Quantum Tunneling and atomic spectra.
In summary, quantum tunneling is the phenomenon where particles can pass through a potential barrier, despite classical mechanics suggesting it is impossible. The energy levels in the barrier are discrete and determined by the Schrödinger equation. The Pauli exclusion principle allows for only two electrons with opposite spins per energy level, unless the level is degenerate. In atomic spectra, more than two electrons with opposite spins can fit into the second and subsequent energy levels due to the different energy states being slightly lifted by additional effects.
misogynisticfeminist
370
Can somebody explain quantum tunneling to me? And the thing about why amplitudes when they are trapped, the energies must choose from a distinct set of values? And why when particles that are totally free to wander will have any energy that they like?
Also, why in the atomic spectra, more than two electrons with opposite spins can fit into the second and subsequent energy levels? How many electrons can fit into each level? And why is this so?
Also, why in the atomic spectra, more than two electrons with opposite spins can fit into the second and subsequent energy levels? How many electrons can fit into each state? And why is this so?
Tunneling is the fenomenon in QM that some particles can get through a potential barrier. In classical mechanics this is impossible because the particles would require negative kinetic energy to do so. This implies negative mass-values.
In the barrier there is a discrete set of possible energyvalues, yes. this is proven by solving the Schrödingerequation in such a barrier. The energy-levels have to be discrete or otherwise the wavefantion of the particle cannot be finite, thus unfysical.
Only two electrons with opposite spin per energylevel !
The reason for this is the Pauli-exclusionprinciple that states that no two particles with the exact same set of quantumnumbers can be found in the same QM-state. This condition is necessary because the wavefunctions of baryons and leptons like electrons (matter) are antisymmetric.
I can give you exact calculations if you wa,t, though they can be found in any standard QM-textbook
regards
marlon
Except if the energy level is degenerate of course...
I think the OP was well aware of the above and wondered why you can have MORE than 2 electrons per energy level. In the simple coulomb hydrogen atom (no LS couplings or whatever), for energy level n (1, 2, 3...), you can have a value of l from 0 to n-1 and for each value of l you can have a value of m from -l to l. The THREE numbers (n, l , m) specify an ENERGY STATE (without spin). However, only the first number determines the ENERGY LEVEL (the value). When such a thing happens, we talk of degeneracy (many different states correspond to the same value). The Pauli exclusion principle only allows 2 electrons (spin up and spin down) per STATE. But as (except for n = 1) you can have several states for the same value, you can have more than 2 electrons per energy value.
Now, one should add that when you take more effects into account than just the electrostatic potential, such as the magnetic coupling of the electron spin to the E-field (because the electron moves), the spin-spin coupling between nucleus and so on... it turns out that a lot of the degeneracy is lifted: the different energy states which, for the coulomb interaction, had the same energy level start to have slightly different values.
cheers,
Patrick.
Related to Quantum Tunneling and atomic spectra.
1. What is quantum tunneling?
Quantum tunneling is a phenomenon in which a particle can pass through a potential barrier even though it does not have enough energy to do so. This is possible due to the probabilistic nature of particles at the quantum level.
2. How does quantum tunneling relate to atomic spectra?
Quantum tunneling plays a crucial role in determining the energy levels and transitions of electrons in an atom. It allows electrons to move between energy levels even though they do not have enough energy to overcome the potential barrier between them.
3. What factors influence the probability of quantum tunneling?
The probability of quantum tunneling is influenced by the thickness and height of the potential barrier, as well as the mass and energy of the particle attempting to tunnel through. The uncertainty principle also plays a role, as the more precisely the position of a particle is known, the less likely it is to tunnel through a barrier.
4. How is quantum tunneling observed and measured?
Quantum tunneling can be observed and measured through various experimental techniques, such as scanning tunneling microscopy and tunneling spectroscopy. These methods involve passing a current through a potential barrier and measuring the resulting tunneling current.
5. What practical applications does quantum tunneling have?
Quantum tunneling has numerous practical applications in fields such as electronics, nanotechnology, and quantum computing. It allows for the creation of tunnel diodes, which are crucial components in electronic devices, and also plays a role in the operation of flash memory and magnetic read heads in hard drives.
