Quantum states as L^2 functions
In summary: Once interactions are present, the decomposition is lost and the dynamics cannot be described in terms of a single-particle wavefunction. This is because the Hilbert space for interacting theories is not a direct sum of single-particle Hilbert spaces. Instead, it is a Fock space, which is a different type of Hilbert space that does not have a direct particle interpretation.
schieghoven
85
Hello,
What is a quantum state? Put generalised functions/Schwartz distributions to one side, because a) they're not a Hilbert space, and b) they can't be multiplied, so it's hopeless to even begin to think about Feynman diagrams.
One-particle quantum states seem to be fairly well understood. The state of the system is a function [itex] \psi: \mathbb{R}^3 \rightarrow \mathbb{C} [/itex], and [tex]|\psi(x)|^2[/tex] gives the probability density of finding the particle near the space point x. Let's denote by [itex] \Omega_1 [/itex] the space of one-particle states. [itex] \Omega_1 [/itex] is a Hilbert space with inner product
[tex]
\langle \psi, \phi \rangle = \int d^3x \; \psi^*(x) \phi(x) \qquad \qquad (1)
[/tex]​
This Hilbert space is known as [itex]L^2(\mathbb{R}^3)[/itex]. The states [tex]\psi, \phi \in \Omega_1[/tex] evolve in time according to an equation of motion, and the the inner product (1) is constant in time. Equivalently, the system evolves by a unitary transformation on [itex] \Omega_1 [/itex].
Building on this, an n-particle state [tex] \psi [/tex] is presumably a function of n space points (x1, x2, ... xn). Assume Bose symmetry, so [tex] \psi [/tex] is totally symmetric with respect to x1, x2, ... xn. So in this case [itex] \psi: (\mathbb{R}^3)^n \rightarrow \mathbb{C} [/itex] and [tex]|\psi(x_1, x_2, \ldots, x_n)|^2[/tex] gives the probability density of finding the n particles near the space points x1, x2, ..., xn. The set [itex] \Omega_n [/itex] of all n-particle states has a canonical inner product
[tex]
\langle \psi, \phi \rangle = \frac{1}{n!} \int d^3x_1 \ldots d^3x_n \;
\psi^*(x_1, \ldots, x_n) \phi(x_1, \ldots, x_n)
[/tex]​
and is a Hilbert space. So far so good. This is not just rigorous - L^2 spaces are stock concepts in pure math - but it's readily understandable as well. States have a direct physical interpretation at all times, not just at asymptotic [itex] t \rightarrow \pm \infty [/tex]. So is it possible to formulate field theory from this standpoint? In field theory, particle number changes with time, so let's suppose the set of all states is
[tex]
\Omega = \mathbb{C} \oplus \Omega_1 \oplus \Omega_2 \oplus \ldots
\oplus \Omega_n \oplus \ldots
[/tex]​
(The C is for the vacuum.) Is it possible to define the dynamics of the system in terms of an equation of motion for the n-particle 'wavefunctions'? Would this be another route towards constructing the Feynman series?
Cheers,
Dave
[tex]
[/tex]​
Cheers,
Dave
In general no. The Hilbert space in quantum field theory only has a decomposition as a tower of particle states for the free theory alone.
Related to Quantum states as L^2 functions
1. What are quantum states as L^2 functions?
Quantum states as L^2 functions are mathematical representations of the possible states of a quantum system. They describe the probability amplitudes of different outcomes for a given measurement and are essential in understanding the behavior of quantum systems.
2. How are L^2 functions related to quantum mechanics?
L^2 functions are a fundamental concept in quantum mechanics. They are used to describe the wave-like behavior of particles and the probabilities of different outcomes in quantum systems. L^2 functions are also used in the Schrödinger equation, which is a key equation in quantum mechanics.
3. Can you give an example of a quantum state as an L^2 function?
One example of a quantum state as an L^2 function is the wave function of a single particle in a one-dimensional box. This function describes the probability amplitude of finding the particle at a specific position within the box.
4. How do L^2 functions differ from classical functions?
L^2 functions differ from classical functions in that they can take on complex values and represent the probability amplitudes of quantum states. Classical functions, on the other hand, typically take on real values and represent physical quantities such as position or velocity.
5. Are there any limitations to using L^2 functions in quantum mechanics?
While L^2 functions are a powerful tool in quantum mechanics, they have some limitations. For example, they cannot fully describe the behavior of systems with multiple particles or particles with spin. In these cases, more advanced mathematical tools, such as tensor products, are needed to fully describe the quantum states.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
