Quantum mechanics - Heisenberg picture
In summary, the conversation discusses the O2- molecule in the Heisenberg and Schrodinger pictures, with a focus on finding eigenvalues and eigenvectors, as well as probabilities using the Born rule. The time evolution operator is used to find the state of the system at different times in the Schrodinger picture.
alc95
We consider the O2- molecule, with the Hamiltonian and position operator having matrix representations in terms of the Pauli matrices:
In the Heisenberg picture, the position operator is:
(1) Find the eigenvalues and eigenstates of x(t) at time t=pi*hbar/(4A)
(2) The state |-a> remains the same in the Heisenberg picture. Find the probabilities of measuring the two eigenvalues of x(t) at time t=pi*hbar/(4*A)
(3) Now switching to the Schrodinger picture, find the state at time t = pi*hbar/(4A) for initial state |−a>
(4) In the Schrodinger picture the operator x is constant. Find the probabilities of measuring eigenvalues +a and −a of x at time t = pi*hbar/(4*A), given initial state |−a>. Compare these to the result from question 2.
The equations given above, plus the Born rule for calculating probabilities.
(1) This part was ok, I got ± a for the eigenvalues, and the corresponding eigenvectors:
(1/sqrt(2))*[1,∓ i]
(2)
the probabilities will be:
[tex]
\begin{equation}
|<psi|\lambda_+>|^2
\end{equation}
[/tex]
and
[tex]
\begin{equation}
|<psi|\lambda_->|^2
\end{equation}
[/tex]
where the lambdas are the eigenstates corresponding to the positive and negative eigenvalues. Psi is the state of the system, although I'm unsure of what it will be.
(3)
I'm not exactly sure how to interpret this question. Should I try to find an expression for psi in terms of |-a>?
(4)
Am I on the right track with the following?
The probabilities will be:
[tex]
\begin{equation}
|<-a|lambda_+>|^2
\end{equation}
[/tex]
and
[tex]
\begin{equation}
|<-a|lambda_->|^2
\end{equation}
[/tex]
Any help is appreciated :)
For part (2), you are correct in using the Born rule to calculate the probabilities. However, you also need to consider the state of the system at time t = pi*hbar/(4A). This can be found by applying the time evolution operator, which in this case is just the identity matrix since the operator x is constant in the Heisenberg picture. So the state of the system at time t = pi*hbar/(4A) is just |-a>. Then you can plug this into the Born rule to calculate the probabilities.
For part (3), you are correct that you need to find an expression for the state of the system in terms of |-a>. This can be done by applying the time evolution operator, which in this case is given by exp(-iHt/hbar), where H is the Hamiltonian. You can use the matrix representations of the Hamiltonian and position operator to calculate this.
For part (4), you are on the right track with using the Born rule again. However, note that in the Schrodinger picture, the state of the system changes with time, so you need to use the time evolution operator to find the state at time t = pi*hbar/(4A). Then you can plug this state into the Born rule to calculate the probabilities of measuring the eigenvalues +a and -a.
Hope this helps!
Related to Quantum mechanics - Heisenberg picture
1. What is the Heisenberg picture in quantum mechanics?
The Heisenberg picture is one of two formulations of quantum mechanics, the other being the Schrödinger picture. In the Heisenberg picture, the operators representing physical observables evolve in time, while the state of the system remains fixed. This is in contrast to the Schrödinger picture, where the state of the system evolves in time while the operators remain fixed.
2. What is the significance of the Heisenberg uncertainty principle in quantum mechanics?
The Heisenberg uncertainty principle states that it is impossible to know both the position and momentum of a particle with absolute certainty. This is a fundamental principle in quantum mechanics and has implications for the behavior of particles at the microscopic level. It also plays a crucial role in the development of technologies such as quantum computing.
3. How does the Heisenberg picture differ from the Schrödinger picture?
In the Heisenberg picture, the operators representing physical observables evolve in time, while the state of the system remains fixed. In the Schrödinger picture, the state of the system evolves in time while the operators remain fixed. This means that in the Heisenberg picture, the equations of motion for operators are more complicated, but the time evolution of states is simpler.
4. Can the Heisenberg picture be used to solve all quantum mechanical problems?
No, the Heisenberg picture is just one of two formulations of quantum mechanics and is not always the most convenient approach for solving problems. Some problems may be more easily solved using the Schrödinger picture or other techniques. It is important to choose the most appropriate approach for each problem.
5. What are some applications of the Heisenberg picture in modern technology?
The Heisenberg picture has been used in the development of technologies such as nuclear magnetic resonance (NMR) spectroscopy and magnetic resonance imaging (MRI). It also plays a crucial role in the understanding of quantum computing and quantum information processing. Additionally, the Heisenberg uncertainty principle has implications for the design and precision of nanotechnology devices.
