Quartic eqn solutions for Cos/Sin
  • Thread starter Thread starter natski
The discussion focuses on finding special case solutions to the quartic equation x^4 + a x^3 + b x^2 + c x + d = 0 when x is expressed as Cos[theta]. Participants note that while Vieta's formulas provide properties of the roots, they may not simplify the equation effectively in this context. The half-angle identity is mentioned as a potential method to reduce the degree of the equation, but it introduces complexities with different cosine arguments. It is emphasized that if theta is a rational multiple of pi, x=cos(theta) is algebraic, while for irrational multiples, it becomes transcendental. Overall, the discussion highlights the challenges and limitations of simplifying quartic equations with cosine solutions.
natski
262
Hi all,
I am looking for a special case solution to the quartic equation x^4 + a x^3 + b x^2 + c x + d = 0 in the case where x = Cos[theta]. Are there are any special properties of the solutions? For example, I know there are numerous properties from Vieta's formula but none of these really help simplify things if x=cosine.
Natski
Mathematics news on Phys.org
Depends on what you want to do, I suppose. The half-angle identity
\cos^2a=\frac{1+\cos(2a)}{2}
could reduce the degree, but at the cost of introducing cosines of different arguments. This may have been what you were referring to as not useful, though; I'm not sure.
I don't see how it can be considered much of a special case if x=cos\theta. All you're saying here is that -1\leq x\leq 1 which really doesn't help a great deal.
x=cos(\theta) is algebraic if \theta is a rational multiple of pi. I.e. it is the zero of a polynomial of integer coefficients.
It can be shown that if \theta is not a rational multiple of pi, then x=cos(\theta) is transcendental and thus not the solution of any polynomial of algebraic coefficients.
I don't know... if the equation was 2ax^2-1=2a\cos^2(\theta)-1, I would consider \cos(2\theta) a simplification.
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation has no solutions with positive integers if It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
