Question about a Tangent Vector
In summary, the conversation is discussing the components of a tangent vector to a parametric curve, specifically the components being dx/dt and dy/dt. The author's reasoning for this is not explicitly stated, but it can be inferred that these components are proportional to the unit vector tangent to the curve and are defined as such because they are in the direction of motion. The authors' explanation may be unclear, but the concept of a tangent vector being "just touching" a curve at a single point is also mentioned.
smodak
459
253
In the following book, please look at equation 3.16. Why are the components of the tangent vector given by
ui = dxi/dt? I understand the velocity components would be dxi/dt and the velocity vector would be a tangent vector. Is that the same reasoning the author uses? The book is normally crystal clear, but, this specific discussion confused me.
https://books.google.com/books?id=7zFalCF_LiEC&pg=PA48&lpg=PA48&dq=tangent+vector+parabola+dx/dt&source=bl&ots=Q2m0RBTbkI&sig=moW1rwceNUEop-SkG5rLfkeAZhY&hl=en&sa=X&ved=0ahUKEwjrgee4qKbMAhWCw4MKHeE7D3gQ6AEIJTAC#v=onepage&q=tangent vector parabola dx/dt&f=false
Thanks in advance for your help!
dvi/dt will be acceleration component!
Sorry. I meant dxi/dt. But the question is still the same.
That is how we define velocity.
I understand. What I am asking is why the components of a tangent vector to a parametric curve x = f(t) and y = g(t) would be dx/dt and dy/dt?
Yes. The velocity vector is tangent to the trajectory of the particle.
For constant unit vectors it is obvious for varying unit vectors as in curvilinear coordinates dxi/dt should include the change in direction part too.
Not for the special case of the expressing the velocities. A differential position vector along the trajectory is $$\vec{ds}=\vec{a_1}dx^1+\vec{a_2}dx^2$$ where the a's are the coordinate basis vectors. So the velocity is given by:$$\vec{v}=\frac{\vec{ds}}{dt}=\vec{a_1}\frac{dx^1}{dt}+\vec{a_2}\frac{dx^2}{dt}$$
If you want to express the accelerations in curvilinear coordinates, however, you need to include the derivatives of the coordinate basis vectors. The difference is that ds is already a differential vector, while v is not.
Yes I understand. Thank you Sir Insights Author.
Thanks. How can this be proved? How can we prove that the components of a tangent vector to a parametric curve x = f(t) and y = g(t) would be dx/dt and dy/dt?
Let's say that that curve is a simple parabola y = -x2.
In parametric form (as a function of time t): x = t , y = √(1-t2)
How can we prove that the components of any tangent vector to the above curve would be dx/dt and dy/dt?
The parametric form you wrote down does not agree with the equation you wrote down for the curve.
Those are not the components of any tangent vector to the curve. But, the components of any tangent vector to the curve will be proportional to these. For example, the components of a unit vector tangent to the curve are given by ##\frac{\frac{dx}{dt}}{\sqrt{(\frac{dx}{dt})^2+(\frac{dy}{dt})^2}}## and ##\frac{\frac{dy}{dt}}{\sqrt{(\frac{dx}{dt})^2+(\frac{dy}{dt})^2}}##
Likes smodak
Consider a point x(t),y(t) on the curve at time t. After a time Δt, we are now at the point x(t+Δt),y(t+Δt) and the vector connecting the two points, Δr, which is approximately in the tangent direction, has components x(t+Δt)-x(t) and y(t+Δt)-y(t). As we let Δt -> 0, the velocity, v, is given by dr/dt and its components ( x(t+Δt)-x(t) )/Δt and ( y(t+Δt)-y(t) )/Δt as Δt -> 0 are just dx/dt and dy/dt. So dx/dt and dy/dt are the components of the tangent vector.
Likes smodak
Well, what is your definition of a tangent vector?
You are absolutely correct. Those are for a circle. I was not thinking :).
I understand now. Thanks.
I was really confused by what the author wrote in the book in my originally linked page.
Tangent vector: Anyvector that is tangent to a curve or surface at a given point
That doesn't really help. What's your definition of "tangent to a curve or surface"?
(If your answer in post #14 means that you think that the problem of this thread is solved, there's no need to respond.)
Tangent = "just touches" a curve at a single point. A vector is a tangent vector to a curve if it just touches a curve at a single point. I believe, It is a vector that is in (or exactly opposite to) the direction of motion. Is that not correct?
Also #14 sort of helps but I am still a bit unclear about what the authors Øyvind Grøn, Arne Næss are saying from the link in my OP. It almost seems like they are just saying that the components of the tangent vectors to the curve are dx/dt and dy/dt without offering any reasoning. I must be missing something obvious.
Did you read my post #12 above?
Actually I had missed it. I think I understand what you mean.
If I understand you correctly, according to your logic, velocity is a tangent vector and the components of the velocity tangent vector are dx/dt and dy/dt. However, this does not automatically mean that any tangent vector would have components dx/dt and dy/dt as Øyvind Grøn, Arne Næss seem to indicate in the book. This is the crux of my confusion.
Okay, I think I see what you're saying. Yes, the velocity is one particular tangent vector that has a particular physical meaning. There are other tangent vectors that have the same direction but differ in their magnitude. They all have to have the same slope, however, which is given by the ratio of the y-component to the x-component. Note that dy/dt divided by dx/dt equals dy/dx, which is the slope. So any vector with components in the same proportion as dx/dt and dy/dt will be a tangent vector, but they will have different magnitudes. Only the one tangent vector with components dx/dt and dy/dt will be the velocity.
Bingo. Unfortunately, this is not very clearly written in that book although the rest of the logic in the book is fabulous (so far).
Related to Question about a Tangent Vector
1. What is a tangent vector?
A tangent vector is a mathematical concept used in differential geometry to represent the direction and magnitude of change at a specific point on a curve or surface.
2. How is a tangent vector different from a regular vector?
A regular vector is a geometric object that has both magnitude and direction, while a tangent vector is specifically defined for a particular point on a curve or surface and represents the direction and rate of change at that point.
3. How is a tangent vector used in calculus?
In calculus, the tangent vector is used to calculate the derivative of a function at a specific point. It represents the instantaneous change of the function at that point, and is essential for solving problems involving rates of change and optimization.
4. Can a tangent vector have negative magnitude?
Yes, a tangent vector can have negative magnitude. The magnitude of a tangent vector represents the rate of change, so it can be positive or negative depending on the direction of the change at that point.
5. How are tangent vectors used in physics?
In physics, tangent vectors are used to represent the velocity and acceleration of an object at a particular point in its motion. They are also used in the study of curves and surfaces in space, such as the path of a moving object or the shape of a planetary orbit.
  • Other Physics Topics
  • Atomic and Condensed Matter
  • Differential Geometry
  • Classical Physics
