Quantum harmonic oscillator coupled to electric potential
In summary: To quantise the motion of the light charge, we need to use the potential energy of the system in the Schrodinger equation to obtain the wavefunctions and the energy spectrum of the theory. Therefore, the first objective is to find the potential energy of the theory.There are two interactions in the theory. The first is due to the spring which connects the object with charge ##Q## and the object with charge ##-q##. The potential energy due to the spring is ##\frac{1}{2}kx^{2}##.The second interaction is due to the charges of the objects. Now, Gauss's law in one dimension gives the electric field as##
rock_pepper_scissors
In ##1+1##-dimensional spacetime, two objects, each with charge ##Q##, are fixed and separated by a distance ##d##.
(a) A light object of mass ##m## and charge ##-q## is attached to one of the massive objects via a spring of spring constant ##k##. Quantise the motion of the light charge and obtain the ground state energies and wavefunctions. What approximations did you use, if any?
(b) The same light object of mass ##m## and charge ##-q## is now attached to both the massive objects via springs of spring constants ##k_1## and and ##k_2##. Repeat the analysis in (a) for this new system.
(a) To quantise the motion of the light charge, we need to use the potential energy of the system in the Schrodinger equation to obtain the wavefunctions and the energy spectrum of the theory. Therefore, the first objective is to find the potential energy of the theory.
##\int \vec{E}\ \cdot{d\vec{A}}=\frac{-q}{\epsilon_{0}} \implies 2E = -\frac{q}{\epsilon_{0}} \implies E = -\frac{q}{2\epsilon_{0}}##,
since the electric field in integrated over the two endpoints of the Gaussian "surface" on the one spatial dimension. Letting the distance from the equilibrium position of the charge ##-q## to the fixed position of one of the charges ##Q## be ##x_{eq}## and the displacement (from the equilibrium position) of the charge ##-q## in the direction of the other charge ##Q## be ##x##, the potential energy due to the object of charge ##-q## is
##-\frac{qQ}{2\epsilon_{0}}[(w_{eq}+x)+(d-x-x_{eq})]=-\frac{qQd}{2\epsilon_{0}}##.
Therefore, the electric potential energy is a constant and can be ignored.
Am I correct in my analysis so far?
Check by superposition... ie sketch the component potentials and add them graphically.
Lets see if I follow:
Arrange coordinates so that charge Q is at the origin and another charge Q is at x=d, let -q (mass m) be attached to the origin.
You want to solve: ##\big[-\frac{\hbar^2}{2m}\frac{d^2}{dx^2} + V(x)\big]\psi(x) = E\psi(x)##
...using the known results for the forces of point charges, and for a spring, then the net force on the mobile charge is given by:
$$-\frac{d}{dx}V(x)= k(x-x_0) + \frac{Qq}{4\pi\epsilon_0(d-x)^2} - \frac{Qq}{4\pi\epsilon_0x^2}$$
... where ##x_0## is the un-stretched length of the spring, and I am assuming that the mobile mass m is always between the two fixed charges (so 0<x<d). Notice that the description also works if the mobile mass is to the left or right of the fixed charges - is it free to pass through the position of a fixed charge?
This 1st order DE can be solved to get V(x)... or you could apply the superposition principle to the known component potentials. I have a feeling the point of the exercise is to get you to think about this.
Whichever the way, ##x_0## is not given.
It is possible that they want ##x_0=0## ... or maybe ##x_0=d/2## to center the imposed HO potential.
Either of these make sense considering part (b) would shift the equilibrium position off-center according to the ratio of ##k_1## and ##k_2##... though, if ##x_0=d/2## was intended, I'd have thought part (a) would also use two springs. OTOH: if ##x_0=0## were intended, then the wording is still off.
Note: If ##x_0=d/2## and d is quite big, then the electric potential about the equilibrium is very flat, and you can use perturbation theory to modify the HO potential ground state. If you have just covered perturbation theory, this is a likely focus for the exercise.
This is in ##1+1##-dimensional space, so Coulomb's law in three dimensions does not apply.
My application of Gauss's law in ##1+1##-dimensional spacetime is the correct way to go.
Oh I see, this is some abstract topology course so 1+1D means exactly that and is not supposed to be taken to mean you are constraining motion to 1D of space.
The rest of the commentary still stands.
You could, then, check from the electric potential in 1D.
Related to Quantum harmonic oscillator coupled to electric potential
1. What is a quantum harmonic oscillator?
A quantum harmonic oscillator is a theoretical model used in quantum mechanics to describe the behavior of a particle that is subject to a restoring force that is proportional to its displacement from a fixed point. It is a simplified version of a real-life oscillator, such as a mass attached to a spring, and is often used to study the behavior of atoms, molecules, and other small particles.
2. What is an electric potential?
An electric potential is a scalar quantity that describes the amount of work needed to move a unit charge from one point to another in an electric field. It is often represented by the symbol V and is measured in volts (V). In the context of a quantum harmonic oscillator, an electric potential can be used to describe the interaction between the oscillator and an external electric field.
3. How are the quantum harmonic oscillator and electric potential coupled?
In the context of quantum mechanics, coupling refers to the interaction between two systems. In the case of a quantum harmonic oscillator coupled to an electric potential, the oscillator is affected by the presence of the electric field, and the electric field is affected by the motion of the oscillator. This coupling can result in changes to the energy levels and behavior of the system.
4. What are the applications of studying a quantum harmonic oscillator coupled to electric potential?
Studying the behavior of a quantum harmonic oscillator coupled to an electric potential can help us understand the behavior of atoms, molecules, and other small particles in the presence of external electric fields. This has applications in various fields, such as chemistry, material science, and quantum computing.
5. What is the significance of the energy levels in a quantum harmonic oscillator coupled to electric potential?
The energy levels in a quantum harmonic oscillator coupled to electric potential play a crucial role in determining the behavior and stability of the system. The energy levels are quantized, meaning they can only take on certain discrete values, which can have significant implications for the behavior of the system. These energy levels can also be manipulated by changing the strength of the electric potential, leading to potential applications in controlling and manipulating quantum systems.
