Question about a cancellation law
  • Thread starter icesalmon
  • Tags
    Law
In summary: Clearly, ##a=\left(\begin{array}{cc} 1&0\\0&0 \end{array}\right),## ##b=\left(\begin{array}{cc} 0&1\\1&1 \end{array}\right),## and ##c=\left(\begin{array}{cc} 0&-1\\0&1 \end{array}\right)##, but the law of real arithmetic says that ##a=\left(\begin{array}{cc} 1&0\\0&0 \end{array}\right),## ##b=\left(\begin{array}{cc} 0&1\\1&1 \end{array}\right),## and ##
icesalmon
270
if ba = bc and a is nonzero then b = c
if a is nonzero I can multiply both sides by a-1 to get
ba(a-1) = bc(a-1)
b(1) = bc(a-1)
b = bc(a-1)
not sure how to proceed, is the problem statement ba = bc supposed to be ab = ac ?
i'll check it out, thanks a lot.
No, that's not true at all. For example, take b=2, a=4, c=4. The equality holds, the criteria are met, yet [itex]b\neq c[/itex]
What you're looking for is
If ba = bc and b is non-zero, then a = c.
EDIT: Sorry, I missed this part:
Yes, that's what it should be instead.
You do not say what algebraic structure you are working in. In a "cancellation ring" such as the set of all integers, with ordinary addition and multiplication as operations, we do NOT have "multiplicative inverses" but the cancellation law is still true: if ab= ac and a is not the additive identity, 0, then b= c.
I'm not sure if this is correct, but I'm thinking it's a field since they didn't specify. My book was using this as an example of how to show that axioms that hold in real arithmetic may not hold in matrix arithmetic: "for example, consider the following two laws of real arithmetic: If ab = bc and a is nonzero then b = c. [ Cancellation Law ] "
That so-called "cancellation law" doesn't hold for matrices. Just consider ##a=\left(\begin{array}{cc} 1&0\\0&0 \end{array}\right)## (which is nonzero), ##b=\left(\begin{array}{cc} 0&1\\1&1 \end{array}\right)## and ##c=\left(\begin{array}{cc} 0&-1\\0&1 \end{array}\right)##.
FAQ: Question about a cancellation law
What is a cancellation law?
A cancellation law is a mathematical rule that states that when two quantities are multiplied or divided, the result will remain the same even if the order of the quantities is changed or one of the quantities is multiplied or divided by its reciprocal.
What is the purpose of a cancellation law?
The purpose of a cancellation law is to simplify mathematical expressions and make them easier to solve. It eliminates unnecessary terms and reduces the complexity of equations.
Are there different types of cancellation laws?
Yes, there are different types of cancellation laws depending on the mathematical operation being performed. For example, there are cancellation laws for addition, multiplication, and division.
How do cancellation laws apply to fractions?
In fractions, cancellation laws can be used to simplify the expression by canceling out common factors in the numerator and denominator. This makes it easier to add, subtract, or multiply fractions.
Can cancellation laws be applied to all mathematical operations?
No, cancellation laws only apply to multiplication and division. Addition and subtraction do not have cancellation laws, but they have other properties such as the commutative and associative properties.
