Question About a Test Charge Near a Conductor
The discussion centers on the confusion regarding the method of charging a conductor through induction and the concept of equilibrium in the system. It clarifies that reaching equilibrium is essential, as charge will continue to flow until this state is achieved. The participants express uncertainty about the terminology used, particularly regarding the equivalence of electric fields. Additional steps in the charging process are noted as necessary for a complete understanding. Overall, the conversation highlights the complexities of electrostatics and the nuances of charging conductors.
nmfowlkes
A positive test charge is brought near to, but not touching, a conducting sphere that is connected to the ground. Both objects remain at rest in the positions shown above. Charge begins to flow from the ground to the sphere. Which of the following statements best describes when charge stops flowing, and provides justification for the claim?
A. Charge will flow until the electric field at the surface of the sphere is equivalent to the electric field of the test charge, because then the excess charge on the surface of the sphere will be equal to the charge of the test charge.
B. Charge will flow until the electric field at the surface of the sphere is equivalent to the electric field of the test charge, because then the net force on all charges on the surface of the sphere will be zero.
C. Charge will flow until the potential at the surface of the sphere is the same as the potential of the test charge, because then the net force on all charges on the surface of the sphere will be zero.
D. Charge will flow from the ground to the sphere until the potential is the same everywhere within the sphere, because then the excess charge on the surface of the sphere will be equal to the charge of the test charge.
E. Charge will flow from the ground to the sphere until the potential is the same everywhere within the sphere, because then the net force on all charges on the surface of the sphere will be zero.
This is a conceptual problem. Equations are not relevant.
I am confused because I thought this was a method of charging a conductor. Why would the system be reaching a state of equilibrium?
You bring up the charge and then count to ten...Equilibrium for as long as you keep the test charge stationary . What does it look like and why?
It is only part of the method of charging a conductor by induction. There are additional steps which are not taken here.
Because if it is not in equilibrium, charge will flow until it reaches equilibrium.
The wording in the first two choices bothers me. I don't know how to tell that an electric field is "equivalent" to another electric field. Is this something that is discussed in wherever you found this question?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
