BillKet
- 313
- 29
Hello! I have two energy levels of opposite parity close by (we can assume they are far from all the other levels in the system) and an off-diagonal term in the 2x2 matrix Hamiltonian that weakly couples them. I initially populate only one parity state, say the positive one, and after a while some population transfers to the other state. Finally, using a 2-step resonant ionization, such that the first step is parity selective (i.e. the ionization happens only from the initially unpopulated state - the negative parity one), I can test if the transition of population took place (in principle I do this many times and from there I extract the off-diagonal term). Let's assume for concreteness (the numbers are really arbitrary) that in 10 ms, I would transfer 10% of the population to the negative parity state and in 20 ms, I would transfer 20% of the population. I have 2 questions:
1. Let's say that my ionization probability (if I were to be 100% in the negative parity state), as well as my ion detection probability are 100%. Let's say that after 10 ms I send my lasers to try to ionize the system (I have 10% chance of doing so), and I don't detect an ion. I wait 10 ms more, and I try again. What will the probability of ionizing be after 20 ms? If I were to not try to ionize after 10 ms, the probability would be simply 20%, but as I tried after 10 ms, did that measurement act as a projection operator, thus reseting my system back to being 100% in the positive parity state, hence the probability after 20 ms would still be only 10%?
2. My questions is the same as the first one, but this time let's assume that the ionization probability is smaller than 100%. In this case, my measurement is not a fully quantum projection operator. What would be the probability of seeing an ion after 20 ms, if I don't see one after 10 ms?
Thank you!
Thank you!
