A Question about an equation from anapole measurement paper
  • A
  • Thread starter Thread starter BillKet
    Measurement Paper
BillKet
Hello! I have a question about this paper. They claim that the hyperfine and spin-rotational terms can be treated perturbatively (they do perform a full diagonalization, too, but they claim that perturbation theory is good to get an estimate of the effect). I agree with that for most of the terms, except for ##c(I\cdot n)(S\cdot n)##. For example, let's assume we use as the level crossing the states (using the notation in order N, S, I):
$$\psi_+ = |0,0>|1/2,1/2>|1/2,1/2>$$
and
$$\psi_- = |1,1>|1/2,-1/2>|1/2,1/2>$$
The operator ##c(I\cdot n)(S\cdot n)## can be expanded (I will ignore some constants, I will write just the operators) as ##c(I_zY_1^0+I_+Y_1^{-1}+I_-Y_1^1)(S_zY_1^0+S_+Y_1^{-1}+S_-Y_1^1)## and among these, the term ##cI_zY_1^0S_-Y_1^1## doesn't seem to vanish when calculated between ##\psi_+## and ##\psi_-## i.e.
$$<\psi_-|cI_zY_1^0S_-Y_1^1|\psi_+> \neq 0$$
which is about equal to c. But when doing perturbation theory, the effect of this term would be about ##\frac{c}{E_+-E_-}## and while c is very small, ##E_+-E_-## is much smaller (ideally as small as the parity violation effect), so I don't see how this can be treated pertubatively. Am I missing something? Is that matrix element actually vanishing? Thank you!
and
I realized I am dumb, of course that term has to be zero, as it would otherwise connect 2 terms of opposite parity. But I would appreciate if someone can help me figure out why does the math looks like it is not zero?
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
