Question about accelerated expanding universe theory.
In summary, the universe is expanding at an accelerated rate. This was measured using spectroscopy, comparing Type 1A supernovae at different distances. It was discovered that Type 1A supernovas at a greater distance were moving away from us at a greater speed then the supernova's closer to us. So it was concluded that the universe is expanding at an accelerated rate.
Ramon163
Hey,
After watching a show on TV about expanding universe and dark matter&energy, I wondered the following.
In the program, it was mentioned that the universe is expanding at an accelerated rate. This was measured using spectroscopy, comparing Type 1A supernovaes at different distances. It was discovered that Type 1A supernovas at a greater distance were moving away from us at a greater speed then the supernova's closer to us. So it was concluded that the universe is expanding at an accelerated rate.
That got me wondering... Because it takes millions of years for that light to reach us, doesn't that mean that: The supernova that is farther away is what is actually was going on for instance 100 million years ago and a supernova closer to us for instance 30 million years ago, which automatically means that of-course it seems that the supernova farther away is moving faster because what we are seeing is closer to when the big bang happened then the supernova closer to us.
Am I missing something here, or is my data just wrong?
Space news on Phys.org
Thanks for your reply, and the posts are indeed a little confusing.
But I did a little research into some of the terminology you used, and I think I understand a little.
If I understand it correctly, my problem with this is that what I mentioned in my earlier post: They concluded an accelerated expanding universe by measuring the same phenomenon at 2 different distances (Super novae). But to conclude that something is accelerating, shouldn't you measure the same object at 2 different time intervals to make that conclusion? Or is that impossible because the redshift doesn't change measurably in our lifetimes to conclude anything like that?
We apply physics as we understand it to observational evidence and make deductions. Anything more [or less] is purely speculative.
Well, that would be really really nice, but I don't think we'll ever have detailed enough measurements to observe the accelerations directly. However, what I will say is that the supernovae are not, by far, our only evidence for dark energy.
The CMB, for instance, provides an extremely accurate measure of the geometry and matter density of our universe. From this we basically know that our universe is very nearly flat, but also that the matter density (both normal and dark) is insufficient to explain this flatness.
From the CMB observations we can also compute the expected typical separation of galaxies today, through a technique called Baryon Acoustic Oscillations (BAO). Basically, we look at the typical separation between the hot and cold spots on the CMB, do a little bit of physical modeling, and are able to compute from this the typical separation between galaxies later on. We can then measure how far apart galaxies appear to be at different redshifts, and we can say how far away they must be based upon how far apart from one another they are. This, it turns out, is also a highly accurate measure of matter density and geometry, but in a rather different way than the CMB itself, making the combination of the two vastly more accurate.
And these three types of measurements, supernovae, CMB, BAO, all converge on the same results for cosmological parameters, to within measurement errors.
We are tantalizingly close to being able to do this, but, for economic and other reasons, such a project won't start for several decades. Once started, the project would take a couple of decades to start to get good results.
http://arxiv.org/abs/0802.1532
Yeah, sorry, you're right. For some odd reason I had been thinking that this sort of experiment wouldn't be measuring acceleration. Whoops.
Related to Question about accelerated expanding universe theory.
What is the accelerated expanding universe theory?
The accelerated expanding universe theory, also known as the accelerated expansion hypothesis, is a scientific theory that explains the observed increase in the rate of expansion of the universe. It suggests that the expansion of the universe is not constant, but rather is accelerating due to the presence of a mysterious force called dark energy.
What evidence supports the accelerated expanding universe theory?
Several pieces of evidence support the accelerated expanding universe theory, including observations of supernovae, cosmic microwave background radiation, and the large-scale structure of the universe. These observations all indicate that the expansion of the universe is accelerating, rather than slowing down or remaining constant.
What is dark energy and how does it relate to the accelerated expanding universe theory?
Dark energy is a hypothetical form of energy that is thought to permeate all of space and is responsible for the observed acceleration of the universe's expansion. It is believed to make up approximately 68% of the total energy in the universe, with the remaining 32% being composed of dark matter and visible matter.
What is the difference between the accelerated expanding universe theory and the Big Bang theory?
The Big Bang theory is a scientific model that explains the origin and evolution of the universe, while the accelerated expanding universe theory focuses specifically on the rate of expansion of the universe. The Big Bang theory does not necessarily imply an accelerating expansion, but the accelerated expanding universe theory is a key piece of evidence supporting the Big Bang model.
Are there any alternative theories to explain the accelerated expanding universe?
There are some alternative theories that have been proposed to explain the accelerated expanding universe, such as modified theories of gravity or the possibility of a large-scale cosmic void. However, these alternative theories have not been able to fully explain all of the observed evidence, and the accelerated expanding universe theory remains the most widely accepted explanation for the universe's expansion.
  • Cosmology
  • Cosmology
  • Astronomy and Astrophysics
