Quantum Harmonic Oscillator (QHO)
In summary: Especially if you want to understand the more subtle details of quantum harmonic oscillator. I would recommend you to read one of the more elementary books on QM, such as this one:"Quantum Mechanics: A Concise Introduction" by John BaezIn summary, the author recommends that a more elementary book be read on QM before attempting to study Griffiths' book.
Abdul Quader
1. I have been trying to plot wavefunctions of QHO for different states with potential energy function using excel. I followed Griffith's Quantum Mechanics, 2nd edition. I got the nature but they have same reference level. Basically I tried to draw fig2.7a (the first one) and got like the second picture.
2. Why does quantum harmonic oscillator need to be solved around singular points for which frobenius technique is used?
3. What is reason behind the fact that the coefficient of highest power should be equal to 2^n to be a hermite polynomial? (Ajay Ghatak, Fundamental Theories of Physics, page 166, article 7.3)
4. Why is one of the even and odd series forced to rather not making mathematically zero in case of getting hermite polynomial? (Ajay Ghatak, Fundamental Theories of Physics, page 166, article 7.3)
Ad 1) You just have to shift each wave function up by a certain amount to get the figure as in the textbook (which I always found a very misleading way to plot, but that may be personal).
Ad 2) The Frobenius method is quite cumbersome for the harmonic oscillator. The point is that you have to find the square-integrable solutions of the energy-eigenvalue equation (aka time-independent Schrödinger equation). The singular points are at infinity, and you usually start with the asymptotic behavior of the equation leading to the ansatz ##\psi(x)=\chi(x) \exp(-a x^2)## (with ##a## the appropriate constant you get from the differential equation). Then you use the power-series ansatz to solve the differential equation for ##\chi##. As it turns out, these series must be finite, i.e., a polynom to get square-integrable solutions only, and the demand that the series ends at a given power leads to the discrete energy-eigenvalues of the harmonic oscillator Hamiltonian, ##E_{n}=(2n+1) \hbar \omega/2##, ##n \in\{0,1,2,\ldots \}##.
Ad 3) The normalization is arbitrary and usually chosen by convenience or just by tradition. For the Hermite polynomials it's just convenient, because then you can define them as (physicists' convention)
$$\mathrm{H}_n(x)=(-1)^n \exp x^2 \mathrm{d}_x^n \exp(-x^2).$$
Ad 4) You just want to find all eigenvalues and the corresponding eigenfunctions of the Hamiltonian. Since the Hamiltonian is invariant under space reflections, the eigenfunctions can be chosen to be even or odd (i.e., you can define a set of common eigenfunctions of energy and parity). To know this beforehand, facilitates the finding of the eigenvalues with the Frobenius method considerable. Since for the simple harmonic oscillator the energy eigenvalues are non-degenerate the eigenfunctions are unique for each eigenvalue, and thus by themselves necessarily a parity eigenstate. They are alternately even and odd under parity, with ##\psi_n(-x)=(-1)^n \psi(x)##.
A much more convenient method to solve for the harmonic oscillator is to first solve it in a completely algebraic approach, introducing ladder operators. This also immediately leads to the above given formula for the Hermite polynomials by iteration.
Likes Mentz114
Thanks for the reply. Some of I understand and some of I don't. Can you suggest some text to study Hermite polynomial leading to the answers?
The treatment I have in mind can be found in the textbook by Sakurai:
J. J. Sakurai, S. F. Tuan, Modern Quantum Mechanics, Revised Edition, Addison-Wesley (1993)
I guess that you also find it in the later edition with Napolitano as co-author, but I cannot check this right now.
Thanks. i didn't check this text although I have this. Since I was going through Griffith's rigorously and tried to stick to it. I will check it now.
Well, I've the impression that Griffiths's book on QM is not the best to study from.
Related to Quantum Harmonic Oscillator (QHO)
1. What is a Quantum Harmonic Oscillator (QHO)?
A Quantum Harmonic Oscillator (QHO) is a fundamental model used in quantum mechanics to describe the behavior of a system that has both potential and kinetic energy, such as a vibrating molecule or an electron in an atom. It is a simplified version of the classical harmonic oscillator, where the energy levels are quantized and can only take on discrete values.
2. How does a QHO differ from a classical harmonic oscillator?
In a classical harmonic oscillator, the energy levels are continuous and can take on any value, while in a QHO the energy levels are quantized and can only take on discrete values. Additionally, the classical harmonic oscillator follows Newton's laws of motion, while the QHO follows the principles of quantum mechanics, which allows for the possibility of the oscillator existing in multiple energy states at the same time.
3. What is the significance of the ground state in a QHO?
The ground state in a QHO is the lowest energy state that the oscillator can exist in. It has the lowest energy and the highest probability of being observed. This state is important because all other energy levels and states can be described in terms of the ground state, and it serves as a reference point for measuring the energy of the oscillator.
4. How is the energy of a QHO calculated?
The energy of a QHO is calculated using the equation E_n = (n + 1/2)ħω, where n is the energy level, ħ is the reduced Planck's constant, and ω is the angular frequency of the oscillator. This equation shows that the energy levels of a QHO are quantized and depend on both the energy level and the frequency of the oscillator.
5. What are some real-world applications of the QHO model?
The QHO model has many real-world applications, such as in studying the vibrational modes of molecules in chemistry, understanding the behavior of electrons in atoms, and developing technologies like lasers and transistors. It is also used in fields like quantum computing and quantum cryptography, where the principles of quantum mechanics are utilized for advanced technologies.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
