Quantum Field Theory: Stationary Point of the Effective Action
In summary, the effective action, which obeys the equation \frac{\delta \Gamma[\varphi]}{\delta \varphi(x)}=J(x), has a stationary point at \varphi_0 where \frac{\delta \Gamma[\varphi_0]}{\delta \varphi(x)}=0, corresponding to the vacuum expectation value. This can be expressed as a power-series expansion for a functional, with \Gamma_n representing functional derivatives of \Gamma evaluated at \varphi=0. However, the whole expansion should be made around \varphi=\varphi_0, not \varphi=0.
latentcorpse
1,444
We have the effective action which obeys [itex]\frac{\delta \Gamma[\varphi]}{\delta \varphi(x)}=J(x)[/itex] where and we are told the stationary point, [itex]\varphi_0[/itex], of this action, [itex]\frac{\delta \Gamma[\varphi_0]}{\delta \varphi(x)}=0[/itex], corresponds to the vacuum expectation value.
(This is out of my notes - there is a discussion around p380 of Peskin & Schroeder on this although it goes a bit more in depth than my notes...)
Anyway, on the next page, he just says that we can write
[itex]\Gamma[\varphi]=i \displaystyle\sum_{n=0}^\infty \frac{1}{n!} \int d^dx_1 \dots \int d^dx_n \varphi(x_1) \dots \varphi(x_n) \Gamma_n (x_1, \dots , x_n)[/itex]
Can anybody explain to me where this formula has come from? And what is [itex]\Gamma_n[/itex]? He hasn't defined that either.
Thanks.
Up to the factor of [tex]i[/tex] this is just a power-series expansion for a functional. [tex]\Gamma_n[/tex] can be expressed in terms of functional derivatives of [tex]\Gamma[/tex] evaluated at [tex]\phi = 0[/tex] as written.
Ok. So I found that [itex]\Gamma_n = - i \frac{\delta^n \Gamma [ \varphi ] }{ \delta \varphi(x_1) \dots \delta \varphi(x_n)}|_{\varphi=0}[/itex]
But shouldn't this be evaluated at [itex]\varhpi = \varphi_0[/itex] i.e. the minimum of the effective potential?
The whole expansion should be made around [tex]\varphi=\varphi_0[/tex]. Your reference is either being sloppy or you've left out information.
Quantum Field Theory (QFT) is a mathematical framework used to describe the behavior of particles and fields at a quantum level. In QFT, the effective action is a mathematical object that encodes the dynamics of the fields in a given system. It is a functional of the fields, denoted by \Gamma[\varphi], and is defined as the Legendre transform of the generator of connected Green's functions.
The effective action satisfies the equation \frac{\delta \Gamma[\varphi]}{\delta \varphi(x)}=J(x), where J(x) is the external source term. This equation is known as the Schwinger-Dyson equation and it is a fundamental equation in QFT. It relates the behavior of the fields with the external sources.
The stationary point of the effective action, \varphi_0, is a special field configuration that satisfies the equation \frac{\delta \Gamma[\varphi_0]}{\delta \varphi(x)}=0. This means that the effective action is minimized at this point, and it corresponds to the vacuum expectation value (VEV) of the fields.
In order to calculate the effective action, we can use a perturbative expansion in terms of the fields. This is where the formula given in your notes comes from. The term \Gamma_n (x_1, \dots , x_n) represents the n-point connected Green's function, which is a function of the field variables at different points in space and time. The summation over n in the formula indicates that we are considering all possible combinations of n fields. The factor of \frac{1}{n!} ensures that we do not double count the same terms in the expansion.
In summary, the formula given in your notes is a perturbative expansion of the effective action in terms of the fields, and \Gamma_n represents the n-point connected Green's function.
FAQ: Quantum Field Theory: Stationary Point of the Effective Action
What is a stationary point in Quantum Field Theory?
A stationary point in Quantum Field Theory refers to a point in the space of all possible field configurations where the effective action is at a minimum or maximum. This means that any small variations in the field configurations around this point do not result in a change in the effective action.
How is the stationary point of the effective action related to the path integral in Quantum Field Theory?
The stationary point of the effective action is a crucial concept in the path integral formulation of Quantum Field Theory. It corresponds to the classical field configuration that dominates the path integral, and the fluctuations around this configuration account for the quantum effects.
What is the significance of the stationary point of the effective action in Quantum Field Theory?
The stationary point of the effective action is important because it allows for the calculation of physical observables in Quantum Field Theory. By expanding the action around this point, one can obtain a perturbative series that can be used to calculate the probabilities of different field configurations and ultimately, the behavior of the system.
Can there be multiple stationary points in Quantum Field Theory?
Yes, in general, there can be multiple stationary points in Quantum Field Theory. This is because the effective action is a function of the field configuration, and there can be multiple configurations that minimize or maximize it. However, in certain cases, such as in supersymmetric theories, there can be only one stationary point.
How does the stationary point of the effective action relate to symmetry breaking in Quantum Field Theory?
In some cases, the presence of multiple stationary points in Quantum Field Theory can lead to symmetry breaking. This occurs when one of the stationary points corresponds to a lower energy state compared to the others, and the system spontaneously chooses this state, breaking the symmetry of the theory. This is a crucial mechanism in understanding the behavior of particles and forces in the universe.
