Quantum mechanics , total orbital angular momentum?
In summary: What are the possible values for this observable? How does this relate to the values of ##l## and ##m##? In summary, the total orbital angular momentum for a hydrogen atom in a state with n=4 and the largest permitted value of l is given by ##\vec{L}^2=l(l+1)\hbar^2##. The allowed values for l are 3, 2, and 1, and the allowed values for m when l is at its largest value are 3, 2, 1, 0, -1, -2, and -3. The total orbital angular momentum is the sum of all Lz, and its magnitude is represented by ##\vec{L}
Outrageous
374
A hydrogen atom is identified as being in a state with n=4. What is the magnitude of the total orbital angular momentum for the largest permitted value of l?
n>l, l is bigger or equal to m
The allowed l= 3,2,1
The allowed m for largest l= 3,2,1,0,-1,-2,-3
Total orbital angular momentum is the sum of all Lz or L^2?
Ans, total= 3+2+1+0 +(-1)+(-2)+(-3)=0?
L^2= 3(3+1)hbar
What is the total orbital angular momentum?
Please guide ,thanks
L^2= 3(3+1)hbar
Read your textbook and notes and answer the following questions:
  1. What does ##\vec{L}^2## physically represent?
  2. What about ##L_z##?
  3. How are ##l## and ##m## related to ##\vec{L}^2## and ##L_z##?
##\vec{L}^2## mean the angular momentum square
##L_z## angular momentum in z direction
##\vec{L}^2##=l(l+1)\hbar and ##L_z##=m\hbar.
Total orbit angular momentum is j?
J=l-(1/2) or l+(1/2)
##\vec{L}^2=l(l+1)\hbar## and ##L_z=m\hbar##.
That should be ##\vec{L}^2=l(l+1)\hbar^2##. Total orbital angular momentum means not just the z-component. ##m## and ##l## are quantum numbers, not angular momenta.
The key word here is orbital. Which observable corresponds to orbital angular momentum?
I would first clarify the question to ensure I understand it correctly. It seems that the question is asking for the magnitude of the total orbital angular momentum for a hydrogen atom with a principal quantum number (n) of 4 and the largest possible value of the angular momentum quantum number (l).
In this case, the allowed values of l are 3, 2, and 1, as you correctly stated. However, the allowed values of m depend on the value of l. For l=3, the allowed values of m are -3, -2, -1, 0, 1, 2, and 3. So the total orbital angular momentum would be the sum of the angular momentum for each allowed value of m, which is 0 in this case.
The formula for the total orbital angular momentum is L = √(l(l+1))ħ. Plugging in the largest allowed value of l, which is 3, we get L = √(3(3+1))ħ = √12ħ = 2√3ħ. Therefore, the magnitude of the total orbital angular momentum for a hydrogen atom in the state with n=4 and the largest allowed value of l is 2√3ħ.
Related to Quantum mechanics , total orbital angular momentum?
1. What is quantum mechanics?
Quantum mechanics is a branch of physics that describes the behavior of particles at a microscopic level. It deals with the principles of uncertainty and probability, and is used to explain the behavior of subatomic particles such as electrons, protons, and photons.
2. What is total orbital angular momentum in quantum mechanics?
Total orbital angular momentum is a property of a quantum system that describes the total amount of rotational motion of all particles within the system. It is a combination of the individual orbital angular momenta of each particle and is quantized in discrete units.
3. How is total orbital angular momentum measured in quantum mechanics?
Total orbital angular momentum can be measured using the quantum mechanical operator L^2, which represents the square of the total angular momentum. The eigenvalues of this operator correspond to the possible values of total orbital angular momentum for a given system.
4. What is the significance of total orbital angular momentum in quantum mechanics?
Total orbital angular momentum is an important quantity in quantum mechanics as it can determine the energy states and allowed transitions of a system. It also plays a crucial role in understanding the magnetic properties of materials and the behavior of atoms and molecules.
5. Can total orbital angular momentum be changed in a quantum system?
Yes, total orbital angular momentum can be changed through interactions with external forces or other particles. However, the total amount of angular momentum in a closed system remains constant, in accordance with the law of conservation of angular momentum.
9K
