Question about a sheet of charge
  • Thread starter toesockshoe
  • Tags
    Charge
In summary: In summary, the force of a point charge is proportional to 1/r^2, while the force of a line charge is proportional to 1/r. For a sheet charge, the force is a constant and for a volume it is proportional to r. However, these equations are based on assumptions, such as the sheet being infinite in extent. When dealing with a finite sheet, the force will vary depending on the distance and the shape of the sheet.
toesockshoe
265
Today my prof said that for a point charge the force is proportional to 1/r^2. For a line charge it is proportional to 1/r. For a sheet charge it is a constant and for a volume it is proportional to r. He also did some derivations but I don't see how this can be.
For example for a sheet charge how can a test charge that is a million meters away experience the same force that an object one millimeter away experiences? Then doesn't that mean if I make a sheet charge of say 100C, then I should be able to provide a resulting force on an object that is across the country ... because a sheet charge produces a uniform electric field regardless of position right? Obviously this doesn't happen because if someone create a sheet charge in Africa...a metal object here certainly doesn't not feel it all the way here in America. Same thing with a volume charge... How can an object further away from the charge feel a stronger attraction than something closer to the charge?
It's always important to understand what assumptions are made when deriving these kinds of equations. In particular, the assumption when deriving the electric field of a sheet of charge is that the sheet is infinite in extent. Obviously, this is not physical, but it is a good approximation when looking at the electric field close to the sheet. It's like the acceleration due to gravity. Certainly objects don't always accelerate with an acceleration of ##g## (after all, the force decreases as you get farther from the Earth), but when close to the surface, it is a good approximation to treat the gravitational field as a constant.
If the sheet is finite, then at far distances, it will look like a point charge. Then you can imagine what the formula will look like, however, from searching around, it is very difficult to get a closed form solution for a finite sheet of charge, hence the infinite sheet approximation.
Thank you.
axmls said:
IIf the sheet is finite, then at far distances, it will look like a point charge. Then you can imagine what the formula will look like, however, from searching around, it is very difficult to get a closed form solution for a finite sheet of charge, hence the infinite sheet approximation.
If the sheet is a finite disc, and the particle lies on the axis of the disc, the math for the field (multiply by charge of particle in the field to get the force) is shown here:
http://hyperphysics.phy-astr.gsu.edu/%E2%80%8Chbase/electric/elelin.html#c3
rcgldr said:
If the sheet is a finite disc, the math for the field (multiply by charge of particle in the field to get the force) is shown here:
Ah, of course. My brain instantly jumped to a finite rectangular sheet. Yes, a disc has a very simple closed form along the axis through its center, and I'm sure the OP can confirm that we obtain the formula for an infinite sheet if we let the radius go to infinity.
It the sheet is a rectangle and the particle lies on the central "axis" of the sheet, the sheet could be considered as an infinite number of lines of finite length, where the component of force perpendicular to the lines cancel, so only the component related to z needs to be considered. This is the math for a line, the math for a sheet would involve an integral based on the formula for a line:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elelin.html
Related to Question about a sheet of charge
1. What is a sheet of charge?
A sheet of charge is a two-dimensional surface with an evenly distributed electric charge. It can be thought of as an infinitely thin layer with a constant charge density.
2. How is a sheet of charge different from a point charge?
A point charge is a single, isolated charge that is usually represented as a single dot. A sheet of charge has a finite area and a charge density that is spread out over that area. This results in a different electric field and potential surrounding the charge.
3. What is the electric field around a sheet of charge?
The electric field around a sheet of charge is uniform and perpendicular to the surface. The magnitude of the electric field is determined by the charge density of the sheet and the permittivity of the surrounding medium.
4. How is the electric field affected if the sheet of charge is curved?
If the sheet of charge is curved, the electric field will no longer be uniform. The curvature of the sheet will cause the electric field lines to bend, resulting in a non-uniform electric field around the sheet.
5. Can a sheet of charge have a negative charge density?
Yes, a sheet of charge can have a negative charge density. This means that the charge is distributed in a way that results in a net negative charge on the sheet. The electric field will still be perpendicular to the surface, but it will point in the opposite direction compared to a sheet with a positive charge density.
  • Electromagnetism
  • Electromagnetism
