Quantum fluctuations at critical point
In summary, a quantum second order transition has a quantum critical point where the quantum fluctuations driving the transition become scale invariant in space and time. This means that the correlations do not have a single length scale, but instead follow a power law with the same exponent. The concept of "large thermal fluctuations" is often used interchangeably with "diverging correlation length", and at the critical point, there are fluctuations on all length scales. However, in classical statistical mechanics, it is the thermal fluctuations that drive the transition, and at the critical point, the correlation length and other quantities diverge. This can be seen in the Ising model, where above the critical point, there are fluctuations on all length scales.
AcidRainLiTE
90
According to wikipedia:
"As for a classical second order transition, a quantum second order transition has a quantum critical point (QCP) where the quantum fluctuations driving the transition diverge and become scale invariant in space and time."
I am confused about what this means. Why do the fluctuations diverge? The quantum fluctuations become infinitely large at the critical point? That does not seem correct. Can someone clarify for me?
Infinitely large is just shorthand for scale invariant. If the correlations decay exponentially, there is a finite length scale set by the exponential decay. There is no such single length scale for scale invariant correlations, and so the correlation length is said to diverge.
Ok, that makes sense. It brings up another question for me though. Why do people call a system "scale invariant" when the correlation length diverges? The correlations still drop off (with distance) via a power law, right? So if I zoom out they will change, and so don't seem "invariant".
If you zoom out, they will change, but only by an overall constant factor, so the correlations will still obey a power law with the same exponent
Interpreting "diverging thermal fluctuations" as equivalent to "infinite correlation length" doesn't make sense with another article I am reading which says:
"What drives the correlation length to infinity are thermal fluctuations, which become very large close to criticality."
If large "large thermal fluctuations" is a synonym for diverging correlation length, than the above sentence is a tautology, simply stating "What drives the correlation length to infinity is the diverging correlation length." Instead, it seems to be saying that the two concepts are distinct, and one causes the other (large thermal fluctuations causing the diverging correlation length)
Wouldn't large thermal fluctuations do exactly the opposite? That is, wouldn't thermal fluctuations tend to increase the randomness in the system, not order it.
I think the sentence is a tautology. My understanding is that in classical statistical mechanics, it is the thermal fluctuations that do anything by definition since we are using the canonical ensemble. Then in particular systems, there is a critical point at which the correlation length and other quantities diverge.
Here is a picture of the Ising model below, at and above criticality: http://www.nature.com/nphys/journal/v6/n10/box/nphys1803_BX1.html (just look at the picture, ignore the commentary about the brain, which I don't know whether is correct). Another example is
In some sense there clearly are "large fluctuations" at criticality, corresponding to there being "fluctuations on all length scales".
Related to Quantum fluctuations at critical point
1. What are quantum fluctuations at a critical point?
Quantum fluctuations at a critical point refer to the unpredictable and random fluctuations of energy that occur at the boundary between two different phases of matter. These fluctuations are a result of the quantum mechanical nature of particles at a critical point.
2. How do quantum fluctuations affect a critical point?
Quantum fluctuations can have a significant impact on the properties of a system at a critical point. They can lead to changes in the critical temperature, alter the scaling behavior, and affect the phase transition itself.
3. What role do quantum fluctuations play in phase transitions?
Quantum fluctuations are crucial in understanding the behavior of systems at a critical point. They can drive and influence phase transitions, leading to changes in properties such as magnetization and conductivity.
4. Can quantum fluctuations be observed experimentally?
Yes, quantum fluctuations have been observed and studied in various systems through experiments such as neutron scattering, NMR spectroscopy, and superconducting quantum interference devices (SQUIDs).
5. How are quantum fluctuations related to the concept of criticality?
Quantum fluctuations play a significant role in the concept of criticality, as they are responsible for the critical behavior at a phase transition. They are also closely linked to the concept of universality, which describes the similarity of critical behavior in different systems.
