Quantum mechanics: simultaneous eigenstates for operators
In summary: B^2, but it is not an eigenvalue of B. Does that mean B and B^2 have different eigenvectors? That could be, as you see in the last line, but the eigenvectors of B and B^2 are strongly connected.In summary, the conversation discussed the expectation value and uncertainty of an eigenstate of operator B, as well as the relationship between B and B2. It was found that the uncertainty for B2 is zero, and the eigenvalue of B2 is related to the eigenvalue of B through a double solution. The conversation
Tailong
Suppose that a state |Ψ> is an eigenstate of operator B, with eigenvalue bi.
i. What is the expectation value of B?
ii. What is the uncertainty of B?
iii. Is |Ψi an eigenstate of B2 or not?
iv. What is the uncertainty of B2?
part B
: Suppose, instead, |Ψ> is an eigenstate of operator B2, with eigenvalue λ.
Without loss of generality, any state can be expanded in eigenstates of B: |Ψ> =
Σci|bi>. (You can still assume that |bi> is eigenstates of operator B, so B|bi> = bi |bi>)
v. What is the uncertainty for B2 ?
vi. Starting from the expansion given above, write out B2 |Ψ> in the B basis (byoperating with B twice in a row since you know that B2|Ψ> = B(B|Ψ>).
vii. Write out the eigenvalue equation for B2in this basis.
Taking the inner product of both sides of the equation with <bj|, you can
extract information about the cj coefficients and the bj eigenvalues, given your
knowledge of λ. Write this equation and explain in words what conclusions
you can draw about the results you might get if you measured B.
By the expectation formula:
i.
<B> = <Ψ| B |Ψ> = bi <Ψ|Ψ> = bi
since for eigenstates, they are normalized, the inner product is 1.
ii.
For eigenstates, the uncertainty is simply 0.
Also we can do this mathematically as
<B2> = <Ψ| B B |Ψ> = bi <Ψ| B |Ψ> = bi2
ΔB = sqrt (<B2> - <B>2) = 0
The real problem is the rest :
iii.
I can do nothing else but operate B twice on the state
B2 |Ψ> = bi 2 |Ψ>
so I guess here bi2 is the corresponding eigenvalue for B2 here?
I feel like the answer is wrong, since if it is, the answer for part iv is zero too.
That looks bad.
So, I tried to do this in another way like
B B |Ψ> = bi B |Ψ>
so let B|Ψ> = is also an eigenstate for operator B
but |χ> = B|Ψ> = bi|Ψ> is with same basis of |Ψ>.
So B2 share a simultaneous eigenstate |Ψ> with B......
And then I get lost of my target.
Am I thinking too much ?
iv. I cannot solve this since I cannot solve part iii.v. Uncertainty for B2 is zero since |Ψ> is an eigenstate for B2.
vi.I tried to operate B on |Ψ>, so I get
B2|Ψ> = λ |Ψ>.
Then use the expansion:
|Ψ> =Σci|bi>
B2 |Ψ> = Σci B2 |bi>
= Σci bi2 |bi>
vii.
<bj| B2 |Ψ> =<bj| Σci bi2 |bi>
=cjbj2
= <bj| λ |Ψ> = λ<bj |Ψ>
= λ cj
Thus, λ = bj2.
I got this but cannot conclude anything from this.
What does this relate to the results from B operator ?
Hello, mr. T, and welcome to PF :)
i, ii, ii, iv: I can't do better than that either. B is just a complex number.
Now, in v. it becomes more interesting. There are two solutions for ##\lambda = b^2## ...
Related to Quantum mechanics: simultaneous eigenstates for operators
What is quantum mechanics?
Quantum mechanics is a branch of physics that deals with the behavior of particles on a very small scale, such as atoms and subatomic particles. It explains how these particles behave and interact with each other through concepts like wave-particle duality and uncertainty.
What are simultaneous eigenstates in quantum mechanics?
Simultaneous eigenstates refer to the states of a quantum system that are associated with the eigenvalues of two or more operators. In other words, these states have well-defined values for multiple physical properties at the same time.
What is an operator in quantum mechanics?
In quantum mechanics, an operator is a mathematical representation of a physical property that can be measured, such as position, momentum, or energy. These operators act on the wave function of a particle to determine its behavior and properties.
How are simultaneous eigenstates useful in quantum mechanics?
Simultaneous eigenstates are useful in quantum mechanics because they allow us to determine the precise values of multiple physical properties of a particle at the same time. This is important for understanding the behavior and interactions of particles on a quantum level.
What are some examples of simultaneous eigenstates in quantum mechanics?
Some examples of simultaneous eigenstates include the energy and angular momentum states of an electron in an atom, or the position and momentum states of a particle in a harmonic oscillator potential. These states have well-defined values for both properties simultaneously.
