(Quantum Mechanics) Prove that <p> = m (d<x>/dt)
The discussion centers on proving the relationship <p> = m (d<x>/dt) in quantum mechanics, starting from the Schrödinger equation. Participants explore the derivation of the expectation value of position, <x>, and its time derivative, encountering challenges with integration by parts and boundary conditions. Key points include the assumption that the wave function and its derivative approach zero as x approaches ±∞, which is necessary for normalization. The conversation also highlights the importance of ensuring that the integration limits are correctly handled during the derivation process. Ultimately, the participants aim to clarify the conditions under which these mathematical steps are valid in the context of quantum mechanics.
emol1414
Prove that &lt;p&gt; = m \frac{d&lt;x&gt;}{dt}
Schrödinger Equation: i\hbar \frac{\partial \Psi} {\partial x} = -\frac{\hbar^2}{2m} \frac{\partial^2 \Psi}{\partial x^2} + V{} \Psi
Respective complex conjugate from equation above
Expectation Position: <x> = \int_{-\infty}^{+\infty} x\Psi {\Psi}^* dx
Derive <x> with respect to t... with V real, we know that V = V*, and after some basic steps we get:
\frac {d&lt;x&gt;}{dt} = \frac{i \hbar}{2m} \int dx x[\Psi^*(\frac{\partial^2 \Psi}{\partial x^2}) - \Psi (\frac{\partial^2 \Psi^*}{\partial x^2})]
Then my problem is with the integration by parts... for
\int_{a}^{b} f \frac{dg}{dx} dx = fg {|}^{b}_{a} - \int_{a}^{b} g \frac{df}{dx} dx
I'm choosing f = x\Psi^* and g = \frac{\partial \Psi}{\partial x}, but I think I'm not getting right these limits considerations... any sugestions or enlightenments?_______________________________________________________
EDIT (\frac{\partial \Psi}{\partial} with respect to time, not position)
Schrödinger Equation: i\hbar \frac{\partial \Psi} {\partial t} = -\frac{\hbar^2}{2m} \frac{\partial^2 \Psi}{\partial x^2} + V{} \Psi
What happened to the dx/dt term when you took the time derivative of x\Psi\Psi^*?
In QM x don't depend on t, right?
*Fixed a typo in the equation
You're right. The operator doesn't explicitly depend on time, so its derivative is 0.
So, we have, for the product rule, that
And choosing f = x\Psi^* and g = \frac{\partial \Psi}{\partial x}
\frac {d&lt;x&gt;}{dt} = \frac{i \hbar}{2m} {x \Psi^* \frac{\partial \Psi}{\partial x} |^{\infty}_{-\infty} - \int_{-\infty}^{\infty} \frac{\partial \Psi}{\partial x}(\Psi^* + x \frac{\partial \Psi^*}{\partial x})dx - x \Psi \frac{\partial \Psi^*}{\partial x} |^{\infty}_{-\infty} + \int_{-\infty}^{\infty} \frac{\partial \Psi^*}{\partial x}(\Psi + x \frac{\partial \Psi}{\partial x})dx}
I guess up to this point it's ok... now I don't know how to work with these limits, which considerations should I do?
Assume the wave function and its derivative go to 0 as x goes to ±∞.
Right... I'm not really sure why this is true (??), but doing so... we perform integration by parts 2 times and then
\frac {d&lt;x&gt;}{dt} = -\frac{i \hbar}{2m} {\int_{-\infty}^{\infty} \Psi^*(\frac{\partial \Psi}{\partial x}) - \Psi (\frac{\partial \Psi^*}{\partial x} )dx}
That's it?
You're almost done. Remember that\langle p \rangle = \int dx\,\Psi^* \hat{p} \Psi = \int dx\,\Psi^*\left(-i\hbar\frac{\partial}{\partial x}\right) \Psi
You want to get the righthand side to look like that. One term already looks like that, but you still need to take care of the other one.
Got it! Integration by parts only in one of the two terms left and then add to the other, so the factor 1/2 is gone... but... there's a m missing in the denominator, right?
Thank you! =)
One more thing... why is that \Psi goes to 0 when x \rightarrow \pm \infty? Is it a "single-case" fact, or is it always true?
The wave function needs to vanish at infinity to be normalizable. You have to assume the function goes to 0 fast enough so that the boundary terms go to 0. There's probably a rigorous justification for it, but I don't recall it offhand.
It's not mandatory, but usually one picks up from L^2 functions only the Schwartz test functions and that for a good reason.
  • · Replies 30 ·
