Quantum field theory in a fractal universe (Calcagni)
In summary, Calcagni proposes a power-counting renormalizable field theory in a fractal spacetime, flowing from a 2-dimensional ultraviolet regime to a D-dimensional infrared limit. He discusses the properties of a scalar field model, including its interaction with the gravitational sector, and mentions the implications for the early universe. Calcagni has recently joined Hermann Nicolai's research outfit at Golm and has published related papers in string theory, loop quantum gravity, and non-commutative geometry. He also compiled a shorter review of his approach, accepted for publication in Phys. Rev. Lett., which is strongly related to the scaling of the spectral dimension in various approaches to quantum gravity.
marcus
Dearly Missed
24,775
792
At least one of us at this discussion board has expressed an interest in fractal modeling of spacetime, or of dynamics.*
This paper by Calcagni may be suggestive of what form such an approach could take.
http://arxiv.org/abs/1001.0571
Quantum field theory, gravity and cosmology in a fractal universe
Gianluca Calcagni
39 pages, 4 figures
(Submitted on 4 Jan 2010)
"We propose a model for a power-counting renormalizable field theory living in a fractal spacetime. The action is Lorentz covariant and equipped with a Stieltjes measure. The system flows, even in a classical sense, from an ultraviolet regime where spacetime has Hausdorff dimension 2 to an infrared limit coinciding with a standard D-dimensional field theory. We discuss the properties of a scalar field model at classical and quantum level. Classically, the field lives on a fractal which exchanges energy-momentum with the bulk of integer topological dimension D. Although an observer experiences dissipation, the total energy-momentum is conserved. The field spectrum is a continuum of massive modes. The gravitational sector and Einstein equations are discussed in detail, also on cosmological backgrounds. We find ultraviolet cosmological solutions and comment on their implications for the early universe."
Until recently Calcagni was at Ashtekar's Institute for Gravitation and the Cosmos (IGC) at Penn State. He has published papers in both string and LQG, as well as in other areas. In late 2009 he appears to have joined Hermann Nicolai's research outfit at Golm, the Albert Einstein Institute.
*Here is a related PF blog entry:
https://www.physicsforums.com/blog.php?b=1213
It might be of interest that Calcagni recently compiled a shorter review of his approach, accepted for Phys. Rev. Lett.:
http://arxiv.org/PS_cache/arxiv/pdf/0912/0912.3142v3.pdf
It is strongly related to and inspired by the scaling of the spectral dimension in various approaches, see e.g. the review by Carlip
http://arxiv.org/PS_cache/arxiv/pdf/0909/0909.3329v1.pdf.
or the case of NCG (not in the sense of Connes' approach):
http://arxiv.org/PS_cache/arxiv/pdf/0912/0912.0220v3.pdf
Also it might be worthwile to remember the thread about Carlips paper,
https://www.physicsforums.com/showthread.php?t=323417.
I like his approach because he basically turns the logic of the above papers upside down to obtain new insights. The scaling dimension is likely to tell us something about the UV behaviour of gravity because it is a property shared by almost all approaches to QG.
Related to Quantum field theory in a fractal universe (Calcagni)
1. What is quantum field theory in a fractal universe?
Quantum field theory in a fractal universe is a theoretical framework that combines the principles of quantum mechanics and fractal geometry to explain the behavior of particles and fields in the universe. It suggests that the fabric of space-time itself is fractal in nature and that particles interact with each other through quantum fields.
2. How does fractal geometry play a role in this theory?
Fractal geometry is used to describe the structure of space-time at the smallest scales. The concept of self-similarity, where the same patterns are repeated at different scales, is applied to the behavior of particles and fields. This helps to explain the non-local and chaotic behavior observed in quantum systems.
3. What are some potential applications of this theory?
One potential application is in understanding the behavior of particles in extreme environments, such as black holes or the early universe. It could also help to unify quantum mechanics and general relativity, two currently incompatible theories that govern the behavior of the smallest and largest scales of the universe.
4. How does this theory differ from traditional quantum field theory?
Traditional quantum field theory is based on the assumption that space-time is smooth and continuous. In contrast, quantum field theory in a fractal universe considers space-time to be fractal and non-local, leading to different predictions and explanations for certain phenomena.
5. Is there any evidence to support this theory?
At this time, there is no direct evidence to support quantum field theory in a fractal universe. However, some of its predictions, such as the existence of a minimum measurable unit of space-time, are consistent with observations from particle accelerators. Further research and experimentation are needed to fully test and validate this theory.
  • Beyond the Standard Models
