Quantum Mechanics, Momentum Space
Thanks.In summary, the conversation discusses how to show that <x> can be expressed as an integral involving the wave function \Phi(p,t) and its derivative with respect to momentum. The conversation goes through the derivation step by step, but a mistake is made when substituting for x\Psi(x,t), which is corrected by changing the dummy variable to p'. The final expression involves a delta function, which makes the integral solvable.
NeoDevin
334
Show that
[tex] <x> = \int \Phi^* \left(-\frac{\hbar}{i}\frac{\partial}{\partial p} \right) \Phi dp [/tex]
[tex] \Phi(p,t) = \frac{1}{\sqrt{2\pi\hbar}} \int^{\infty}_{-\infty} e^{\frac{-ipx}{\hbar}} \Psi(x,t)dx [/tex]
[tex] \Psi(x,t) = \frac{1}{\sqrt{2\pi\hbar}} \int^{\infty}_{-\infty} e^{\frac{ipx}{\hbar}} \Phi(p,t)dp [/tex]
I started out with
[tex] <x> = \int^{\infty}_{-\infty} \Psi^* x \Psi dx [/tex]
Using the above equation for [itex] \Psi(x,t) [/itex] (and it's conjugate) gives:
[tex] \Psi^* (x,t) = \frac{1}{\sqrt{2\pi\hbar}} \int^{\infty}_{-\infty} e^{\frac{-ipx}{\hbar}} \Phi(p,t)dp [/tex]
and
[tex] x\Psi(x,t) = \frac{x}{\sqrt{2\pi\hbar}} \int^{\infty}_{-\infty} e^{\frac{ipx}{\hbar}} \Phi(p,t)dp[/tex]
[tex] = \frac{1}{\sqrt{2\pi\hbar}} \int^{\infty}_{-\infty} x e^{\frac{ipx}{\hbar}} \Phi(p,t)dp[/tex]
[tex] = \frac{1}{\sqrt{2\pi\hbar}} \int^{\infty}_{-\infty} \frac{\partial}{\partial p} e^{\frac{ipx}{\hbar}} \Phi(p,t)dp[/tex]
[tex] = \frac{1}{\sqrt{2\pi\hbar}} \left[ \left( e^{\frac{ipx}{\hbar}} \Phi(p,t) \right) \bigg|^{\infty}_{-\infty} -\int^{\infty}_{-\infty} e^{\frac{ipx}{\hbar}} \frac{\partial}{\partial p}\Phi(p,t)dp \right][/tex]
[tex] = -\frac{1}{\sqrt{2\pi\hbar}} \int^{\infty}_{-\infty} e^{\frac{ipx}{\hbar}} \frac{\partial}{\partial p} \Phi(p,t) dp [/tex]
Substituting into the original equation for [itex] <x> [/itex] then gives
[tex]<x> = \int^{\infty}_{-\infty}\left( \frac{1}{\sqrt{2\pi\hbar}} \int^{\infty}_{-\infty}e^{\frac{-ipx}{\hbar}} \Phi^* (p,t) dp \right) x\Psi(x,t) dx [/tex]
[tex] = \frac{1}{\sqrt{2\pi\hbar}} \int^{\infty}_{-\infty} \Phi^* (p,t) \int^{\infty}_{-\infty} e^\frac{-ipx}{\hbar} (x\Psi(x,t))dx dp [/tex]
[tex] = -\frac{1}{2\pi\hbar} \int^{\infty}_{-\infty} \Phi^* (p,t) \int^{\infty}_{-\infty} e^{\frac{-ipx}{\hbar}} \int^{\infty}_{-\infty} e^{\frac{ipx}{\hbar}} \frac{\partial}{\partial p} \Phi(p,t) dp dx dp[/tex]
[tex] = -\frac{1}{2\pi\hbar} \int^{\infty}_{-\infty} \Phi^* (p,t) \int^{\infty}_{-\infty} \frac{\partial}{\partial p} \Phi(p,t) \int^{\infty}_{-\infty} e^{\frac{-ipx}{\hbar}} e^{\frac{ipx}{\hbar}} dx dp dp[/tex]
[tex] = -\frac{1}{2\pi\hbar} \int^{\infty}_{-\infty} \Phi^* (p,t) \int^{\infty}_{-\infty} \frac{\partial}{\partial p} \Phi(p,t) \int^{\infty}_{-\infty} dx dp dp [/tex]
I'm pretty sure I messed up somewhere, since that integral is infinite...
Any help would be appreciated.
I also tried the reverse, starting with the expression you're supposed to get for <x>, and working back from there using similar methods... but it gives me the same problem.
Your calculation seems fine up until the point where you substitute your expression for [tex]x\Psi(x,t)[/tex]. You should be integrating over two dummy variables in your final expression, say [itex]p[/itex] and [itex]p^{\prime}[/itex], but you have written both dummy variables as the same variable [itex]p[/itex]. The expression you derived for [tex]x\Psi(x,t)[/tex] in terms of an integral over [itex]p[/itex], change [itex]p[/itex] to [itex]p^{\prime}[/itex] and everything should work out.
So then for the second last line we end up with
[tex] <x> = -\frac{1}{2\pi\hbar} \int^{\infty}_{-\infty} \Phi^* (p,t) \int^{\infty}_{-\infty} \frac{\partial}{\partial p'} \Phi(p',t) \int^{\infty}_{-\infty} e^{\frac{-i(p-p')x}{\hbar}} dx \ dp' \ dp [/tex]
Is that integral doable?
You should recognize the x integral as a delta function.
Oh, right... Duh. :blushing: Got it now
Related to Quantum Mechanics, Momentum Space
1. What is momentum space in quantum mechanics?
Momentum space is a mathematical representation of the momentum of a particle in quantum mechanics. It is a three-dimensional space that describes the momentum of a particle in terms of its magnitude and direction.
2. How does quantum mechanics describe momentum?
In quantum mechanics, momentum is described in terms of operators, specifically the momentum operator. This operator acts on the wave function of a particle to determine its momentum at a specific point in space and time.
3. What is the uncertainty principle in momentum space?
The uncertainty principle in momentum space states that it is impossible to know the exact momentum and position of a particle simultaneously. This is due to the wave-particle duality of quantum mechanics, where the more precisely we know the momentum, the less precisely we know the position, and vice versa.
4. How is momentum conserved in quantum mechanics?
In quantum mechanics, momentum is conserved in the same way as in classical mechanics. This means that the total momentum of a closed system remains constant, regardless of any internal interactions or changes in the system.
5. Can momentum be quantized in quantum mechanics?
Yes, in quantum mechanics, momentum is quantized, meaning it can only exist in discrete values rather than a continuous range. This is due to the wave-like nature of particles, where their momentum can only take on certain discrete values determined by the particle's wavelength.
