Quantum - Postulate of getting specific momentum p = |A_p|^2
In summary, the postulate states that in quantum mechanics, the momentum \( p \) of a particle is related to the square of the amplitude \( |A_p|^2 \) in momentum space. This relationship indicates that the probability of finding a particle with a specific momentum is proportional to the square of the wave function's amplitude associated with that momentum, emphasizing the probabilistic nature of quantum measurements.
laser
104
See description
See description
The first equation states that every wavefunction can be written as a sum of wavefunctions of definite momentum, with A_p being defined as the coefficients in the expansion such that when you take the |wavefunction|^2 it equals 1 - fine.
We then multiply by the wavefunction conjugate and integrate, and using some Kronecker delta trickery we get an expression for A_p. - I'm also okay with this.
But then we say that P(p) = |A_p|^2 is a postulate... From my experience in maths/physics, postulates should be "facts". But here we see that A_p came from somewhere... why are the coefficients in the expansion related to the probability of finding a certain momentum? Is this just experimentally observed and we take it to be true?
Please let me know how you think about this, as I feel like I am thinking of the notion of a "postulate" wrongly.
You have
$$\psi(x)=\sum_l A_l ~\psi_l(x)$$ It follows that $$\psi^*(x)=\sum_m A_m^* ~\psi_m^*(x)$$Now suppose you consider $$\int_0^L \psi(x)\psi^*(x)dx~,$$ substitute from above and use some more Kronecker delta trickery. What do you get?
Firstly, I am not sure why you changed the subscripts when going to the wavefunction conjugate.
Also, the equation you asked me to consider is the same one in my image! So I will get A_m. But I don't see how that answers my question.
Because they are two different summations and anyway the indices are dummy.
It is not the same. Take a second careful look. Like I said, what happens when you substitute the summations with two different indices in the equation that I asked you to consider.
Likes laser
Ah okay I see. You get the sum over m of |A_m|^2
which is equal to the above image.
As it turns out, the above image is also equal to the probability density over all the space = 1! (from another postulate)
This leads to another question: why is |A_p|^2 = probability density a postulate as well as the |wavefunction|^2 = probability density? Surely just one of them being a postulate is enough!
The postulate is
$$\int_0^L \psi(x)\psi^*(x)dx=1.\tag{1}$$
Please provide the exact statement of the problem as was given to you and how "postulate" is mentioned in it. Note that $$\sum_p |A_p|^2=1$$ is another way of saying the same thing as equation (1).
kuruman said:
The postulate is
I'm just reading some notes, it says that equation (1) is a postulate, but it also said that the sum of |A_p|^2 = 1 is also a postulate. Probably just a mistake in the notes, as either postulate can be used to derive the other!
Source: https://oyc.yale.edu/sites/default/files/notes_quantum_9.pdf page 21 equation (34)
I wouldn't worry about it.
Likes laser
FAQ: Quantum - Postulate of getting specific momentum p = |A_p|^2
What does the postulate of getting specific momentum p = |A_p|^2 mean?
This postulate refers to the probabilistic interpretation of quantum mechanics, where |A_p|^2 represents the probability density of finding a particle with a specific momentum p. Here, A_p is the wave function associated with momentum p, and the square of its amplitude gives the likelihood of measuring that momentum in an experiment.
How is the wave function related to momentum in quantum mechanics?
The wave function in quantum mechanics is a mathematical function that encodes the probabilities of finding a particle in various states. In the momentum representation, the wave function is expressed in terms of momentum variables, and its squared magnitude, |A_p|^2, gives the probability density for measuring the particle's momentum. This is a key aspect of the wave-particle duality in quantum mechanics.
What is the significance of the probabilistic nature of momentum in quantum mechanics?
The probabilistic nature of momentum highlights the fundamental departure of quantum mechanics from classical mechanics. In classical physics, momentum can be precisely defined and measured. However, in quantum mechanics, due to the Heisenberg uncertainty principle, we can only assign probabilities to different momentum values, reflecting the inherent uncertainties in measuring quantum states.
How does one calculate the probability of measuring a specific momentum?
Can the momentum wave function change over time?
Yes, the momentum wave function can change over time according to the time-dependent Schrödinger equation. As the system evolves, the wave function may exhibit interference and other dynamic behaviors, leading to changes in the probability distributions for momentum. This time evolution is a core aspect of quantum mechanics and can be analyzed using techniques such as Fourier transforms to relate position and momentum representations.
