Quantum mechanics emerging from vibrating fluid
In summary, the pilot wave theory is a theory that has been shown to be correct for some forms of quantum mechanics, and has potential to be extended to all relativistic quantum mechanics.
ibkev
131
60
I've just recently learned about Yves Clouder's hydrodynamics models that show quantum mechanics behaviour emerging from a vibrating fluid. As a "born-again student", this seems very exciting to me - especially in the sense that at the very least it offers a mental model that helps come to grips with the weirdness of quantum mechanics.
AND, on a deeper level, what if this really is giving us a hint that there is a fundamental mechanism underlying quantum behaviour? How cool would that be?? :)
Can someone point me in the direction of interesting work that is being spawned from this? I've done some basic googling and turned up John Bush's experiments at MIT and some papers by Brady and Anderson. Also, I'd be interested to hear if people are skeptical of the value of looking in this direction? Seems exciting to me but I still have a great deal to learn.
The August 2015 Issue of "Physics Today" has a good article called "The new wave of pilot-wave theory" written by John W. M. Bush.
I think the pilot-wave theory is a viable theory that should be perused. Just keep in mind that it not the main stream view of quantum mechanics.
Likes vanhees71 and ibkev
Ah thanks for this!
Incidentally, this vibrating fluid seems to offer an 2D analogy for quantum mechanics that is reminiscent of how the balls-on-a-rubber-sheet analogy helps people to conceptually understand 2D GR.
If you read the posts in the thread I linked, you will find a number of points why these experiments aren't exactly like QM and as an aside a recent paper was published by another team questioning some of Couder's conclusions:
We argue that the double-slit experiment with walking droplets can possibly lead to spectacular interference patterns (Fig. 1), but that these will be fundamentally different from the interference in the renowned double-slit experiment with single electrons that is so central in quantum mechanics (Fig. 2). Our conclusions are based on experiments on walking droplets and general theoretical arguments. By presenting a modified double-slit experiment with a central splitter plate we theoretically pinpoint the fundamental difference between the two systems, namely that the droplet singles out a particular path whereby destroying the quantum mechanical democracy of paths experienced by an electron.
Double-slit experiment with single wave-driven particles and its relation to quantum mechanics
http://www.fysik.dtu.dk/english/Research/Highlight/150827-Double-slit-experiment
It's worth reading the whole paper if you have access.
Likes ibkev
I'd say "visualize" instead of "conceptually understand", but with that qualification it is indeed a useful analogy (in fact, it's a better analogy for QM than the rubber sheet model is for GR) because it shows the remarkable variety of phenomena that emerge from the wave equation in any medium.
It only becomes problematic when people forget that it is analogy, that it illustrates only certain aspects of thing being analogized, and at some point will have to be replaced with study of the real thing.
Likes bhobba and ibkev
This is basically hype.
(1) The pilot wave theory needs no help* from the work you mentioned. It is already accepted as a correct possibility in for non-relativistic quantum mechanics, and for some forms of relativistic quantum mechanics. Open problems are extending it to all relativistic quantum mechanics, as well as possible deviations from quantum mechanics if the pilot wave theory is right. For the latter you can look up Antony Valentini's work.
(2) The fluid experiments only deal with a single particle. At present they do not extend to quantum mechanics with two particles. In contrast, the pilot wave theory does extend to any fixed number of particles in non-relativistic quantum mechanics. It is important to note that currently most people do not consider single particle quantum mechanics to be mysterious in any way. It is with two particles that one can get the famous "spooky action at a distance", which did teach us that relativity is not necessarily a theory of causality, as it is presented classically.
*The phrase "needs no help" comes from Tim Maudlin's critique in the comments of https://www.quantamagazine.org/20140624-fluid-tests-hint-at-concrete-quantum-reality/ (the article itself is misleading, just focus on Maudlin's comments). Maudlin's critique was pointed out to me by bohm2 in another thread on this forum.
Likes Demystifier
FAQ: Quantum mechanics emerging from vibrating fluid
What is quantum mechanics emerging from vibrating fluid?
Quantum mechanics emerging from vibrating fluid is a theoretical framework that explains the behavior of particles at the quantum level by using the concept of a vibrating fluid. This concept suggests that particles are not solid objects, but rather are made up of constantly vibrating fluid or energy.
How does the concept of vibrating fluid relate to quantum mechanics?
The concept of vibrating fluid relates to quantum mechanics by providing a new way of understanding the behavior of particles at the quantum level. It suggests that particles are not just particles, but rather a manifestation of constantly vibrating energy. This concept helps explain phenomena such as wave-particle duality and quantum tunneling.
What evidence supports the concept of quantum mechanics emerging from vibrating fluid?
There is currently no direct evidence to support the concept of quantum mechanics emerging from vibrating fluid. However, some researchers have proposed experiments that could potentially provide evidence for this theory. These experiments involve observing the behavior of particles in a vibrating fluid environment and looking for any patterns or correlations that support the theory.
How does this theory differ from other interpretations of quantum mechanics?
This theory differs from other interpretations of quantum mechanics in that it suggests that particles are not fundamental objects, but rather manifestations of vibrating energy. Other interpretations, such as the Copenhagen interpretation, view particles as fundamental objects with inherent properties. This theory also provides a more intuitive way of understanding quantum phenomena, as it relates to everyday experiences of waves and vibrations.
Are there any practical applications of this theory?
Currently, there are no practical applications of this theory. However, if it is proven to be true, it could lead to a deeper understanding of quantum mechanics and potentially lead to new technologies and advancements in fields such as quantum computing and communication. It could also potentially help bridge the gap between classical and quantum mechanics, leading to a more unified understanding of the universe.
