history or initial conditions. In quantum entanglement, however, the particles are linked in such a way that their quantum states are dependent on each other, leading to correlations that cannot be explained by classical physics. This phenomenon is often described as "spooky action at a distance," a term coined by Albert Einstein.
What is hybridization in the context of quantum systems?
In quantum systems, hybridization refers to the process where atomic orbitals mix to form new hybrid orbitals. This concept is often used in quantum chemistry to describe the bonding in molecules. Hybridization helps explain the shape and bonding properties of molecules by combining the characteristics of different atomic orbitals, such as s and p orbitals, to form hybrid orbitals like sp, sp2, and sp3. These hybrid orbitals have different geometries and energy levels compared to the original atomic orbitals.
Can quantum entanglement be used for communication?
Quantum entanglement itself cannot be used for faster-than-light communication because it does not transmit information in the traditional sense. While the state of one entangled particle instantly affects the state of the other, this change cannot be controlled to send a specific message. However, entanglement is a crucial resource for quantum communication protocols, such as quantum teleportation and quantum key distribution, which can enhance the security and efficiency of communication systems.
What are the practical applications of quantum entanglement and hybridization?
Quantum entanglement and hybridization have several practical applications in various fields. In quantum computing, entanglement is used to create qubits that can perform complex calculations more efficiently than classical bits. Quantum entanglement is also essential for quantum cryptography, which provides secure communication channels. Hybridization is important in understanding the bonding and properties of molecules in chemistry and materials science, leading to the development of new materials and drugs. Additionally, both concepts are being explored for their potential in developing advanced technologies such as quantum sensors and quantum networks.
