Quantum Mechanics, Simple harmonic oscillator, partition function
In summary, quantum mechanics is a branch of physics that studies the behavior of matter and energy at a small scale. A simple harmonic oscillator is a system that exhibits periodic motion, and the partition function is a mathematical tool used to calculate thermodynamic properties in quantum mechanics. The partition function is directly related to the energy levels of a system and can be used to calculate other thermodynamic properties such as average energy, entropy, and specific heat.
vj3336
Compute the partition function Z = Tr(Exp(-βH)) and then the average number of particles
in a quantum state <nα > for an assembly of identical simple harmonic oscillators. The Hamiltonian is:
H = [itex]\sum _{k}[/itex][(nk+1/2)[itex]\hbar - \mu[/itex] nk]
with nk=ak+ak.
Do the calculations once for bosons and once for fermions.
For Bosons
[itex]Z=\text{Tr}[\text{Exp}[-\text{$\beta $H}]]=\sum _n \langle n|\text{Exp}[-\text{$\beta $H}]|n\rangle =\sum _n \left\langle n\left|\text{Exp}\left[-\beta
\left(\sum _k \left(n_k+\frac{1}{2}\right)\hbar -\text{$\mu $n}_k\right)\right]\right|n\right\rangle =[/itex]
[itex]=\sum _n \left\langle n\left|\text{Exp}\left[-\beta \left(\sum _k (\hbar -\mu )a_k{}^+a_k-\frac{1}{2}\hbar \right)\right]\right|n\right\rangle[/itex]
I don't know how to go on from here.
Particularly I don't know how to deal with the sum in the exponential.
What are the eigenstates of the Hamiltonian? I think if you understand that, evaluating the exponential should be straightforward. The sum over k is just summing over the individual harmonic oscillators.
ok, I think that I can find energy eigenstates in this way:
[itex]\left.\left.H|n\rangle =E_n\right|n\right\rangle[/itex]
[itex] \left.\left.\left.\left.\left(\sum _k (\hbar -\mu )a_k{}^+a_k-\frac{1}{2}\hbar \right)\right|n\right\rangle =E_n\right|n\right\rangle
[/itex]
[itex]
\left.\left. \left.\left.\left.\left.\left.\left.\left.\left.(\hbar -\mu )a_1{}^+a_1\right|n\right\rangle -\frac{1}{2}\hbar \right|n\right\rangle +...+(\hbar -\mu )a_k{}^+a_k\right|n\right\rangle -\frac{1}{2}\hbar \right|n\right\rangle=E_n\right|n\right\rangle
[/itex]
[itex]
\left.\left.\left.\left.\left(k\left((\hbar -\mu )n-\frac{1}{2}\hbar \right)\right)\right|n\right\rangle =E_n\right|n\right\rangle
[/itex]
[itex]
E_n=\left(k\left((\hbar -\mu )n-\frac{1}{2}\hbar \right)\right)
[/itex]
Put aside the math for now. Describe in words what the eigenstates of the system are. For example, the ground state would be when all of the oscillators are in the ground state. What would the first excited state(s) be? And so on.
The first excited state is when one of the oscillators is in the E1 state,
the second excited state is when one of the oscillator is in the E2 state or
one is in E1 state and some other is also in E1 state ... etc
Isn't the answer to that question in how many ways I can distribute En energy quanta between N oscillators ?
So these states would be something like [itex]\vert 1,0,0,...,0 \rangle[/itex], [itex]\vert 0,1,0,...,0 \rangle[/itex], and so on, where the k-th number is n for the k-th oscillator. In other words, the eigenstates can be labeled using the n's for the individual oscillators. Do you see now how you'd evaluate the matrix elements now?
sorry , I still don't know how to do it, can you give me a more explicit hint ?
You will find it more useful to leave the operator written as [itex]\hat{n}_k[/itex], as you are acting on the eigenstates of this operator with a function of that operator: [itex]f(\hat{n}_k)| n \rangle[/itex]. This is actually quite easy to evaluate. Consider what happens if the function f can be expanded as a Taylor series (which is really the definition of a function of an operator). What does
[tex]\left(\hat{1} + \sum_{m=1}^\infty \frac{f^{(m)}(0)}{m!}\hat{n}_k^m\right)|n \rangle[/tex]
evaluate to?
Once you understand this, making the connection to vela's hint will hopefully be clear.
Also, note that [itex]\hbar[/itex] should have a frequency [itex]\omega[/itex] attached to it: [itex]\mathcal H = \sum_k [(\hat{n}_k + 1/2)\hbar\omega + \mu \hat{n}_k].
I think the above expression evaluates to:
[itex]\left.\left.\left.\left.\overset{\wedge }{1}|n\right\rangle +\frac{f^{(1)}(0)}{1!}\overset{\wedge }{n_k}{}^1|n\right\rangle +\frac{f^{(2)}(0)}{2!}\overset{\wedge
}{n_k}{}^2|n\right\rangle +\text{...}+\frac{f^{(m)}(0)}{m!}\overset{\wedge }{n_k}{}^m|n\right\rangle[/itex] =
20+\frac{f^{(2)}(0)}{2!}n^2|n\right\rangle%20+\text{...}+\frac{f^{(m)}(0)}{m!}n^m|n\right\rangle.gif
[itex] \left.\left(\overset{\wedge }{1}+ \sum _{m=1}^{\infty } \frac{f^{(m)}(0)}{m!}n^m\right)|n\right\rangle[/itex]
[URL]http://latex.codecogs.com/gif.latex?\left.\left.\left.\left.\overset{\wedge%20}{1}|n\right\rangle%20+\frac{f^{(1)}(0)}{1!}n|n\right\rangle%20+\frac{f^{(2)}(0)}{2!}n^2|n\right\rangle%20+\text{...}+\frac{f^{(m)}(0)}{m!}n^m|n\right\rangle[/URL]
The last line is correct; the first couple of lines should really indicate that there are infinitely many terms.
Anyways, as for the last line, you hopefully realize that that is again just the Taylor series for the function f, where the eigenvalue of [itex]\hat{n}_k[/itex] acting on the eigenstate [itex]|n\rangle[/itex] has replaced the operator! i.e.,
[tex]f(\hat{n})|n\rangle = f(n)|n\rangle[/tex]
What this means is that any time you have a function of an operator that acts on an eigenstate of that operator, you can replace the operator with its eigenvalue in the function. (Caveat: it must be valid to expand the function as a Taylor series).
So, can you see how this relates to vela's hint?
P.S. - to get the hats on top of the symbols in Latex, use \hat{n}. Also, for the angle brackets, if you're going to use \left and \right on them, I would also do it for the | part. Otherwise the bras and kets look very awkward. Generally, when dealing with bras and kets I tend not to even use \left and \right, as I don't really view them as enclosing anything.
It's not clear to me exactly what you're doing. First off, what does n stand for?
Take the case of two harmonic oscillators. You have for the Hamiltonian
[tex]\hat{H} = [\hbar\omega(\hat{n}_1+1/2) - \mu \hat{n}_1] + [\hbar\omega(\hat{n}_2+1/2) - \mu \hat{n}_2][/tex]
and the eigenstates are [itex]|0,0\rangle[/itex], [itex]|1,0\rangle[/itex], [itex]|0,1\rangle[/itex], [itex]|1,1\rangle[/itex], [itex]|2,0\rangle[/itex], [itex]|0,2\rangle[/itex], ... What do you get when [itex]\hat{H}[/itex] acts on each of these states?
Related to Quantum Mechanics, Simple harmonic oscillator, partition function
1. What is quantum mechanics?
Quantum mechanics is a branch of physics that studies the behavior of matter and energy at a very small scale, such as atoms and subatomic particles. It describes the fundamental laws that govern the behavior of these particles and how they interact with each other.
2. What is a simple harmonic oscillator?
A simple harmonic oscillator is a system that exhibits periodic motion, where the restoring force is directly proportional to the displacement from the equilibrium position. Examples of simple harmonic oscillators include a mass attached to a spring and a pendulum.
3. What is the partition function in quantum mechanics?
The partition function is a mathematical tool used in statistical mechanics to calculate the thermodynamic properties of a system. In quantum mechanics, it is used to determine the probability of a system being in a certain energy state at a given temperature.
4. How is the partition function related to the energy levels of a system?
The partition function is directly related to the energy levels of a system through the Boltzmann factor, which takes into account the energy of each possible state and the temperature of the system. The higher the energy of a state, the less likely it is to be occupied at a given temperature.
5. Can the partition function be used to calculate other thermodynamic properties?
Yes, the partition function can be used to calculate other thermodynamic properties such as the average energy, entropy, and specific heat of a system. These properties are derived from the partition function through statistical mechanics formulas.
