Question :A diver springs upward from a board Need help
In summary: Have you tried solving for them both?In summary, The diver springs upward from a board that is three meters above the water. Her initial velocity is 8.90 m/s and her final velocity is -3 m/s.
carrbaseball
Question :A diver springs upward from a board ...Need help
I am stumped as to how to go about answering this question...A diver springs upward from a board that is three meters above the water. At the instant she contacts the water her speed is 8.90 m/s and her body makes an angle of 73.0° with respect to the horizontal surface of the water. Determine her initial velocity, both magnitude and direction. I am not sure if I am to set this up as two different columns and solve for both the x and y components? Any help would be appreciated. thanks
Absolutely solve for the x- and y-components separately.
The only connection between them is that they will have the same elapsed time (which may or may not help you in this particular problem; I haven't looked that closely). And, of course, you need to combine the components to get the vector in question...
I guess I am just confused on how to set this problem up. The angle is throwing me off, am i solving for tan...or is it a sin cos I am looking for? this whole problem has me confused.
Have you drawn a diagram?
Also, it sounds to me (correct me if I'm wrong) that you're stressing over the last step. Take things one step at a time. Make a list of what you know for x, what you know for y, what you know in general.
List what you want to know (what the question asks for).
Write down an equation that will give you what you want to know. If that equation requires you to sove for something else first, do so.
I know, that's all up in the air (no[?] pun intended). Basically, have you drawn a diagram yet? Are you working in an organized fashion?
Here's what i think is going on so far:
y initial =0
y final = -3
I am trying to draw a triangle to solve for the info I am giving about her speed of 8.9 m/s and the angle with respect to the horizontal which is 73 degrees.
But isn't her speed...gravity, -9.8 m/s 2??
I have tried drawing this up...over and over
It's just not connecting.
y initial =0
y final = -3
OK, now we're in business.
Let's start with resolving the diver's final velocity into its x and y components. If someone cool were helping you out here, they'd draw the diagram now. I don't know how to draw diagrams on the computer.
Your diagram should be a parabola opening downward, with the bottom left bit chopped off (because she starts from an elevated diving board). The bottom right hand bit is where she enters the water. That forms a right triangle with an angle which is given as 73 degrees, and the hypotenuse is her final velocity, given as 8.9 m/s.
The two legs of that triangle are the x and y components of her velocity. Use arccos and arcsin to solve for the components.
Does that help?
Nope. Gravity is her acceleration.
I tried finding the arccos and arcsin...but it doesn't seem right.
I got arcsin= 9.3 and arccos = 30.4.??
And after i find those (when i get them right), ill have
y initial= 0
y final = -3
velocity component of y = (whatever the correct answer from above is)
velocity component of x= ( " " ")
acceleration = -9.8 m/s2
Did i miss anything?
yeah, it shouldn't seem right; there's no reason to start playing with arccos and arcsin over here.
You have a right triangle with angle theta = 73 degrees.
[itex]cos\theta = \frac{adjacent}{hypotenuse} = \frac{v_{x}}{v}[/itex]
so [itex]v_{x} = v\cos\theta[/itex]
so in this case [itex]v_{x} = (8.90 \frac{m}{s})(cos\73^o)[/itex]
Then do a similar thing to find the y-component.
ok...so i come up with ...
Vox= 2.6 m/s
Voy= 8.5 m/s
You're looking for initial velocity. Find the x and y components seprately. What equations could you use?
So those answers i came up with were wrong?
Im sorry...I thought that was what i was to find, in the previous step?
Im sorry, i am confusing myself big time
Whoa...
No, I'm the one who's not being clear; sorry. What you just found are the correct components of the FINAL velocity. Cute. But the question wants initial velocity. So you need to find an equation relating initial and final velocities (preferably without time, because you don't know it yet) and use it to find the initial velocity. start with finding the y-component of the INITIAL velocity.
Then I'd use that to find time, and use time to find the x-component of the initial velocity.
So then ill try using V*2= Vo*2 + 2a(X-Xo)
to solve for initial velocity.
but for the Y...not the x component...sorry about that
yay!:biggrin:
well i came up with a y-component of the initial velocity= 3.66 m/s
then i used Vy=Voy + at to find time
but i came up with -.49...?
so i tried plugging that into find the initial velocity of x-component...using V= Vo +at...but i got 2.6?
That isn't right...:(
where am i going wrong??...thakn you for your patience by the way...much appreciated.
Well, getting negative time is (usually) a pretty good indication you did something wrong. I got a different initial y-velocity than you did. How did you manipulate your equation?
(and my pleasure with the help. really. this is so much fun! [quoth the nerd])
well like i said, i started with Vy*2= Voy*2 + 2a (Y-Yo)
so i plugged in numbers...(8.5)*2= Voy*2 + 2(-9.8)(-3-0)
and i got 13.45=Voy*2
for an answer of Voy= 3.66
OK, I manipulated the equation wrong. Divided instead of subtracted. BUT. I then did it again your way (read "the right way"), using v_y=-8.51 m/s. (NOTE that the y component of the final velocity is negative. It points down, and you've set your co-ordinate system so down is negative.)This gives v_0y as 3.68 m/s.
Great. Now shove that into, say, [itex]v_{y}=v_{0y}+a_{y}t[/itex]
and get 1.24s. Please check my work, though, it's late where I live...
Use that time instead of the negative one, and see if that helps.
Thank you very much for all your help...its greatly appreciated!...Ill try these numbers and see what i get. I hope to see you on here again if i have more questions down the road.
FAQ: Question :A diver springs upward from a board Need help
What causes a diver to spring upward from a board?
A diver springs upward from a board due to the force of their legs pushing against the board and the force of gravity pulling them downward. This combination of forces propels the diver upward.
What factors affect the height of a diver's spring?
The height of a diver's spring is affected by the amount of force they apply to the board, the angle at which they jump, and their body position during the jump. Additionally, the height of the board and the strength of the diver's legs can also impact the height of the spring.
How can a diver increase their spring height?
A diver can increase their spring height by using proper technique, such as bending their knees and pushing off the board with strong and coordinated leg movements. Additionally, having a higher starting position on the board can also help increase the height of the jump.
Why is it important for a diver to spring upward from a board?
Springing upward from a board is an essential part of diving as it helps the diver gain height and control their trajectory. This allows them to perform more complex and impressive dives and also helps them enter the water with less impact, reducing the risk of injury.
What are some common mistakes made when springing from a diving board?
Some common mistakes made when springing from a diving board include not bending the knees enough, not coordinating the leg movements properly, and not using enough force to push off the board. These mistakes can result in a lower spring height and potentially lead to a less successful dive.
