Question about angles and triangles I thinkg
In summary: They didn't have to do the measurements during a solar eclipse because the geometry is the same no matter what time of year it is.
pbody
41
1. How does the moon's diameter compare with the distance between Earth and the Moon
Tape a small coin, such as a dime to a window and view it with one eye so that it just blocks out the full Moon. This occurs when your eye is about 110 coin diameters away. Then the ratio of coin diameter/ coin distance is about 1/110. Geometrical reasoning of similar triangles shows this is also the ratio of Moon diameter/Moon distance. So the distance to the Moon is 110 times the Moon's diameter. The early Greeks knew this. Aristarchus's measurement of the Moon's diameter was all that was needed to calculate the Earth - Moon distance. So the early Greeks knew both the size of the Moon and its distance from Earth.
2. moon diameter is 1 and the moon distance is 110 1/110
3. I understand that looking at the moon it is a total of 1 moon diameter and the distance is 110 moons away.
but I don't understand at the same time where and how this is theasable. How would you correctly get that measurement and why. I know this man Aritarchus didn't have 110 moons so I am assuming he used geometry but how did he decide on the angle, or what ever.
I don't know if I am making sense.
Than it also states that you can use the same method with the sun, which is 1/110. I do not understand basically because I am assuming if you did this with Jupiter there would be a lot more Jupiters than 110.
The greeks new the bit about the coin. eg that a coin held 110 diameters away blocked out the moon. That's an easy experiment to do.
They also understood the properties of "similar triangles"... Read down to and including "Example 27" , Don't worry there aren't 27 examples to read!..
http://www.mathsteacher.com.au/year9/ch13_geometry/08_similar/similar.htm
The angle subtended by the coin and moon are the same (0.54°) so...
Coin Diameter/Coin distance = Moon Diameter/Moon Distance
So all they needed was the moon diameter and they could calculate it's distance.
Then along came Aritarchus and he worked out how to measure the diameter..
http://www.astro.cornell.edu/academics/courses/astro201/aristarchus.htm
Thats because by chance the angle subtended by the moon and sun is very similar..
0.54 degrees for the moon
0.52 degrees for the sun
See..
http://www.mathopenref.com/subtend.html
or put it another way...The moon just happens to be the right size and distance away so that it appears the same size as the much bigger and further away sun.
eg by pure fluke...
Moon diameter/moon distance ≈ sun diameter/sun distance
It does not work for Jupiter because Jupiter is the wrong size and distance.
I will be back I have to go to the store and get a protractor I don't know where mine is and my desk is an absolute mess!
In theory couldn't you perceive let's still use Jupiter as a similar angle comparison to the moon? couldn't you have Jupiter diameter and Jupiter distance which of course would be more than the moon and sun distance of 110. but depending on how you look at it would you be able to contort it to the angle of which you want? I know we started measuring distance in light years over angular measurements but I am a little confused.
I am not trying to be smart I am just trying to understand to the best of my capabilities.
*wait - I just thought of this did they do the measurements during a solar eclipse, because if they did that would make sense I am looking at the diagram and everything seems to be aligned as if there was and eclipse or something.
Related to Question about angles and triangles I thinkg
1. What is the difference between an angle and a triangle?
An angle is formed by two intersecting lines and consists of a vertex and two rays. A triangle is a three-sided polygon with three angles, each of which is formed by two sides of the triangle.
2. How do you measure an angle?
An angle can be measured using a protractor. Place the center of the protractor on the vertex of the angle and align one of the rays with the baseline of the protractor. The number where the second ray intersects the protractor is the measure of the angle in degrees.
3. What is the sum of the angles in a triangle?
The sum of the angles in a triangle is always 180 degrees. This can be proven using the fact that a straight line forms a 180 degree angle and a triangle can be divided into two triangles by drawing a line from one vertex to the midpoint of the opposite side.
4. Can a triangle have two right angles?
No, a triangle can only have one right angle (90 degrees). This is because the sum of the angles in a triangle is 180 degrees and if two angles are right angles, the third angle would have to be 0 degrees, which is not possible.
5. How do you find the missing angle in a triangle?
To find the missing angle in a triangle, you can use the fact that the sum of the angles in a triangle is 180 degrees. If you know the measures of two angles, you can subtract their sum from 180 to find the missing angle. Alternatively, you can use the properties of similar triangles or the Pythagorean theorem to find the missing angle.
  • Astronomy and Astrophysics
11K
