Quantum mechanics question on probability amplitude
In summary, the conversation discusses the use of probability amplitudes in studying physical phenomena, rather than just probabilities. The equation p(x) = |\psi(x)|^2 is mentioned, but it is noted that this is not a physical phenomenon. The concept of assigning meaning to \psi(x) alone is also questioned. The idea of "waves superposition" is suggested as an answer.
spaghetti3451
1,344
34
What physical phenomenon requires us to work with probability amplitudes rather than just
with probabilities, as in other fields of endeavour?
That the probability of an outcome is given by the square of the modulus of the corresponding probability amplitude? But that's not a physical phenomenon?
Is probability a physical phenomenon? I don't think so, but maybe.
Like any statistical distribution you can use the density to e.g. finding the probability of the particle being a point in space:
Find the probability that the electron has position x = 2 given that:
[itex] p(x) = |\psi(x)|^2 = 1/x^2[/itex]
Then you would be wrong to integrate, but simply doing this would solve it:
[itex] p(x=2) = 1/2^2 = 4[/itex]
I don't think you can assign much meaning to the [itex]\psi(x)[/itex] alone.
Hope that helped a little.
'Waves superposition' would be an answer.
FAQ: Quantum mechanics question on probability amplitude
1. What is a probability amplitude in quantum mechanics?
A probability amplitude is a complex number used to describe the likelihood of a particle's state in quantum mechanics. It combines both the amplitude (size) and phase (direction) of a wave function to determine the probability of finding a particle in a certain state.
2. How is a probability amplitude calculated?
A probability amplitude is calculated by taking the inner product of two wave functions. This involves multiplying the complex conjugate of one wave function by another and integrating the result over all space.
3. What is the significance of the magnitude and phase of a probability amplitude?
The magnitude of a probability amplitude determines the likelihood of finding a particle in a given state, with larger magnitudes corresponding to higher probabilities. The phase of a probability amplitude determines the direction of the wave function and affects interference patterns in quantum systems.
4. How does the concept of probability amplitude relate to the uncertainty principle?
The uncertainty principle states that it is impossible to know both the position and momentum of a particle with absolute certainty. Probability amplitudes reflect this uncertainty by assigning a range of possible states to a particle rather than a single value.
5. Can probability amplitudes be negative?
Yes, probability amplitudes can be negative. This reflects the wave-like nature of particles in quantum mechanics and allows for destructive interference between waves, which can result in a probability of zero for certain states.
