Quantum mechanical model of an atom
In summary: has gone from being an electron in an unspecified orbital to being an electron in the specified orbital.
Frigus
337
160
We say that principal quantum number tells us the average distance from the nucleus, so the sub shells of some principal quantum number say 3 has 3 sub Shells 0,1,2 and in 3p sub shell their will probability of finding the electron near the nucleus which doesn't mean electron will find in region of 2p orbital.
How can we say that there are different orbitals in an electron as the smaller orbital for example 2p will come in the region of 3p.
Which part of the calculations are unclear to you ?
Does it worry you that the probability distributions for the distance to the nucleus show overlap ?
Because which orbital the electron is in is not determined by where it is. The electron doesn't even have a definite position to begin with. Which orbital the electron is in is determined by its energy and angular momentum.
Please tell me where I am wrong,I think like
That when we say there are two orbitals 1s and 2s and both have spherical shape and the average distance of 2s orbital is larger so doesn't it means that the smaller s orbital will lie in the region of larger s orbital. In my mind their is picture of atom where two orbitals 1s and 2s lie like a ball(of course it is not but it is the region where we can find the electrons) so the the smaller ball region should lie in the volume of smaller if this is the case then both smaller and larger 1s and 2s orbitals share some volume then if we found an electron in the smaller 1s orbital then it is also present in the larger s orbital so then how can we say in which orbital is the electron present and like that their are many numbers of orbitals in an atom doesn't their region overlap with one another.
So sir it means that if the election is found near the nucleus then it can be in the larger p orbital but if we find an electron near the nucleus then shouldn't it have less energy than how can we say that it can be in larger 3p orbital as electron energy is less.
This is not correct. The spatial parts of the wave functions for the orbitals do overlap. Again, which orbital the electron is in is not determined by position. The orbitals are different because they have different combinations of energy and angular momentum, not because they occupy different portions of the space around the nucleus.
This is not correct. Go back and read what I've already written.
If all we know is the electron's position, then yes, it could be in any orbital whose spatial wave function gives a nonzero probability for the electron being found in that position.
But in practice we never find electrons in atoms at particular positions. We don't measure their positions. They don't even have definite positions. We measure their energies and their angular momenta. And that tells us which orbital they are in.
No. The electron is not a classical particle. You can't relate its energy and its position the way you could for a classical particle in a classical orbit.
Likes BvU
Thanks sir 😊
More precisely, before we measured its position it could have been in any orbital whose spatial wave function gives a nonzero probability for the electron being found in that position.
But after we measure the electron's position, it is no longer in the same state as it was before. It is now in a state localized at that position we just measured, and that state is not an orbital at all. It's not a state with definite energy or definite angular momentum. It's a different kind of state altogether. The electron isn't even bound to the atom any more--basically the process of measuring its position will have knocked it out of its previous bound state.
Once again, quantum mechanics does not work like classical physics, and the electron is not a classical particle.
Likes mattt
Related to Quantum mechanical model of an atom
1. What is the quantum mechanical model of an atom?
The quantum mechanical model of an atom is a mathematical model that describes the behavior and properties of atoms at the atomic level. It incorporates the principles of quantum mechanics to explain the distribution of electrons in an atom's energy levels.
2. How does the quantum mechanical model differ from the Bohr model?
The Bohr model of the atom is a simplified version that only considers the electrons in specific energy levels, while the quantum mechanical model takes into account the wave-like behavior of electrons and their uncertain position and momentum.
3. What is the significance of the Schrödinger equation in the quantum mechanical model?
The Schrödinger equation is the fundamental equation of the quantum mechanical model. It describes the behavior of electrons in an atom as a wave function, which gives the probability of finding an electron at a certain position and time.
4. How does the quantum mechanical model explain the properties of elements?
The quantum mechanical model explains the properties of elements by describing the arrangement of electrons in an atom's energy levels. The number of electrons in an atom's outermost energy level determines its chemical properties, such as reactivity and bonding behavior.
5. What are the limitations of the quantum mechanical model?
The quantum mechanical model is limited in its ability to accurately predict the exact position and momentum of an electron at any given time. It also does not fully explain the phenomenon of electron spin and the magnetic properties of atoms.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
