Why Is Transfer Function Defined for Linear Systems Only?
In summary, a query in control system is a request for information or data from the system, and it is different from a command which is a directive to perform an action. There are two main types of queries - status and parameter queries - which are used in closed-loop control systems to monitor performance and make adjustments. Queries can also be used in real-time control systems to continuously monitor and maintain stability and performance.
srinaath
52
i have few queries regarding control system in electrical engineering...
1)transfer function is defined for linear system ? why is that so...
2)why transfer function is defined with zero initial condition...why not with initial condition
A transfer function is the output-to-input signal ratio. Such a ratio can be defined for equal signals forms only.
(Can you divide a triangle form by a sinus signal?).
The output signal form is equal to the form of the input signal for linear systems only.
Related to Why Is Transfer Function Defined for Linear Systems Only?
1. What is a query in control system?
A query in control system is a request for information or data from the system. It is used to retrieve information about the current state of the system, such as sensor readings, actuator positions, or control parameters.
2. How is a query different from a command in control system?
A query is a request for information, while a command is a directive to the system to perform a specific action. Queries do not change the state of the system, whereas commands do.
3. What types of queries can be used in control systems?
There are two main types of queries in control systems: status queries and parameter queries. Status queries retrieve information about the current state of the system, while parameter queries retrieve specific values or settings.
4. How are queries used in closed-loop control systems?
In closed-loop control systems, queries are used to monitor the system's performance and make adjustments to maintain the desired output. The controller sends queries to the system to retrieve feedback information, which is used to calculate the appropriate control action.
5. Can queries be used in real-time control systems?
Yes, queries can be used in real-time control systems. In fact, they are commonly used to continuously monitor the system's performance and make adjustments in real-time to maintain stability and performance.
  • Electrical Engineering
  • General Engineering
