Question about a property of Sturm-Liouville problems
  • Thread starter A_B
  • Tags
    Property
Expert SummarizerIn summary, the conversation discusses a Sturm-Liouville problem and its operator in equation (7) of a paper. The operator is multiplied by a positive function in order to find an explicit solution. This solution also has negative eigenvalues, leading to the conclusion that the original problem must also have negative eigenvalues. This is a well-known property of Sturm-Liouville problems, proven using the Rayleigh quotient. Further references and resources are recommended for those interested in learning more about Sturm-Liouville problems.
A_B
93
Hi,
In equation (7) of
http://arxiv.org/pdf/gr-qc/9604038.pdf
they consider a Sturm-Liouville problem of the form
-(Rr')'-(8/R5)r = ω²r.
with R(x) a positive function on (0, +∞) and r(x) the eigenfunction with eigenvalue ω². The goal is to show that there are negative eigenmodes.
Equation (7) in this paper is not the sturm-liouville problem above. The operator is multiplied from the left by R(x) in order to allow an explicit solution to be found. This explicit solution to the new problem turn out to have negative eigenvalue, and it is concluded that the original problem also has a negative mode. I wonder why this can be done. Perhaps multiplication of the operator by a positive function does not change the sign of eigenvalues?
Can someone see what's going on here? Perhaps point me to a reference/proof for the relevant property of Sturm-Liouville problems?
Thanks,
A_B
Dear A_B,
Thank you for bringing this to our attention. It is true that the operator in equation (7) is not exactly the same as the Sturm-Liouville problem mentioned in the paper. However, as you correctly noted, multiplying the operator by a positive function does not change the sign of eigenvalues. This is a well-known property of Sturm-Liouville problems and can be proven using the Rayleigh quotient.
The Rayleigh quotient is a mathematical tool used to find the eigenvalues of a Sturm-Liouville problem. It states that the eigenvalues are the critical points of the quotient, and these critical points are either positive or negative. Therefore, multiplying the operator by a positive function does not change the sign of the eigenvalues, as it does not change the critical points of the quotient.
Additionally, the explicit solution found for the new problem also has negative eigenvalues, which further supports the conclusion that the original problem has negative eigenvalues as well. This is a common approach in solving Sturm-Liouville problems, where a simpler problem is solved in order to gain insight into the original problem.
I hope this clarifies the situation for you. If you would like to learn more about Sturm-Liouville problems and their properties, I recommend checking out the book "Introduction to Partial Differential Equations" by Peter Olver.
FAQ: Question about a property of Sturm-Liouville problems
What is a Sturm-Liouville problem?
A Sturm-Liouville problem is a type of boundary value problem in differential equations that involves finding a solution to an eigenvalue equation. It is named after the mathematicians Jacques Charles François Sturm and Joseph Liouville who first studied and described this type of problem in the 19th century.
What are the properties of Sturm-Liouville problems?
The main properties of Sturm-Liouville problems are self-adjointness, orthogonality, and completeness. Self-adjointness means that the differential operator in the problem is its own adjoint. Orthogonality refers to the fact that the eigenfunctions of a Sturm-Liouville problem are orthogonal to each other with respect to a weight function. Completeness means that the set of eigenfunctions forms a complete basis, which allows for the expansion of any function in the domain as a series of eigenfunctions.
What are some real-world applications of Sturm-Liouville problems?
Sturm-Liouville problems have a wide range of applications in physics, engineering, and mathematics. They are used in the study of heat transfer, quantum mechanics, vibration analysis, and fluid dynamics, among others. They also have applications in signal processing, where they are used for spectral analysis and filtering.
How are Sturm-Liouville problems solved?
Sturm-Liouville problems are typically solved using analytical methods, such as separation of variables or the method of Frobenius. These methods involve converting the problem into a series of simpler equations that can be solved using standard techniques. In some cases, numerical methods may also be used to approximate the solution.
What is the significance of Sturm-Liouville problems in mathematics?
Sturm-Liouville problems are significant in mathematics because they provide a mathematical framework for studying a wide range of physical phenomena. They also have connections to other areas of mathematics, such as functional analysis and the theory of differential equations. Additionally, the properties of Sturm-Liouville problems have important implications for the theory of operators and spectral theory.
