Question about accelerating expansion
In summary, the conversation discusses the concept of an accelerated expansion of the universe and its implications on the observed brightness of distant supernovae. The data shows that the supernovae appear dimmer than expected at high redshifts, which suggests an accelerating universe. This is supported by a positive cosmological constant, which is the simplest explanation within Einstein's equations. The conversation also mentions a possible link between the accelerated expansion and the recession of nearby objects. However, this is not the case as all objects are receding faster due to the accelerated expansion. The expectation is based on a more complex model that takes into account the influence of dark energy.
exmarine
241
Why do I see everything backwards? Here is a paragraph from Bernard Schutz’s excellent book on General Relativity, p. 352: (referring to the famous plot from the High-Z Supernova Search Team: Riess, et al, 1998)
The top diagram shows the flux (magnitude) measurement for each of the supernovae
in the sample, along with error bars. The trend seems to curve upwards, meaning that at
high redshifts the supernovae are dimmer than expected. This would happen if the universe
were speeding up, because the supernovae would simply be further away than expected.
Three possible fits are shown, and the best one has a large positive cosmological constant,
which we shall see below is the simplest way, within Einstein’s equations, that we can
accommodate acceleration. The lower diagram shows the same data but plotting only the
residuals from the fit to a flat universe. This shows more clearly how the data favor the
curve for the accelerating universe.
As high-Z objects are older, and more distant “than expected”, wouldn’t that have to mean that the younger objects nearby are not retreating as fast as they once were in the distant past?
I assume that the expectation is from a linear fit extrapolation of the younger nearby supernovae? I attach a Word/pdf of a simple integral that seems to confirm intuition.
  • DistIntegrals.pdf
Space news on Phys.org
No. The accelerated expansion makes it so that all objects, regardless of distance, are receding faster than they would have we didn't have an accelerated expansion. It's just that that discrepancy is most visible at certain specific redshifts.
At redshifts that are too high, the dark energy was such a tiny fraction of the total energy density that it had negligible impact on expansion at that time. At redshifts that are too low, there hasn't been enough time for the very weak dark energy to have had a measurable impact.
It's substantially more complicated than that. The expectation is from an alternate model fit which doesn't include dark energy. That alternate model predicts a power-law relationship between supernova brightness and redshift, so that plotted on a graph of log(z) vs. magnitude (which is a logarithm of brightness), the graph appears linear. But a full physical model is used, rather than a simple linear regression.
Related to Question about accelerating expansion
What is the accelerating expansion of the universe?
The accelerating expansion of the universe refers to the observation that the rate at which the universe is expanding is increasing over time. This means that the distance between galaxies is increasing at a faster rate than in the past.
What is causing the accelerating expansion of the universe?
The cause of the accelerating expansion of the universe is currently unknown and is a topic of ongoing research and debate. Some theories suggest that it could be due to dark energy, a mysterious force that makes up a significant portion of the universe's energy density.
How is the accelerating expansion of the universe measured?
The accelerating expansion of the universe is measured using a variety of methods, including observations of type Ia supernovae, the cosmic microwave background, and galaxy redshift surveys. These measurements allow scientists to determine the rate of expansion and how it has changed over time.
What are the implications of the accelerating expansion of the universe?
The accelerating expansion of the universe has significant implications for our understanding of the universe and its future. It suggests that the expansion will continue to accelerate, eventually leading to the "heat death" of the universe, where all matter and energy are evenly distributed and no work can be done.
Can the accelerating expansion of the universe be stopped or reversed?
At this time, there is no known way to stop or reverse the accelerating expansion of the universe. However, scientists continue to study and explore potential theories and solutions that could potentially alter the fate of the universe.
  • Cosmology
  • Cosmology
