Question about a Mass-Spring-Damper
In summary, the conversation discusses the schematic diagram and values for a suspension system in a road vehicle, and the task of developing a Laplace Transform model to predict the displacement of the vehicle body in response to different inputs. The conversation also mentions using Mason's rule to reduce the diagram to a transfer function and using the transfer function to determine the response. The conversation concludes with a question about determining the tension in the spring and force of the damper as a function of displacement and time derivatives, as well as the Newton's law force balance on the mass."
shannonxtreme
1) The schematic diagram for the suspension system at one corner of a road vehicle is shown below. The displacement of the road wheel is denoted x, and the resultant displacement of the vehicle body is y.
IMAGE - http://imgur.com/VxKx5Qq
Values of the spring rate, k, damping coefficient, c, and mass, m, are given below.
k - 7 x 104 N/m
c - 3 x 103 N/m/s
m - 250 kg
Analysis / Modelling
a) Develop a Laplace Transform model of the system and use this to predict the displacement, y, in response to various inputs, x, (e.g., step, impulse, ramp).
Can anyone help me solve this? It has been a while and I am very rusty indeed.
Likes oshz
Sketch a diagram as shown below:
Well, it's not a mass-spring-damper system, but some electric motor.
Anyway, you should get something like that, with one or more closed loops.
Now, use Mason's rule to reduce the diagram to a transfer function: y(s)/x(s) = numerator / denominator.
Set the input, x(s) = ramps/sine waves/whatever, multiply by the transfer function, and you will get the response, y(s).
Job done.
If x is the upward displacement of the axle and y is the upward displacement of the mass, what is the tension in the spring as a function of x and y? What is the force of the damper as a function of the time derivatives of x and y? What is the Newton's law force balance on the mass in terms of x and y, and their first and second time derivatives?
Chet
FAQ: Question about a Mass-Spring-Damper
What is a mass-spring-damper system?
A mass-spring-damper system is a physical system that consists of a mass, a spring, and a damper. The mass represents the object being studied, the spring represents the restoring force, and the damper represents the dissipative force.
What is the equation of motion for a mass-spring-damper system?
The equation of motion for a mass-spring-damper system is given by F = ma = -kx - bv, where F is the force applied to the mass, m is the mass of the object, a is the acceleration, k is the spring constant, x is the displacement of the mass from its equilibrium position, b is the damping coefficient, and v is the velocity of the mass.
What is the natural frequency of a mass-spring-damper system?
The natural frequency of a mass-spring-damper system is given by ωn = √(k/m), where k is the spring constant and m is the mass of the object. It represents the frequency at which the system will oscillate without any external forces acting on it.
What is the role of damping in a mass-spring-damper system?
The role of damping in a mass-spring-damper system is to dissipate energy and reduce the amplitude of the oscillations. It helps to prevent the system from oscillating indefinitely and allows it to reach a steady-state response.
How does the amplitude of oscillations change with damping in a mass-spring-damper system?
The amplitude of oscillations decreases with increasing damping in a mass-spring-damper system. This is because damping dissipates energy and reduces the amplitude of the oscillations, resulting in a smaller displacement from the equilibrium position.
