Quantum Numbers and Valence Electrons
In summary, this conversation discusses the application of quantum numbers to Cl's electrons and the determination of valence electrons for a ground state oxygen atom based on given quantum number values. The first question raises the issue of the missing n = 3 electrons in Cl's electron configuration, which can be explained by considering only the "core" electrons. The second question involves understanding the relationship between magnetic quantum numbers and orbital orientation for different subshells to determine the correct number of valence electrons for oxygen.
Qube
1) Apparently it's a true statement that the quantum numbers 2, 0, 0, 1/2 can apply to any of Cl's electrons. But chlorine's electron configuration is [Ne]3s^2 3p^5. What happened to the n = 3 electrons?
2) How many valence electrons can a ground state oxygen atom have with the quantum numbers m_l = 0 and m_s = +1/2? Those are the m-sub-l (magnetic) and spin quantum numbers, respectively.
For l = 0, m_l can only = 0.
For l = 1, m_l can equal -1, 0, or 1.
l = 0 corresponds with subshell s
l = 1 corresponds with p.
For the first question, I'm thinking the question is only considering "core" electrons without explicitly stating it as such.
Second question: oxygen has 6 valence electrons. 2 are in its 2s subshell. Four are in its 2p subshell. Exactly half the electrons of each subshell have a spin of +1/2. The other two electrons have opposing spins.
The question only specifies that m_l = 0. That means l = 0 or 1. Both the s and p subshells must be considered. In that case there are 4 electrons that fulfill the criteria of having m_l = 0 and a spin of +1/2. One electron from the s subshell, and 3 from the p subshell. The key says 2, however.
Okay scratch that about question 2. I see what I did wrong. Key is correct. Magnetic quantum numbers correspond to the orientation of an orbital; for the s orbital it's spherical so there's only one orientation. P orbitals have three orientations, Px, Py, and Pz. m_l = 0 specifies exactly one of these orbitals.
Related to Quantum Numbers and Valence Electrons
1. What are quantum numbers?
Quantum numbers are a set of four values that describe the state of an electron in an atom. They are used to predict the energy, location, and orientation of an electron within an atom.
2. What is the purpose of quantum numbers?
The purpose of quantum numbers is to accurately describe the properties and behavior of electrons in an atom. They allow scientists to predict the electronic structure and chemical properties of elements.
3. How many quantum numbers are there?
There are four quantum numbers: principal quantum number (n), azimuthal quantum number (l), magnetic quantum number (m), and spin quantum number (s).
4. What is the relationship between quantum numbers and valence electrons?
Valence electrons are the outermost electrons in an atom, and they are described by the quantum numbers. The principal quantum number determines the energy level of the valence electrons, while the other three quantum numbers determine the shape, orientation, and spin of the orbitals that the valence electrons occupy.
5. How do quantum numbers relate to the periodic table?
The periodic table is organized based on the electronic structure of elements, which is determined by the quantum numbers. The number of valence electrons and their arrangement in orbitals can be predicted using the quantum numbers, allowing elements to be placed in the correct groups and periods on the periodic table.
  • Atomic and Condensed Matter
  • Quantum Physics
