bayan
- 203
Assume that a typical electron in a piece of metallic sodium has energy [itex]- E_{0}[/itex] compared to a free electron, where [itex]E_{0}[/itex] is the 2.7 eV work function of sodium.
At what distance beyond the surface of the metal is the electron's probability density 20% of its value at the surface?
[itex]η=\frac{\hbar}{\sqrt{2m( U_{0} - E)}}[/itex]
[itex]ψ_{(x)}=ψ_{edge} e^{-(x-L)/η}[/itex]
I've assumed the surface of the sodium metal is the barrier. I have also assumed [itex]U_{0}-E= 2.7eV[/itex]Given that the probability density must be 20% at a distance from the surface I've used the following method to get my answer and want to check if my assumptions/work are correct.
I've worked [itex]η≈1.19*10^{-10}m[/itex]
Because I need probability density to be 20% of what it would be at the barrier I've done the following;
[itex]0.2=|ψ|^{2}[/itex]
[itex]ψ_{(x)}=ψ_{edge} e^{-(x-L)/η}[/itex] ∴ [itex]|ψ_{(x)}|^{2}=(ψ_{edge} e^{-(x-L)/η})^{2}[/itex]
[itex]\sqrt{0.2}=ψ_{edge} e^{-(x-L)/η}[/itex]
Given x value is going to be x value of barrier + zη
[itex]0.447=ψ_{edge} e^{-(zη)/η}[/itex]
[itex]ln 0.447 =ψ_{edge} -(zη)/η[/itex]
[itex]-0.805=ψ_{edge} -(zη)/η[/itex]
[itex]-0.805=-z[/itex]
[itex]z=0.805[/itex]
Would the answer be 0.805η (0.096 nm)
Any help would be greatly appreciated :)
