Quantum Mechanics - Question Regarding Eigenenergy
In summary, the problem involves an electron in a three-dimensional cubic box with infinitely high potential walls. The energy equation for this scenario is En=((h2)/8MLz2)(n2), where n is the principal quantum number. Each quantum number is independent of the others and the side lengths of the box, but the energy spectrum is the same in all three dimensions.
vladittude0583
40
Consider an electron in a three-dimensional cubic box of side length Lz. The walls of the box are presumed to correspond to infinitely high potentials.
En=((h2)/8MLz2)(n2) where n corresponds to the principal quantum numbers in their respective axes
My only question is if the side lengths of the cubic box are all of length Lz, does that necessarily mean that all of the principal quantum numbers "n" can be written as nz also or are they all independent of the each other and of the side lengths? Thanks.
Each quantum number is independent. The fact that the side lengths are all the same only means that the energy spectrum (the set of allowed energies) is the same in all 3 dimensions. So for example, the fact that the side lengths are the same means that if nx = ny, then the same amount of energy is associated with the x dimension as with the y dimension. But there's no reason that the actual values of different quantum numbers need to be the same, even if the sets of possible values are the same.
FAQ: Quantum Mechanics - Question Regarding Eigenenergy
What is the concept of eigenenergy in quantum mechanics?
Eigenenergy in quantum mechanics refers to the energy of a quantum system in a specific state. It is a characteristic energy value that is associated with a particular quantum state, and is unique to that state.
How is eigenenergy calculated in quantum mechanics?
Eigenenergy is calculated by solving the Schrödinger equation for a particular quantum system. This equation describes the energy of the system in terms of its wavefunction, and the eigenenergy is obtained as the solution to this equation.
Can eigenenergy be measured in experiments?
No, eigenenergy cannot be directly measured in experiments. This is because it is a theoretical concept that describes the energy of a quantum system in a specific state. However, the effects of eigenenergy can be observed and measured indirectly through experiments.
How does eigenenergy relate to quantum states?
Eigenenergy is a property of quantum states, as it describes the energy of a system in a specific state. Each quantum state has a unique eigenenergy, and the difference in eigenenergy between two states determines the probability of a system transitioning from one state to another.
What are the implications of eigenenergy in quantum mechanics?
Eigenenergy is a fundamental concept in quantum mechanics, and it has many implications for understanding the behavior of quantum systems. It allows us to predict the energy levels of a system, determine the probability of transitions between states, and study the dynamics of quantum systems.
