Quantum Mechanics, The Delta-Function potential
In summary, the potential has a minimum at x=0, and the only bound state solutions are those with k=\frac{m \alpha}{\hbar^2}.
eliUCV
Hi, I have a question, why when we study the Delta-Function Potencial we can treat with ##E < V##, since the following relation says
##\frac{d^2 \psi}{dx^2} = \frac{2m}{\hbar^2} (V - E) \psi##
And do not allow it? or it is just ##E < V_{min}## ?
Likes eliUCV and Mentz114
Thanks :D
## V(x) = - \alpha \delta(x) ## where ## \alpha > 0 ##
I think it is important to say that it is time-independent Schrodinger's Equation
Yep. Exactly matches the treatise in the link. One bound state.
For ##\ V(x) = - \alpha \delta(x) \ ## there is no ##V_{min}\ ## so no ## E < V_{min}\ ##; did you mean ## E < V_{max}##, in this case 0 ?
Likes eliUCV
Yes, could E be less than V_max ?
V max is zero. E is less, yes: a bound state
Ok, but E never can be less than ## V_{min}## for any ##V(x)##, right??
Correct.
Since in
$$\hat{H}=\frac{1}{2m} \hat{p}^2 + V(\hat{x}),$$
the first term ("kinetic energy") it's a positive definite operator. For the very artificial potential in question, somewhat sloppily speaking the potential has a minimum at ##x=0## (namely "##-\infty##") there. The energy eigenvalues thus must all be ##>-\infty##, which is hardly a constraint.
To get the eigenvalues you have to solve the time-independent Schrödinger equation,
$$-\frac{\hbar^2}{2m} u_E''(x) -\alpha \delta(x) u_E(x)=E u_E(x).$$
For bound states you need ##E<0##, but for ##E<0## the only solution must be of the form
$$\psi(x)=A \exp(-k|x|), \quad k>0.$$
Now
$$\psi'(x)=-A k \mathrm{sign}(x) \exp(-k |x|)$$
and
$$\psi''(x)=[A k^2 -2 A k \delta(x)] \exp(-k |x|).$$
Plugging this into the Schrödinger equation we get (cancelling the common A exp factor)
$$-\frac{\hbar^2}{2m} [k^2 - 2 k \delta(x)]-\alpha \delta(x)=E.$$
So the only bound-state solution is to make the ##\delta## distribution contribution vanish by choosing
$$\frac{\hbar^2}{m} k = \alpha \;\Rightarrow \; k=\frac{m \alpha}{\hbar^2}.$$
From this we get
$$E=-\frac{\hbar^2}{2m} k^2 = -\frac{m \alpha^2}{2 \hbar^2}.$$
Of course there are plenty of scattering solutions with ##E>0## too.
Likes eliUCV
Related to Quantum Mechanics, The Delta-Function potential
1. What is Quantum Mechanics?
Quantum Mechanics is a branch of physics that studies the behavior and interactions of particles on a microscopic scale, such as atoms and subatomic particles. It describes the fundamental principles that govern the behavior of these particles and their interactions with each other and with energy.
2. What is the Delta-Function potential?
The Delta-Function potential is a mathematical function used in quantum mechanics to model a potential energy barrier that is infinitely high and thin. It is often used to represent a point-like particle or a localized potential in a system.
3. How is the Delta-Function potential used in Quantum Mechanics?
The Delta-Function potential is used in quantum mechanics to solve problems involving a particle interacting with a potential barrier or well. It allows for the calculation of the wave function and energy levels of the particle in these situations.
4. What are the applications of the Delta-Function potential?
The Delta-Function potential has various applications in quantum mechanics, including in the study of scattering processes, tunneling phenomena, and bound states. It is also used in fields such as solid-state physics and nuclear physics to model the behavior of particles in potential wells and barriers.
5. What are the limitations of using the Delta-Function potential in Quantum Mechanics?
While the Delta-Function potential is a useful mathematical tool in quantum mechanics, it has its limitations. It is a simplified model that does not accurately represent all types of potential barriers and does not take into account the effects of quantum tunneling. In some cases, more complex potential functions may be necessary for a more accurate description of a system.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
