Quantum Harmonic Oscillator with Additional Potential
Mr_Allod
Apply and additional potential ##V'(x) = \alpha x## to the standard Hamiltonian of a harmonic oscillator. Find the solutions to the Schrodinger equation.
Harmonic Oscillator Hamiltonian: ##H = - \frac \hbar {2m} \frac {d^2}{dx^2}\psi + \frac {m\omega^2 x^2}{2}##
Hello there, I am trying to solve the above and I'm thinking that the solutions will be Hermite polynomials multiplied by a decaying exponential, much like the standard harmonic oscillator problem. The new Hamiltonian would be like so:
$$H = - \frac \hbar {2m} \frac {d^2}{dx^2}\psi + \frac {m\omega^2 x^2}{2} + \alpha x$$
Normally one would make the substitutions:
$$y = \sqrt{\frac {m\omega}{\hbar}}$$
$$\epsilon = \frac {2E}{\hbar\omega}$$
This would produce a solvable dimensionless differential equation:
$$\frac {d^2}{dy^2}\psi + (\epsilon-y^2)\psi = 0$$
Now I'm having trouble finding the correct substitution to make to reduce the new problem to a dimensionless one like above. I would appreciate it if someone could give me some suggestions, thank you!
Rather think about the Hamiltonian a bit first.
Hint: Think about the classical case. What's the change of the potential due to the additional linear piece? Equivalently you can think about, what it changes for the force acting on the particle and how does it affect the solutions of the classical equations of motion?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
