Quantum Gravity and Specific GR Tests
In summary, the discussion revolved around the state of quantum gravity research and whether the prediction for the precession of Mercury's perihelion is a fundamental test for all theories, including quantum gravity. It was noted that while this may make sense for cosmological extensions of GR, it may not apply to all quantum gravity theories that have not yet established their connection to GR. The question of how to compute the precession of Mercury's perihelion using specific theories like CDT or spin-foam LQG was also raised, with the conclusion that the only current option is semiclassical quantum gravity. It was also mentioned that the recent inclusion of fermions in LQG is still preliminary and
  • #36
Right. It is important to distinguish between those two different facets or aspects. There is the philosophical analysis of concepts: what is space what is time what is the operational meaning of distance or area or dimension or the operational meaning of a loop being contractible to a point. Einstein was good at that, how does an observer actually measure a distance to something--he sends a flash of light, OK let's look at the light...
So there is the conceptual analyst side (the "philosopher") and also the physical theorist side---the person who constructs and explores mathematical models comparable to our experience of nature.
I suppose that C.R. is not so unusual in having these two sides, and in having the analysis of concepts serve as an heuristic guide to the mathematical modeling. Many other good theoretical physicists must, like him, be asking questions like "what does this mathematical object actually stand for?" and "how in principle might we determine if this condition is actually satisfied?"
Nice thing about empirical science is that if some philosophical investigation guides you heuristically to some physical theory, and then the theory turns out not to work, then you can realize the philosophy was wrong! At least I think you can. There's a way of discovering that some line of thought was on the wrong track---if you follow through rigorously on it.
One reason I think QG research is exciting to follow.
...*IF* it turns out that LQG really does reduce (at zero-th order in \hbar) to Regge theory then it doesn't really matter how and why the philosophy works --- we should indeed rebuild the philosophical understanding after the fact...
Philosophy and physics aid each other, sometimes essentially. Philosophy can guide innovative theory, as a kind of heuristic, and in turn get feedback from physics. If the physics works, it validates the concepts, but if the physics fails empirical test, then go back and re-work the philosophy. Didn't people around 1650-1750 call it "natural philosophy". Maybe they had the right idea.
  • #37
atyy said:
And how can Rovell's "relational" arguments in his QG book make sense if there is a background metric? Do you think Rovelli meant only no background 4D spacetime metric - ie. not everything is relational?
Did you think LQG researchers understand "background independence" to mean "no background 4D spacetime metric" or "no background metric"?
I was dissapointed by rovelli's reasoning on these points. IMHO he has undoubtedly several excellent points, but to make it short this is how I characterize his reasoning on relational thinking(and I don't like it):
Rovelli tries to argue that there is not objective background information at all. Each observer simply views everything from it's own subjective "context" - OK.
Also, there are no objective predetermined absolute relations between these contexts, the only way level them in any way is for two observes to interact/communicate - OK.
But as Rovelli's is not questioning or analysing QM as such, here he just assumes that the "communication" between two observers, somehow obey the Rules of Quantum Mechanics. This is where he lost me because QM also requires a background context. Not a metric background, but a encoding structure and system for computing expectations. But he also declared that this is as far as his anzats goes, and he simply didn't aim to revise QM or counting problematics, just put it in what he thinks is the right view.
> If Rovellian LQG's insistence that all physics should be relational means that there is no
> background metric, it is wrong. There can be a background metric which does not have
> the meaning of spacetime, so that the emergent classical spacetime is still dynamical.
I sort of agree, it could be any abstract information space metric. Information can be recoded, so as far as I'm concerned it's irrelevant to principles here which information carriers we talk about. Spacetime manifolds, theory manifolds are all information carriers.
So I think it doesn't end there. I think that ANY background information (metric or something else) that is assume absolute and eternal smells. Ie. I do not think that we can assume a observer invariant structure on any theory space itself.
I personally think the only reasonable conclusion is to accept that information evolves. Any attempt to cast in stone, theory spaces or background metrics or whatever are IMHO conceptually incoherent and thus misguiding if one is to have some respect for what I think is the core of science and inference. Because why would certain information carriers be excepted from the inference requirement? The only excuse I'm aware of is that the history is erased or overwritten and you just know where you are but not how you got there.
As I see it this must have implications also for the RG work. Somehow, I can't help but insist that theory space must be the one and same as what defines the population of observers in the universe. This IS the REAL theory space, isn't it?
/Fredrik
  • #38
Regarding what genneth and I were discussing, there is an interesting comment in http://arxiv.org/abs/1011.2149 . Spinfoams are being pushed in 3 different directions, and it is not clear how they are related (i) Rovellian spinfoams (ii) GFT (iii) KKL . This paper tries to see what relationship there might be between (i) and (iii): "The geometrical interpretation in terms of tetrahedra (and now polyhedra) has raised a lively discussion and it is sometimes unpalatable to the more canonical oriented part if the community. Part of this discussion is based on a misunderstanding. The precise claim ... truncated Hibert space has a classical limit ... naturally interpreted as describing a collection of polyhedra ... classical general relativity admits truncations ... where the geometry is discretized."
  • #39
Atyy, I went and looked through the Ding Han Rovelli paper and, on page 7, I found the passage you quoted. Is there a way I could use google or some other search to find a passage in the context of a given article? Sometimes that would be a real help, especially when you quote from longer papers and don't give a page. Tell how you do a keyword search within an article, if you know, please!
The passage on page 7 is interesting. Here is the paragraph in full:
==quote Ding Han Rovelli==
The geometrical interpretation in terms of tetrahedra (and now polyhedra) has raised a lively discussion and it is sometimes unpalatable to the more canonical-oriented part of the community. Part of this discussion is based on misunderstanding. The precise claim here is that if we take the diff--invariant Hilbert space of the theory and we truncate it to a finite graph (so that the observable algebra is also truncated), then the truncated Hilbert space (with its observables algebra) has a classical limit, and this classical limit can be naturally interpreted as describing a collection of polyhedra. This is well consistent with classical general relativity, because classical general relativity as well admits truncations where the geometry is discretized. Also, this is not inconsistent with the continuous picture for the same reason for which the fact that the truncation of Fock space to an n particle Hilbert space describes discrete particles, is not inconsistent with the fact that Fock space itself describes a (quantized) field.
==endquote==
I'm not sure what you mean by "Rovellian" spinfoams, since spinfoam formulation has changed so much since 2007.
I don't see any permanent barriers between what Rovelli is now doing and the KKL. (Lewandowski's version of spinfoam with vertex valence greater than 5). Just generalizing from less-general to more-general polyhedra.
My idea of Lqg is a gradual evolution---it is easier to see steady directions of progress than to specify exact location at any given moment.
Especially since so many people are working on it and so much has been happening lately.
But definitely yes! they are exploring the connection between what you call (i) and what you call (iii), just as you say. I would expect some kind of coming together there----likewise probably with GFT ---your item (ii).
Convergence has been a common theme in LQG research since 2007 and probably before---convergence of different lines of investigation, approaches---it is a good guess that the trend will continue. Convergence, after all, was what the original KKL paper was about.
  • #40
Here's part of an introductory overview of the Ding Han Rovelli results, from page one of their paper. I think it helps to understand:
==quote page 1 of "Generalized Spinfoams" http://arxiv.org/abs/1011.2149 ==
The relation with LQG, however, is limited by the fact that the simplicial-spinfoam boundary states include only four-valent spin networks. This is a drastic reduction of the LQG state space. In [20], Kaminski, Kisielowski, and Lewandowski (KKL) have considered a generaliza- tion of the spinfoam formalism to spin networks of arbi- trary valence, and have constructed a corresponding vertex amplitude. This generalization provides truncated transition amplitudes between any two LQG states [1], thus correcting the limitation of the relation between the model and LQG. This generalization, on the other hand, gives rise to several questions. The KKL vertex is obtained via a “natural” mathematical generalization of the simplicial Euclidean vertex amplitude. Is the resulting vertex amplitude still related to constrained BF theory (and therefore to GR)? In particular, do KKL states satisfy the simplicity constraint? Can we associate to these states a geometrical interpretation similar to the one of the simplicial case? Can the construction be extended to the physically relevant Lorentzian case?
Here we answer several of these questions. We show that it is possible to start form a discretization of BF theory on a general 2-cell complex, and impose the same boundary constraints that one impose in the simplicial case (simplicity and closure). Remarkably, on the one hand, they reduce the BF vertex amplitude to a (generalization of) the KKL vertex amplitude, in the Euclidean case studied by KKL. On the other hand, a theorem by Minkowski [21] garantees that these constraints are precisely those needed to equip the classical limit of each truncation of the boundary state space to a finite graph, with a geometrical interpretation, which turns out to be in terms of polyedra [22].
==endquote==
