Quantum: why can't you square every operator?
In summary: If this is still not clear, let me rephrase again: In the above post, you have two operators:A = (a+b)^2 = (a+ + a-)^2B = (c+d)^2 = (-ip + mωx)^2For the operator A, you can FOIL it, and apply the result on ψ.For the operator B, you CANNOT FOIL it, and apply the result on ψ.
Aziza
190
In Griffiths book, he says (a+ + a-)2 = a+2 + a-2 + a+a- + a-a+.
Why can you NOT do the same thing for a+2 = (-ip+mωx)2 ?!
When I do this to find the 2nd excited state of SHO, it gives me wrong answer. I actually have to apply a+ two times to ψ0 in order to get ψ2. It is ridiculous that Griffiths does not mention at all why certain operators can be squared but others cannot. Could someone please elaborate on the difference between these two cases?
I hope you realize that squaring an operator means applying the operator twice.
In the case of
you are not applying it twice. You are squaring the operator and then applying that result on ψ. That is exactly what griffiths did.
By definition, ##A^2 = A \circ A## for some operator ##A## assuming that the domains agree (which is only a problem if ##A## is unbounded).
Let me elaborate: let ##\psi## be an arbitrary vector in the domain of ##(a_+ + a_-)##-we take for granted that the action of ##(a_+ + a_-)^2## is well defined on ##\psi##. Then, ##(a_+ + a_-)^2 \psi = (a_{+} + a_{-})[(a_{+} + a_{-})\psi] = (a_+ + a_-)[a_+ \psi + a_- \psi] = a_+^2 \psi + a_- a_+ \psi + a_+a_- \psi + a_-^2 \psi##.
you are not answering my question. sure, i can agree that in general, A^2=A*A. But that is not my question. My confusion is that for certain cases (idk if it depends on the operators involved or the wavefunction involved), you can directly FOIL A^2, as in the above example i already mentioned twice. My question is therefore, why can you FOIL certain operators, but not others.
Thus my question is, what is the difference between A and B that causes this asymmetry?!
What did you get when you tried foiling ##(-iP + m\omega X)^{2}## and acting on some vector?
Idk why we would take anything for granted, but either way, this is still not how griffiths did this. You are applying the operators twice on ψ. griffiths did not do this. He literally said that A^2 = (FOIL'ed A^2). THEN he applied this result on ψ. Thus from this example, I thought the message was that you can just FOIL operators.
Are you saying then that this procedure is always wrong? Or are there still certain operators that can be exponentiated before being applied?
I got the wrong answer when acting on the vector.
I FOIL'ed it as:
-h_bar^2 * (d^2/dx^2) + m^2ω^2x^2 - m*h_bar*ω*x*(d/dx) - m*h_bar*ω
I think the effective Socratic question here is to ask you what you think an operator is. I know relatively little about quantum physics, but math will always whisper answers in one's ear if you are willing to listen.
I FOIL'ed it as:
The last term you forgot that the product rule will be invoked. (d/dx) x is not just 1 because d/dx will also act on the state.
Aziza said:
Idk why we would take anything for granted...
It's a mathematical technicality. If ##A## is an unbounded operator then it's domain is not going to be the entire vector space so ##A\psi## need not be a vector in the domain of ##A## meaning ##A^2 \psi## will not be well defined if that happens.
You didn't foil correctly. You have to be extra careful when foiling because you're dealing with operators here. It should be ##(-iP + m\omega X)^2\psi(x) \\= (-iP)^2 \psi(x) + (m \omega X )^2\psi(x) - (im\omega PX)\psi(x) - (im\omega XP)\psi(x) \\= \hbar^2 \frac{\mathrm{d} ^2 \psi}{\mathrm{d} x^2} + m^2\omega^2 x^2 \psi - (m\omega \hbar \frac{\mathrm{d} }{\mathrm{d} x})(x\psi(x)) - m\omega \hbar x\frac{\mathrm{d} \psi}{\mathrm{d} x} \\= \hbar^2 \frac{\mathrm{d} ^2 \psi}{\mathrm{d} x^2} + m^2\omega^2 x^2 \psi - 2m\omega \hbar x\frac{\mathrm{d} \psi}{\mathrm{d} x} - m\omega \hbar \psi##
oohhhh! yes you are correct, thank you so much! so then i CAN exponentiate any operator, but i have to remember to immediately multiply by my function.
thank you!
thank you!
For clarity: Griffiths suggests that you do this whenever you compute a commutator. You can extend that rule of thumb to any operator computation: always use a test function for operator equations.
FAQ: Quantum: why can't you square every operator?
Why can't you square every operator in quantum mechanics?
In quantum mechanics, operators represent physical observables such as position, momentum, and energy. Not all operators can be squared because some operators, such as the position operator, do not have a well-defined square. This is due to the uncertainty principle, which states that it is impossible to know both the position and momentum of a particle with 100% certainty.
What happens if you try to square an operator in quantum mechanics?
If you try to square an operator in quantum mechanics, the resulting operator will not represent a physical observable. This is because squaring an operator essentially means applying the operation twice, which can lead to contradictory or nonsensical results.
Are there any operators that can be squared in quantum mechanics?
Yes, there are some operators that can be squared in quantum mechanics, such as the Hamiltonian operator which represents the energy of a system. However, not all operators can be squared and the ones that can have important physical implications.
How does the inability to square every operator affect quantum mechanics?
The inability to square every operator in quantum mechanics is a fundamental aspect of the theory and has important implications for the behavior of particles at the quantum level. It leads to the uncertainty principle and the probabilistic nature of quantum mechanics, where the exact position and momentum of a particle cannot be known simultaneously.
Is there a way to work around the inability to square every operator in quantum mechanics?
There are mathematical techniques, such as using raising and lowering operators, that can be used to manipulate operators in quantum mechanics without squaring them. However, the inability to square every operator is a fundamental aspect of the theory and cannot be completely avoided.
