Quantum teleportation from a Curious 10 year Old
In summary, particles can't teleport for thousands of miles, but this might be possible in the future with more research.
Jacques Marrot
My brother and I are thinking about the problem that NASA has with sending signals to Mars rovers, and quantum teleportation, is in an instant, therefor we thought you could use that, so we just have a few questions for you. We know this is not possible, since particles can’t teleport for thousands of miles, but just what are those limits? Furthermore, there is only photon teleportation, but this would require electron teleportation, so when might this be possible (I know it is likely a few decades). Thank you so much for your time, and I hope to get a reply soon.
Likes vanhees71
There is no distance limit, and you can do this with all particles, not just photons. But to teleport something you always have to send a signal that travels with at most the speed of light - typically this signal is light, then it travels at the speed of light. It doesn't speed up communication at all.
Likes vanhees71
Quantum teleportation doesn't actually teleport an object. It only transfers the state of an object to another (identical) object.
I think that the information of a quantum state can be teleported with the current technology.
The information of an quantum state can be viewed as infinite complex numbers.
However, an object contains infinitely many atoms. There are infinitely many quantum states.
If we want to teleport a person, all the information should be teleported, such as the information of individual atoms, the information of there connections.
On the other hand, to finish the goal of teleportation, the sender should tell the classical information to the receiver.
Then at least, the people in Mars should have a phone...
No, an object only contains finitely many atoms.
Likes bhobba
Yes, you are right. It is finitely many. But the number may be larger than 10000000000. In the current technology, we can faithfully teleport the 'quantum information (a|0\rangle+b|1\rangle)' of several particles, not the particles themselves. The following expression is wrong: the atoms at one side (A) disappear then appear at another side (B). The correct one is the following: the state of the atoms (A) changes and we can recover the state of the atom by acting some operation on the atom at another side. What operation should we operate? It is dependent on
measurement result at the side (A). That is to say, a 'telephone' should exist between (A) and (B). Then the person at the side (B) can get the information and do the right operation.
I think it is an interesting question philosophically. Suppose that all the atoms of Alice are identical with the atoms of Bob. Are they the same person? If they are the same person, can we develop a technique to copy the state of Alice? Maybe these questions are interesting in fiction.
These two things are exactly the same in quantum mechanics. The quantum state is everything that defines a particle or set of particles (apart from the particle types, but they are obviously chosen to be identical).
No-cloning theorem. You cannot copy the state exactly (in general).
If you are just interested in the philosophical questions you don't need an exact quantum copy. Reproducing the molecules would be sufficient, and these can be copied.
Furthermore, there is only photon teleportation.
No, photons are not the only particles that can be “teleported” electrons can. Day that you actually could teleport a electron that far you would already need electron(s) there, and depending on how many there are the Pauli Exclusion Principle could easily get in the way. Although, depending on how many electrons there are, it could be very difficult to detect the single sending particle.
Related to Quantum teleportation from a Curious 10 year Old
1. What is quantum teleportation?
Quantum teleportation is a process in which information (such as the state of a particle) is transferred from one location to another, without the physical movement of the particle itself. This is made possible by exploiting the principles of quantum entanglement and superposition.
2. How does quantum teleportation work?
In quantum teleportation, two particles become entangled, meaning that their states are correlated and dependent on each other. When one of the particles is measured, its state is instantaneously transferred to the other particle, no matter how far apart they are. This allows information to be teleported from one location to another.
3. Is quantum teleportation like sci-fi teleportation?
No, quantum teleportation is quite different from the teleportation seen in science fiction movies. While sci-fi teleportation involves physically moving an object from one place to another, quantum teleportation only transfers information about the object's state.
4. What is the potential use of quantum teleportation?
Quantum teleportation has potential applications in quantum computing, cryptography, and long-distance communication. It could also be used in teleporting quantum states of particles for experiments and research purposes.
5. Can humans be teleported using quantum teleportation?
Currently, there is no evidence to support the possibility of teleporting humans using quantum teleportation. The process only transfers information about the state of a particle, not the physical body. It is also important to note that quantum teleportation is still in its early stages of development and a lot more research is needed before any practical applications can be considered.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
15K
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
