Quantum Tunneling of a conduction electron in Copper
In summary, an electron moving through a block of Cu will experience a strong force at the surface due to the nonuniform charge distribution. This force causes the electron to remain bound to the metal. By using the wave function and probability of tunneling equations, the penetration depth of the electron outside the Cu block can be calculated as Δx = ħ/(2sqrt(2m(V-E))). The work function of the metal, which is 4 eV, can be used to obtain the energy of the electron (E) needed for the calculation. The work function represents the minimum energy required for the electron to escape the metal, so it can be subtracted from the potential energy (V) to obtain E.
Philolaus_
A conduction electron moves through a block of Cu until it reaches the surface. At the surface the electron feels a strong force exerted by the nonuniform charge distribution in that region. This force tends to attract the electron back into the metal which is what causes the conduction electron to remain bound to the metal. Given that the work function of the metal is 4 eV estimate the distance x that the electron can penetrate outside of the Cu block.
Wave function = Ψ(x) = De^(-kx)
Probability of tunneling = P = |Ψ(x)^2
Wave number k = sqrt(2m(V-E))/ħ
I am confident on how the penetration depth is calculated as it can be calculated using the following steps;
Compare probability at x=0 and x = Δx where Δx is the point where the probability of finding a particle is 1/e of its original value.
This gives;
1/e * |Ψ(0)|^2 = |Ψ(Δx)|^2
D^2e^(-2k*0) * 1/e = D^2e^(-2k(Δx))
1/e = e^(-2k(Δx))
-1 = -2k(Δx)
Δx = 1/2k
We know the potential is 4eV from the question, but I don't know how the energy of the electron, E, is obtained and any help on where the value for E would be appreciated..
Thank you in advance.
Hint: what does the work function tell you?
(Not the depth of the potential well.)
Related to Quantum Tunneling of a conduction electron in Copper
1. What is quantum tunneling?
Quantum tunneling is a phenomenon in which particles are able to pass through barriers that would normally be impenetrable according to classical physics. This is possible because at the quantum level, particles do not behave like solid objects with defined positions, but rather as waves with a probability of being found in a certain location.
2. How does quantum tunneling occur in a conduction electron in copper?
In copper, conduction electrons are able to tunnel through the potential barrier created by the crystal lattice of the metal. This is because the electrons have a certain amount of energy, known as the Fermi energy, which allows them to overcome the potential barrier and move through the crystal lattice.
3. What is the significance of quantum tunneling in copper?
Quantum tunneling in copper is important for the flow of electric current in conductors. It allows electrons to pass through the crystal lattice, making copper a good conductor of electricity. Without quantum tunneling, electrical conductivity in copper would be significantly reduced.
4. Can quantum tunneling be observed in everyday life?
Yes, quantum tunneling is a fundamental phenomenon that occurs in many aspects of our everyday lives. For example, it is essential for the operation of electronic devices such as transistors and flash memory. It also plays a role in chemical reactions and nuclear processes.
5. Are there any practical applications of quantum tunneling in copper?
Yes, quantum tunneling in copper has several practical applications. One of the most significant is in the development of quantum computing, which relies on the ability of particles to tunnel through barriers. It is also used in scanning tunneling microscopy, a powerful tool for studying the atomic and electronic structure of materials.
