Quantum mechanics: Find the wave function given the conditions
In summary, the wave function for a 1-dimensional linear harmonic oscillator can be expressed as: α|ϕ0> + β|ϕ1> where α and β are real and positive. The mean value of the momentum operator at the instant t=0 is: <P> = (mħw/2)1/2.
Jalo
120
Consider a 1-dimensional linear harmonic oscilator. Any measurement of it's energy can either return the value of ħw/2 or 3ħw/2, with equal probability. The mean value of the momentum <P> at the instant t=0 is
<P> = (mħw/2)1/2
Find the wave function ψ(x,0) for this state.
I started by assuming that the wave function would be something of the kind:
ψ(x,0) = α|ϕ0> + β|ϕ1>
Since the probability of measuring the energy for n=0 and n=1 is the same I concluded that α=β
Image with my resolution:
http://oi41.tinypic.com/2e64ykz.jpg
I think my way of solving the problem is correct, however the result doesn't make sense... If someone could give me a hint about where I might have gone wrong I'd appreciate. Thanks.
You can't assume that α = β follows from the equal probabilities. What is the relationship between α and the probability of measuring the energy to be [itex]\hbar \omega/2[/itex]?
It looks like you dropped a negative sign in your calculations. See the third line of your calculation of <Px> where you have a negative sign in front of α that you drop in the last equality of the third line.
[Edit: Also, I think your expression for the operator Px has the wrong overall sign.]
Ok, so I reviewed the problem.
The probability of measuring the energy to be ħw/2 is given by the expression:
[itex]\frac{|<ϕ_{0}|ψ>|^{2}}{<ψ|ψ>}[/itex]
where ϕ0 is the eigenfunction associated with the eigenvalue of the first level of energy. Developing this expression I got:
[itex]\frac{|<ϕ_{0}|ψ>|^{2}}{<ψ|ψ>}[/itex] = [itex]\frac{|α|^{2}}{1}[/itex] = [itex]\frac{1}{2}[/itex]
|α| = ±[itex]\sqrt{1/2}[/itex]
Using the same process I also concluded that:
|β| = [itex]\sqrt{1/2}[/itex]
Correcting the sign mistake I had I arrived at the following result, regarding the mean value of the momentum operator P:
i[itex]\sqrt{\frac{mwħ}{2}}[/itex] ([itex]α^{*}[/itex]β - αβ[itex]^{*}[/itex]) = [itex]\sqrt{\frac{mwħ}{2}}[/itex]
i (α[itex]^{*}[/itex]β - αβ[itex]^{*}[/itex]) = 1
I'm not sure where I am supposed to go next. Have I made any other error?
Since you can multiply the wavefunction by any complex number of magnitude 1 without changing the state or the normalization, you may assume ##\alpha## is real and positive. But you will need to allow for a phase factor in ##\beta##: ##\beta =e^{i\phi} \sqrt{1/2}##.
I think you might still have an overall sign error here. Did you correct the sign error in your expression for the Px operator in terms of the creation and destruction operators?
My bad! I corrected it just now. It will result in a change of sign in the final expression.
[itex]i\left(αβ^{*}-α^{*}β\right) = 1[/itex]
I assumed that both [itex]α[/itex] and [itex]β[/itex] were complex numbers, given by
[itex]α = |α|^{i\theta}[/itex]
[itex]β = |β|^{i\phi}[/itex]
Substituting in my expression, and developing it in a sine, I arrived at the expression:
[itex]sin(\theta-\phi) = -1[/itex]
[itex]\theta-\phi = \frac{3\pi}{2}+2n\pi[/itex]
If I force [itex]\theta[/itex] to be 0, as you said, I'll get the value of [itex]\phi[/itex]. Am I correct now? (I don't have the solution of the problem, so I'm not 100% sure)
Yes, that looks good. You should get a simple expression for ##\beta##.
Likes 1 person
Thank you very much for your help!
Related to Quantum mechanics: Find the wave function given the conditions
1. What is a wave function in quantum mechanics?
A wave function in quantum mechanics is a mathematical function that describes the behavior and properties of a quantum system. It contains information about the position, momentum, and other physical characteristics of particles in the system.
2. How is the wave function determined?
The wave function is determined by solving the Schrödinger equation, which is a fundamental equation in quantum mechanics that describes the time evolution of a quantum system. The solution to this equation gives the wave function for the system under specific conditions.
3. What are the conditions needed to find the wave function?
The conditions needed to find the wave function depend on the specific problem at hand. In general, the conditions include the physical properties of the quantum system, such as the particles involved, the potential energy, and any given initial conditions.
4. Can the wave function be observed?
No, the wave function itself cannot be directly observed. It is a mathematical tool used to make predictions about the behavior of a quantum system. However, the effects of the wave function can be observed through experiments and measurements of the system.
5. How does the wave function relate to probability in quantum mechanics?
In quantum mechanics, the wave function is used to calculate the probability of finding a particle in a given state or location within a quantum system. The absolute square of the wave function gives the probability density function, which represents the likelihood of finding a particle at a specific point in space.
