Quantum Virial Theorem Derivation
In summary, the Quantum Virial Theorem relates the average kinetic and potential energies of a quantum system to its total energy. It is derived from the principles of quantum mechanics, specifically using the time evolution of a wave function and the expectation values of position and momentum operators. The theorem provides insights into the behavior of quantum systems in various potentials, demonstrating that for bound states, the average kinetic energy is proportional to the average potential energy, leading to a deeper understanding of quantum dynamics and stability.
flyusx
48
Using the time-dependence of an operator equation, show that ##\frac{d}{dt}\left\langle\hat{x}\hat{p}\right\rangle=2\langle\widehat{KE}\rangle-\left\langle x\frac{\partial V}{\partial x}\right\rangle##
$$\frac{d}{dt}\langle\hat{A}\rangle=\frac{i}{\hbar}\langle[\hat{H},\hat{A}]\rangle+\left\langle\frac{\partial\hat{A}}{\partial t}\right\rangle$$
Using the time derivative of an operator, and expanding out, I got to this:
$$\frac{d}{dt}\langle\hat{x}\hat{p}\rangle=\frac{i}{\hbar}\left\langle\left[\hat{H},\hat{x}\hat{p}\right]\right\rangle+\left\langle\frac{\partial}{\partial t}\left(\hat{x}\hat{p}\right)\right\rangle$$
Expanding using ##\langle\psi\vert\text{stuff}\vert\psi\rangle## and noting that the time derivative of ##\hat{x}\hat{p}=0## yields the following integral through all space:
$$\frac{i}{\hbar}\int\psi^{*}\left[\hat{H},\hat{x}\hat{p}\right]\psi\;dx$$
$$\frac{i}{\hbar}\int\psi^{*}\left(\hat{H}\hat{x}\hat{p}-\hat{x}\hat{p}\hat{H}\right)\psi\;dx$$
$$\int\psi^{*}\left(\left(-\frac{\hbar^{2}}{2m}\frac{\partial^{2}}{\partial x^{2}}+V\right)x\frac{\partial}{\partial x}-x\frac{\partial}{\partial x}\left(-\frac{\hbar^{2}}{2m}\frac{\partial^{2}}{\partial x^{2}}+V\right)\right)\psi\;dx$$
I have tried to simplify the stuff in between ##\psi^{*}## and ##\psi## (ie calculate the commutator between the Hamiltonian and xp) but I get the following, which is wrong:
$$2\left\langle\widehat{KE}\right\rangle-\left\langle x\frac{\partial V}{\partial x}\right\rangle+\left\langle Vx\frac{\partial}{\partial x}\right\rangle$$
The first two parts are correct, but the very last term is just...strange.
However, when I operate the derivatives on ##\psi##, simplify and then re-pull out the ##\psi##, I get the right answer. It appears that the extraneous term at the very right (with a random partial position derivative) gets cancelled out.
Could someone explain the difference? Is this just me not realising I have to operate on something first? Thanks.
First of all the momentum operator is ##\hat p=\dfrac{\hbar}{i} \dfrac{\partial}{\partial x}~## not what you have.
Secondly, it looks like you messed up the algebra and dropped a ##\psi## somewhere. You cannot end up with a dangling operator ##\frac{\partial}{\partial x}## when you start from the integral of function.
Here is a generous hint
First show that $$[\hat x,\hat H]=-\frac{\hbar}{i}\frac{\hat p}{m}~;~~[\hat p,\hat H]=+\frac{\hbar}{i}\frac{\partial V}{\partial x}$$then use it.
Also, remember that ##[AB,C]=A[B,C]+[A,C]B.##
The terms involving ##V## are $$\int \left[\psi^{*}Vx\frac{\partial \psi} {\partial x}-x\frac{\partial}{\partial x}\left(V \psi \right) \right]\;dx$$ Note the second term where the derivative acts on the product ##V \psi##.
The integral will reduce to ## \left\langle -x\frac{\partial V}{\partial x}\right\rangle##. So, your approach will yield the desired result.
However, it is very worthwhile to work it using @kuruman's approach.
I think @flyusx did use ##\hat p=\dfrac{\hbar}{i} \dfrac{\partial}{\partial x}~##, but the ##\dfrac{\hbar}{i}## was cancelled out by the factor ##\dfrac i \hbar## in front of the integral.
Likes kuruman
Yes, I don't know how I missed that.
Thanks all, I got the correct answer using kuruman's method.
In the future, when commutators are present inside of an integral, is it simply standard to operate them on the ψ instead of directly simplifying them?
Can you show an example of "directly simplifying"? I don't know what it means.
Yeah.
Originally, I tried to simplify the things in the brackets while ignoring ψ* and ψ, which yielded the incorrect answer:
$$\left(-\frac{\hbar^{2}}{2m}\frac{\partial^{2}}{\partial x^{2}}+V\right)x\frac{\partial}{\partial x}-x\frac{\partial}{\partial x}\left(-\frac{\hbar^{2}}{2m}\frac{\partial^{2}}{\partial x^{2}}+V\right)$$
$$-\frac{\hbar^{2}}{2m}\frac{\partial}{\partial x}\left(\frac{\partial}{\partial x}\left(x\frac{\partial}{\partial x}\right)\right)+Vx\frac{\partial}{\partial x}+\frac{\hbar^{2}}{2m}x\frac{\partial^{3}}{\partial x^{3}}-x\frac{\partial V}{\partial x}$$
$$-\frac{\hbar^{2}}{2m}\frac{\partial}{\partial x}\left(x\frac{\partial^{2}}{\partial x^{2}}+\frac{\partial}{\partial x}\right)+Vx\frac{\partial}{\partial x}+\frac{\hbar^{2}}{2m}x\frac{\partial^{3}}{\partial x^{3}}-x\frac{\partial V}{\partial x}$$
$$-\frac{\hbar^{2}}{2m}\left(x\frac{\partial^{3}}{\partial x^{3}}+2\frac{\partial^{2}}{\partial x^{2}}\right)+Vx\frac{\partial}{\partial x}+\frac{\hbar^{2}}{2m}x\frac{\partial^{3}}{\partial x^{3}}-x\frac{\partial V}{\partial x}$$
$$2\left(-\frac{\hbar^{2}}{2m}\frac{\partial^{2}}{\partial x^{2}}\right)+Vx\frac{\partial}{\partial x}-x\frac{\partial V}{\partial x}$$
Where there is the incorrect and extraneous term. Using your method or acting the 'central' stuff on ψ yielded the correct answer. I'm just confused as to why calculating the commutation between the Hamiltonian and the position/momentum and then using the commutation identity works while an issue arises when using the method above.
When simplifying a product of operators it's a good idea to consider how the product behaves when acting on an arbitrary state function ##\psi(x)##.
For operators ##A## and ##B##, $$(A \cdot B) \psi(x) \equiv A[B(\psi(x))].$$ Thus, $$\left( \frac {\partial}{\partial x} \cdot V(x) \right) \psi(x) = \frac {\partial}{\partial x} \left[ V(x) \psi(x) \right] =\frac {\partial V(x)}{\partial x} \psi(x) + V(x) \frac {\partial \psi(x)}{\partial x} .$$ This may be written as $$\left( \frac {\partial}{\partial x} \cdot V(x) \right) \psi(x) = \left[ \frac {\partial V(x)}{\partial x} + V(x) \frac {\partial }{\partial x} \right] \psi(x)$$ Since this is to hold for arbitrary ##\psi(x)##, we have the operator identity $$\frac {\partial}{\partial x} \cdot V(x) = \frac {\partial V(x)}{\partial x} + V(x) \frac {\partial }{\partial x}$$
As a little exercise, verify the important commutator ##[\hat x, \hat p] = i \hbar## where ##\hat x = x## and ##\hat p = - i \hbar\frac {\partial}{\partial x}##.
Likes kuruman
You can't do that. You start with an expectation value, which is a constant, and you propose to end up with an operator. It's like mixing birthday cakes and diesel engines.
Thanks. I've noticed that whenever I operate with respect to ψ, I get the correct answer.
