Quantum Mechanics, Cart filling, + friction as it moves
In summary, the conversation discusses a scenario in which a cart is rolling down a track with an initial velocity and experiences an increase in mass due to falling rain. The cart also experiences a frictional force caused by the rain on the track. The conversation includes a request for the equation of motion for this scenario, a solution to the resulting differential equation, and a plot of the velocity of the cart over time. The given parameters for this scenario are initial velocity (vo) of 2 m/s, initial mass (mo) of 100 kg, coefficient of kinetic friction (μ) of 0.1, and a time rate of change in mass (k) of 1 kg/s. There is also a mention of the need to
GassyMule
A cart roles down the track with an initial velocity vo. Because of falling rain, water starts filling the cart such that its mass increases linearly with time. The rain that has fallen on the track cause the wagon to experience a frictional force characterized with a coefficient of kinetic friction μ.
a) Write the equation of motion for this scenario..
b) Solve this differential equation by hand to get the velocity as a function of time. You might have to consult a book on ordinary differential equations.
c) Using whatever means you wish, plot the velocity of the cart versus time and determine at what time the cart stops moving. Use vo = 2 m/s, mo = 100 kg, μ = 0.1, and the time rate of change of the mass of the cart k = 1 kg/s
Hello GM, welcome to PF :smile: !
What's the QM got to do with all this ?
You need to get familiar with the PF culture a little better: see the guidelines . Template, attempted soltion, relevant equations are missing and that should preclude any assistance at this stage, I'm afraid.
And: is there something you wanted to ask ? So far all I see is a (nice) exercise :rolleyes:.
Related to Quantum Mechanics, Cart filling, + friction as it moves
1. What is Quantum Mechanics?
Quantum Mechanics is a branch of physics that studies the behavior and interactions of particles at a subatomic level, where classical physics laws no longer apply.
2. How does Cart filling relate to Quantum Mechanics?
Cart filling, or the process of filling a shopping cart, is not directly related to Quantum Mechanics. However, the principles of Quantum Mechanics can be applied to understand the behavior of particles in a cart, such as the movement of individual atoms and molecules.
3. What is friction in relation to Quantum Mechanics?
Friction is a force that opposes the motion of an object. In Quantum Mechanics, friction is understood as the result of interactions between particles at a microscopic level.
4. How does friction affect the movement of a cart?
Friction can slow down or stop the movement of a cart, depending on the surface it is moving on and the force being applied. In Quantum Mechanics, this is due to the interactions between particles in the cart and the surface it is moving on.
5. Can Quantum Mechanics explain the movement of a cart?
While Quantum Mechanics can provide a deeper understanding of the behavior of particles in a cart, it does not fully explain the macroscopic movement of the cart as a whole. Classical mechanics is still the most accurate theory for describing the movement of larger objects.
