Graduate Quantum statistical canonical formalism to find ground state at T
The discussion focuses on computational methods for solving a spinless fermionic Hamiltonian using the Quantum Canonical Ensemble formalism. The user aims to calculate the ground state energy and wave function at various temperatures but encounters issues with extremely high values of beta at room temperature, leading to difficulties in obtaining meaningful results. It is clarified that the ground state energy and wave function are intrinsic properties of the Hamiltonian and do not change with temperature; however, the occupancy probabilities of these states do vary with temperature. The density matrix formulation allows for the calculation of expectation values, but the ground state is fundamentally defined at zero temperature. The conversation emphasizes the distinction between the static properties of the ground state and the dynamic behavior of the system at finite temperatures.
Luqman Saleem
TL;DR
As an example, calculating the ground state energy and wave function using canonical formalism of a simple fermionic model.
For my own understanding, I am trying to computationally solve a simple spinless fermionic Hamiltonian in Quantum Canonical Ensemble formalism . The Hamiltonian is written in the second quantization as
$$H = \sum_{i=1}^L c_{i+1}^\dagger c_i + h.c.$$
In the canonical formalism, the density matrix is given as
$$\rho = \frac{e^{-\beta H}}{Tr [e^{-\beta H}]}$$
where ##\beta = 1/k_B T## and the expectation value of any operator ##A## is given as
$$\langle A \rangle = Tr[\rho A]$$
Things that I want to calculate:
1. ground state energy at temperature ##T##
2. ground state wave-function at ##T##
My attempt to solution:
1. I first write ##H## in matrix form by using particle number basis i.e. 1100, 1010 ##\cdots## for 4 sites and 2 particles
2. then I diagonalize ##H## and find energy eigenvalues ##E_i## and eigenvectors ##\psi_i##
3. then I write ##\rho## by using above given formula
4. finally, I try to calculate ground state energy using ##\langle H \rangle = Tr[\rho H]##
Problems I am facing:
As Boltzmann constant ##k_B## is ##1.36\times 10^{-23}##, so even at room room temperature ##\beta## is very large i.e. ~##10^{21}##. Due to which I can't calculate ground state energy at very low temperatures? Computer just give 'Infinity' values. And at very large temperatures, the energy seems to be decreasing with increasing ##T##. ... totally wrong
Questions:
1. Is my algorithm correct? How can we calculate ground state energy at ##T=0## and at small temperatures?
2. How to calculate ground state wave function at ##T##?
Is the temperature relevant to defining the ground state energy and wave function? Isn't the ground state defined at T=0?
Likes Luqman Saleem
At T=0, ground state is defined. I was just wondering how does statistical mechanics' formalism deal with this case. And I got the answer, I mean at T=0, ##\rho = I##, which means ##\langle H \rangle = \langle I H \rangle = \langle H \rangle##.
And I would say that ground state energy is relevant to temperature. Does not ground state energy increase with the increase in temperature?
The ground state and the ground state energy do not change with temperature. The ground state is a property of the Hamiltonian, and is the state with the lowest energy.
The probability with which the ground state and other states are occupied changes with temperature.
In the canonical ensemble at finite T, each member of the notional canonical ensemble of systems is in a different state. The distribution of states across the members of the ensemble is given by the density matrix of the canonical ensemble. Roughly, one can think that the probability of a given state in the canonical ensemble is given by p(E) ∝ exp(-βE).
You can find an example in https://en.wikipedia.org/wiki/Canonical_ensemble. See the right side of the figure titled "Example of canonical ensemble for a quantum system consisting of one particle in a potential well."
You can also see section 6.5 of https://mcgreevy.physics.ucsd.edu/s12/lecture-notes/chapter06.pdf for an example of the distribution of states at finite T in the canonical ensemble for the quantum harmonic oscillator.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 19 ·
  • · Replies 0 ·
  • · Replies 16 ·
