Question about acids And molarity vs concentration
In summary: Actually it depends on how anal you want to be about what the substance is. Take water - it autodissociates, producing H+ and OH-. So technically you can argue that even 100% pure water is not "just H2O", as it contains 10-7 M of both ions. No chemist I know would think this way though.
AMan24
58
so is an acid like HCl, is it basically these HCl ions that are "dissolved" or "infused" into water and form an acid? So what I'm saying is HCl by itself isn't possible and it's only possible in the dissolved form or aqueas form. This would make sense because as far as I know an acid or base cannot be 100% pure. And if this is true then it makes sense.
so basically, I have a few questions but the main one is. Is HCl its own pure liquid or is it just ions or a molecule dissolved in water. If it is just something in water than I won't even ask those questions because it will answer them.
Another question, which I'm almost certain the answe is no. Is it possible to have a "pure" acid?
Chemistry news on Phys.org
Interesting question. I was pretty sure I knew the answer, but I googled it to be sure. HCl=hydrogen chloride is a colorless gas at room temperature. And it is quite soluble in water where the ions separate (H+ and Cl-). You can get very strong concentrations, but no, you won't have pure liquid HCl (at least at atmospheric pressure). The HCl molecular bond is of the ionic form=perhaps that would explain why it separates when it encounters liquid water with the water molecule also having a permanent dipole, etc.
Likes AMan24
Just to expand a little bit on Charles' answer. Even if you were to liquefy pure HCl, it wouldn't have acidic properties. HCl needs to ionize in aqueous solution in order to behave like an acid.
Likes Charles Link and AMan24
thanks guys, it makes a lot of sense now
This is both wrong and true at the same time.
In practice there is no such thing as a "pure substance" - they are always contaminated to some extent. At the same time you can have reasonably pure sulfuric acid or nitric acid (both liquids), or pure sodium hydroxide (as a solid, or molten, if heated high enough) - what is wrong about calling them "100% pure acid" or "100% pure base"?
I see what you mean, but calling it 100% pure wouldn't be right. I just read online that sulfuric acid can be 98% pure, 2% impurity seems like a big difference to me, but of course from a practical point it makes no difference. If it was some substance that was 99.99% pure i'd give it the 100%, because you're right, nothing can actually be 100% pure.
It depends on your source. 98% is a standard stock acid, one that we know to make relatively cheap, but if you need a 99.99% you can buy it too - it is just a matter of price.
Such a pure sulfuric acid is technically difficult to produce, and needs special precautions when stored, as it is highly hygroscopic and will absorb water from the air. But making it 99.99% is only a technical difficulty, there is no reason why it couldn't be done.
Likes AMan24
Really, that's interesting. I figured it was the absolute limit
For most substances the only absolute limit is 100%.
For some things get complicated, as they are in fact an equilibrium mixture of several things, or they are unstable and can't be produced pure.
Likes AMan24
Related to Question about acids And molarity vs concentration
What is the difference between molarity and concentration?
Molarity is a measure of the number of moles of a substance per liter of solution, while concentration is a measure of the amount of a substance in a given volume of solution. Molarity takes into account the volume of the solution, while concentration does not.
How do you calculate molarity?
Molarity can be calculated by dividing the number of moles of the solute by the volume of the solution in liters. The formula for molarity is: M = moles of solute / liters of solution.
Can molarity and concentration values be the same?
Yes, molarity and concentration values can be the same if the volume of the solution is 1 liter. In this case, the molarity and concentration will have the same numerical value.
What are some common acids used in science?
Some common acids used in science include hydrochloric acid, sulfuric acid, nitric acid, and acetic acid. These acids are commonly used in experiments and industrial processes.
How do acids and molarity affect each other?
Acids have varying molarity values depending on their strength and concentration. A strong acid will have a higher molarity compared to a weak acid with the same concentration. Changing the molarity of an acid can also affect its pH level, making it more or less acidic.
  • Chemistry
  • Chemistry
