Question about a system in thermodynamic equilibrium
In summary: It has been established that for thermodynamic equilibrium to exist, there can be no net macroscopic flow of energy or matter and the temperature must be constant. The question now is whether a system with a spatially varying energy density can still be in equilibrium, or if there needs to be a mechanism to push it towards uniform energy density. It has been pointed out that a system of particles treated as independent oscillators with position-dependent energy can lead to directional energy flows, which goes against the conditions for thermodynamic equilibrium. Therefore, it can be concluded that for a system to be in
hgandh
27
What are the precise conditions for thermodynamic equilibrium? I know that a system in thermodynamic equilibrium must have constant temperature and that there can be no net macroscopic flow of energy or matter. However, is it possible for there to be a system in equilibrium that has a spatially varying energy density? For example, a system of particles treated as independent oscillators where the energy of the oscillators depends on its position in space. Can such a system be in equilibrium or must there be a mechanism that pushes it towards uniform energy density?
Science news on Phys.org
For thermodynamic equilibrium to exist there can be no internal or external macroscopic energy flows ie temperature is uniform and any changes in thermodynamic properties must occur over very long time intervals. Independent oscillators whose energy depends upon their position within the volume do not meet these criteria. Energy distribution being position dependent necessarily means that there will be directional energy flows. For example, a living cell has independent energy oscillators (mitochondria or chloroplasts) that are positioned throughout the cytoplasm of the cell. These provide energy flows within the cells that are highly directed and allow the cell to perform various function i.e. not thermodynamic equilibrium.
AM
@hgandh, could you clarify what you mean by energy density?
I don't agree. If something has a position dependent heat capacity (e.g., layered materials), then wouldn't the energy content depend on the local heat capacity at uniform temperature?
Likes Andrew Mason
'Thermodynamic equilibrium' requires 2 systems, not one- it's a unique definition- and simply states that the two objects are in equilibrium if they have the same temperature. Regarding the possibility of a 'spatially varying energy density', sure- an isothermal column of homogeneous fluid (with gravity present) has a spatially-varying potential energy density and can be in thermal equilibrium with its container and surroundings.
There is also the concept of internal equilibrium. Two parts of what one would call a unique system can be out of equilibrium with each other.
If the two subsystems are out of thermal equilibrium with respect to each other, what prevents the flow of thermal energy?
You would get a flow of energy in the direction to restore thermal equilibrium.
Right, that's my point. My original point is that thermal equilibrium requires *at least 2* systems (which can be subsystems of a larger system), that is in contrast with say, mechanical equilibrium which is a statement about a single system.
You are correct. It is difference in average translational kinetic energy per molecule that is determines whether there will be a flow of energy within a body or system. By posing the question as the OP did: "For example, a system of particles treated as independent oscillators where the energy of the oscillators depends on its position in space" I incorrectly assumed that meant that the average translational kinetic energy per particle in the oscillators depended on position within the body. I should have said "If molecular translational kinetic energy distribution is position dependent, this necessarily means that there will be directional energy flows".
AM
Likes DrClaude
Related to Question about a system in thermodynamic equilibrium
1. What is thermodynamic equilibrium?
Thermodynamic equilibrium refers to a state in which a system has reached a balance between all of its internal and external forces and has no net change in its macroscopic properties over time.
2. How does a system reach thermodynamic equilibrium?
A system can reach thermodynamic equilibrium through various processes, such as heat transfer, work, and chemical reactions. These processes work to equalize the energy and matter distribution within the system until it reaches a state of balance.
3. What are the properties of a system in thermodynamic equilibrium?
A system in thermodynamic equilibrium has uniform temperature, pressure, and composition throughout its entire volume. It also has no net flow of energy or matter, and its macroscopic properties do not change over time.
4. Can a system in thermodynamic equilibrium be disturbed?
Yes, a system in thermodynamic equilibrium can be disturbed by external forces, such as changes in temperature or pressure. However, it will eventually return to a state of equilibrium through the processes of heat transfer, work, and chemical reactions.
5. What is the significance of studying systems in thermodynamic equilibrium?
Understanding systems in thermodynamic equilibrium is crucial in fields such as engineering, chemistry, and physics. It allows us to predict and control the behavior of complex systems and develop efficient and sustainable processes and technologies.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
